Ik heb hier een macro ik heb hem via de opneem functie gemaakt en daarna nog deels ingekort maar hij blijft traag.
weet iemand misschien hoe hij nog meer ingekort kan worden of in ieder geval vlugger gemaakt kan worden???
Greetz AVA
Sub Macro1()
' Macro1 Macro
Sub Printen()
' Printen Macro
If Range("D4") = 0 Then MsgBox "Aantal kasten: is niet ingevuld."
If Range("D4").Value = 0 Then Range("D4").Select: GoTo 1 Else GoTo 2
1: With Selection.Interior
.Pattern = xlSolid
.PatternColorIndex = xlAutomatic
.Color = 255
End With: GoTo getout2
2: Range("D4").Select
.Pattern = xlNone
If Range("C26") = 0 Then MsgBox "Naam klant: is niet ingevuld."
If Range("C26").Value = 0 Then Range("C26").Select: GoTo 3 Else GoTo 4
3: With Selection.Interior
.Pattern = xlSolid
.Color = 255
4: Range("C26").Select
.Pattern = xlNone
If Range("D26") = 0 Then MsgBox "Tel klant: is niet ingevuld."
If Range("D26").Value = 0 Then Range("D26").Select: GoTo 5 Else GoTo 6
5: With Selection.Interior
.Pattern = xlSolid
.Color = 255
6: Range("D26").Select
.Pattern = xlNone
If Range("E26") = 0 Then MsgBox "Adres klant: is niet ingevuld."
If Range("E26").Value = 0 Then Range("E26").Select: GoTo 7 Else GoTo 8
7: With Selection.Interior
.Pattern = xlSolid
.Color = 255
8: Range("E26:G26").Select
.Pattern = xlNone
If Range("H26") = 0 Then MsgBox "Email klant: is niet ingevuld."
If Range("H26").Value = 0 Then Range("H26").Select: GoTo 9 Else GoTo getout
9: With Selection.Interior
.Pattern = xlSolid
.Color = 255
getout: Range("H26:J26").Select
.Pattern = xlNone
With ActiveSheet.PageSetup
.LeftMargin = Application.InchesToPoints(0.6)
.RightMargin = Application.InchesToPoints(0.45)
.TopMargin = Application.InchesToPoints(0.65)
.BottomMargin = Application.InchesToPoints(0)
.HeaderMargin = Application.InchesToPoints(0)
.FooterMargin = Application.InchesToPoints(0)
.Zoom = False
.FitToPagesWide = 1
.FitToPagesTall = 1
ActiveWindow.SelectedSheets.PrintPreview
getout2:
Greetz AVA
