Daphne82
- 18 jul 2004
Hi,
Ik heb een Griffin iTrip gekocht voor mijn autoradio (zodat ik mijn iPod erop kan aansluiten) alleen kom er zoals gewoon weer niet helemaal uit.
Ik heb de software geinstalleerd in combo met iTunes.
Toen heb ik dit gedaan:
Last minute details:
You will need to import the XML file into iTunes after the installer completes.
To do this:
1. Run iTunes
2. Click File --> Import
3. Click the "Look In" pull down and select "Local Disk (C"
4. Click the "Files of Type" pull down and select "XML Files (*.XML)"
5. Double Click the iTrip (.xml) file
This should import the appropriate stations into your iTunes library. Sync up your iPod and
you're ready to go.
If you scroll down there is a graphical step-by-step.
1. Run iTunes
You should now have a iTrip Stations playlist under the source pane in iTunes
If your iTrip Stations playlist is empty go to File-->New Smart Playlist. In the blank text box type Griffin Technology. This will create the appropriate playlist.
you're ready to go.
-Griffin Technology
Tech Support Team
Wat nu???
-Griffin Technology
Tech Support Team
To do this:
1. Run iTunes
you're ready to go.
1. Run iTunes
you're ready to go.
-Griffin Technology
Tech Support Team
Wat nu???
-Griffin Technology
Tech Support Team
