Games/Software met Vista
madrofiel
4 nov 2005
Ik heb pas Windows Vista Final NL geinstalleerd maar ik heb nu een probleem met het Opstarten van een spel (Lineage 2 Chaotic Chronicle 4) en software (Ecplise).
Bij Lineage 2 Chaotic Chronicle 4 doet hij gewoon niks, ik druk op het icoontje en niks (hij staat wel in Taakbeheer) Lineage 2 Chaotic Chronicle 5 doet het wel!
Bij eclipse krijg ik een error:
eclipse.buildId=M20060921-0945
java.version=1.5.0_10
java.vendor=Sun Microsystems Inc.
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=nl_NL
Command-line arguments:  -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.osgi 4 0 2006-12-10 10:33:10.386
!MESSAGE Application error
!STACK 1
java.lang.UnsatisfiedLinkError: no swt-win32-3235 in java.library.path
	at java.lang.ClassLoader.loadLibrary(Unknown Source)
	at java.lang.Runtime.loadLibrary0(Unknown Source)
	at java.lang.System.loadLibrary(Unknown Source)
	at org.eclipse.swt.internal.Library.loadLibrary(Library.java:123)
	at org.eclipse.swt.internal.win32.OS.<clinit>(OS.java:18)
	at org.eclipse.swt.widgets.Display.<clinit>(Display.java:125)
	at org.eclipse.ui.internal.Workbench.createDisplay(Workbench.java:433)
	at org.eclipse.ui.PlatformUI.createDisplay(PlatformUI.java:161)
	at org.eclipse.ui.internal.ide.IDEApplication.createDisplay(IDEApplication.java:122)
	at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplication.java:75)
	at org.eclipse.core.internal.runtime.PlatformActivator$1.run(PlatformActivator.java:78)
	at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:92)
	at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:68)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:400)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:177)
	at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
	at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
	at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
	at java.lang.reflect.Method.invoke(Unknown Source)
	at org.eclipse.core.launcher.Main.invokeFramework(Main.java:336)
	at org.eclipse.core.launcher.Main.basicRun(Main.java:280)
	at org.eclipse.core.launcher.Main.run(Main.java:977)
	at org.eclipse.core.launcher.Main.main(Main.java:952)
Ik heb ook problemen met instaleren van Sony vegas 6.0d het vraagt om Framework 1.1 terwijl ik Framework 3 heb!
Kunnen jullie mij helpen alvast bedankt
Lang niet alle games zullen werken op Vista. Dit komt door de drivers voor je videokaart.. er zijn wel nieuwe drivers uit, maar deze werken ook niet altijd 100%.
Nvidia > www.nvidia.com
Ati > www.ati.com
Voor de drivers.
Ik heb "Test" laten uitvoeren met die Vista upgrade advisor maar alles is goed er is geen fout
-.-' Update 10
Ho...:shocked: Ik wist nog niet eens dat-ie er was. :)
En heb je hetinstallatie bestand van Eclips ook?
Misschien ook Java opnieuw installeren, want hij wordt niet herkend lijkt het wel uit je foutmeldingen.
ik verwijder Update 10 wel en dan installeer ik update 9 :)
J2SE(TM) Development Kit 5.0 Update 10
The Java SE Development Kit (JDK) includes:
the Java Runtime Environment (JRE)
command-line development tools, such as compilers and debuggers, that are necessary or useful for developing applets and applications
Je hebt denk ik de SDK voor ontwikkelaars gedownload, ik zou die Development Kit er ook af gooien.
ik heb nodig:
JDK (voor eclipse)
JRE (voor JAVA game server)
welke moet ik dan nemen Update 9 (heeft altijd gewerkt) of Update 10 -.-
ik heb hier nog eens naar gekeken, maar ik wil niet vervelend doen: heb je wel het goede programma gedraaid?
Uit mijn eigen rapportage haal ik een voorbeeld hier naar toe.
Respectabele programma's worden wel als "zorgenkindje" gerapporteerd.
Bij jou dus geen enkel programma?
(Klikbaar dus.)
java.version=1.4.2_13
!ENTRY org.eclipse.osgi 4 0 2006-12-10 11:42:19.177
!STACK 1
!ENTRY org.eclipse.osgi 2 0 2006-12-10 11:42:19.208
!MESSAGE The following is a complete list of bundles which are not resolved, see the prior log entry for the root cause if it exists:
!SUBENTRY 1 org.eclipse.osgi 2 0 2006-12-10 11:42:19.208
!MESSAGE Bundle update@plugins/org.eclipse.jdt.apt.core_3.2.1.R32x_v20060822-2100.jar [38] was not resolved.
!SUBENTRY 2 org.eclipse.jdt.apt.core 2 0 2006-12-10 11:42:19.208
!MESSAGE Missing Constraint: Bundle-RequiredExecutionEnvironment: J2SE-1.5
!MESSAGE Bundle update@plugins/org.eclipse.jdt.apt.ui_3.2.1.R32x_v20060822-2100.jar [39] was not resolved.
!SUBENTRY 2 org.eclipse.jdt.apt.ui 2 0 2006-12-10 11:42:19.208
!MESSAGE Missing required bundle org.eclipse.jdt.apt.core_[3.2.0,4.0.0).
!MESSAGE Bundle update@plugins/org.eclipse.jdt.junit4.runtime_1.0.1.r321_v20060905.jar [47] was not resolved.
!SUBENTRY 2 org.eclipse.jdt.junit4.runtime 2 0 2006-12-10 11:42:19.208
!MESSAGE Missing required bundle org.junit4_[4.1.0,4.2.0).
!MESSAGE Bundle update@plugins/org.junit4_4.1.0.1/ [113] was not resolved.
!SUBENTRY 2 org.junit4 2 0 2006-12-10 11:42:19.208
ok ik heb nu j2re 1.4.2.13 geinstalleerd samen met j2sdk 1.4.2.13 omdat ik deze ook op XP had en nu krijg ik de bovenstaande error als ik eclipse open
Even kijken waar je mee bezig bent. Je hebt Vista geinstalleerd en twee programma's doen het niet. Daarvan geeft Eclipse een foutenrapportage.
Iedere normale gebruiker (dus geen software-ontwikkelaar zijnde) heeft op zijn systeem staan van Java: J2SE Environment Runtime 5.0 Update 9.
Waarom jij nu (weer) een andere versie hebt geinstalleerd is me onduidelijk.
Ik heb je geadviseerd de Windows Vista Upgrade Advisor RC te downloaden en het programma te "draaien". Jij zegt dat er geen fouten waren gevonden, ik liet zien dat er bij programma's van Microsoft, ATI en Power DVD comptabiliteits-problemen konden onstaan, dat er dus stuurprogramma-problemen konden komen.
1. Ik heb je gevraagd: heb je wel de goede Vista Advisor test gedaan?
2. Waarom gebruik nu weer een andere Java en niet 5 update 9?
Ik wil even orde op zaken, het is nu wat te verward allemaal.
ok allemaal effen op een rijtje.
ik heb Windows Vista Ultimate Geinstalleerd.
Daarbij kwam ik tot de ontdekking dat Eclipse een foutmelding geeft.
Ik heb nu helemaal geen java meer op me PC staan.
Ik ga nu Java 5 Update 9 Installeren.
Ok Update 9 is niet meer op de site te downloaden.
Moet ik nu Update 10 downloaden?
Bedoel je dat je Vista er weer afgegooid hebt?
Op deze Java-site kun je versie 5 Update 9 downloaden, maar misschien moet je dan eerst alle andere versies verwijderen.
Ok, ik heb nu alleen JRE 5 Update 9 op me PC staan.
Ik start eclipse en ik krijg deze error:
java.version=1.5.0_09
!ENTRY org.eclipse.osgi 4 0 2006-12-10 12:59:50.791
!STACK 1
Ik heb al eerder een afbeelding laten zien van mijn rapport van de Vista Advisor.
Ik laat nu opnieuw een beeld zien van de uitslag van de Vista Advisor. Ik heb mijn systeem laten beoordelen op gereed voor Vista Ultimate, net als de vorige keer.
Er worden een aantal opmerkingen gemaakt en ik moet iets gaan ondernemen in verband met stuurprogramma's die misschien niet werken onder Vista.
Zie de afbeelding.
Wat was de exacte uitslag van jouw Vista-test?
(Hier op klikken voor een vergroting.)
