hey mensen ik heb iets gevonden op een site maar ben niet zo goed in engels
dit heb ik gevonden op de site hieronder en daar onder staat iets beschreven ik snap het niet helemaal ben niet zo goed in engels
http://filext.com/info/archive/index.php/t-430.html
THANK THE GODS FOR HELPING ME FIND THIS SITE AND fFOR DABOSS AND CHEESEY_ITEM FOR HELPING ME!!!!!
Well, as you can tell, I have my computer back. Thank you sooooo much. Now, in case people end up having the same problem as me, this is what I did (thanks to the above mentioned guys who helped me out).
(1) i pressed Alt+Ctrl+Del and brought up the Task Manager, then I selected the File Menu and clicked on New Task while holding the Ctrl button.This brings up the Command Prompt.
(2) Followed DaBoss' instructions on copying regedit as a .com file that DaBoss has on:
http://filext.com/info/showthread.php?p=12
(3) I ran regedit.com and then selected the File Menu and clicked on Import and selected the fix that DaBoss has on the above link.
Now this didn't fix all the link problems, so then I ran the other fixes that are at the link that Cheesey_Item left in this thread:
http://www.dougknox.com/xp/file_assoc.htm
(COM File Assoc Fix, EXE File Assoc Fix, Link File Assoc, REG File Assoc)
(4) As soon as I did this, guess what popped up? That darn Ad-Aware asking me if I wanted to Accept or Block the changes in registry. The first time I clicked on Accept and it messed up my extensions again so I had to do the above steps for a second time. When that window pops up asking about the registry, Don't select anything, click on the Ad-aware icon in your sys tray and Select Unload Ad-aware and then uninstall it.
(5) Shut down computer by using the Start menu and then turn it back on.
(6) Next, I was still missing a bunch of stuff in my system tray that I really need (like internet connection, touch mouse pad, audio options, and other stuff that wouldn't run for some reason) so I just rebooted with my Windows XP CD, selected repair and my laptop is back to her old self again.
There you have it, long but it may help someone else in the future.
thank you thank you thank you thank you thank you!!!!!!!
