branden met DVD shrink lukt niet meer
hangmat
22 mei 2001
Het heeft altijd goed gewerkt, maar met de backup die ik vandaag wilde maken gaat het keer op keer mis. Ik gebruik DVD shrink om mijn backups te maken. Ik kreeg vandaag deze wazige foutmelding nadat hij wel alles netjes in de temp map had gezet:
Windows XP 5.1
IA32
WinAspi: File 'Wnaspi32.dll': Ver=4.57 (1008), size=48128 bytes, created 23-12-1997 2:23:24
ahead WinASPI: File 'G:\Program Files\Ahead\Nero\Wnaspi32.dll': Ver=2.0.1.56, size=163910 bytes, created 2-4-2003 8:13:44
Nero API version: 6.0.0.0
Using interface version: 6.3.1.4
Installed in: G:\Program Files\Ahead\Nero\
Application: ahead\Nero - Burning Rom
Recorder: <_NEC DVD_RW ND-3500AG> Version: 2.18 - HA 0 TA 0 - 6.0.0.0
Adapter driver: <atapi> HA 0
Drive buffer : 2048kB
Bus Type : via Inquiry data (1) -> ATAPI, detected: ATAPI
Connected to MMC as unknown drive with class-nr : 1
Drive is autodetected - recorder class: Std. MMC recorder
=== Scsi-Device-Map ===
CdRomPeripheral : _NEC DVD_RW ND-3500AG atapi Port 0 ID 0 DMA: On
CdRomPeripheral : CD-R/RW CW099D CD-R/RW atapi Port 0 ID 1 DMA: On
DiskPeripheral : ST340016A atapi Port 1 ID 0 DMA: On
DiskPeripheral : WDC WD400BB-00DEA0 atapi Port 1 ID 1 DMA: On
AutoRun : 1
Excluded drive IDs:
CmdQueuing : 1
CmdNotification: 2
WriteBufferSize: 83886080 (0) Byte
ShowDrvBufStat : 0
EraseSpeed : 0
BUFE : 0
Physical memory : 1023MB (1048048kB)
Free physical memory: 694MB (711052kB)
Memory in use : 32 %
Uncached PFiles: 0x0
Use Static Write Speed Table: 0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
30.4.2007
NeroAPI
18:14:33 #1 Phase 112 File APIProgress.cpp, Line 232
DVD-Video files reallocation started
18:14:33 #2 DVDREALLOC -21 File DVDVideoCompilation.cpp, Line 1161
Required file 'VIDEO_TS.VOB' is not present
18:14:33 #3 Phase 115 File APIProgress.cpp, Line 232
DVD-Video files reallocation failed
Existing drivers:
File 'Drivers\ASPI32.SYS': Ver=4.57 (1008), size=23936 bytes, created 23-12-1997 3:02:46
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
Nogmaals, alles heeft altijd goed gewerkt. De zelfde bestanden branden op een andere pc geeft hetzelfde resultaat. Afspelen met VLC vanuti de temp map gaat dan weer wel, dus de bestanden zijn niet corrupt ofzo! Heeft iemand een idee wat hier aan de hand is?
Inderdaad vaag.
Dit lijkt op zich niks met DVD-shrink te maken te hebben ......
Mag ik vragen waar je eigenlijk een backup van maakt.
Want dit programma is eigenlijk bedoeld om de films, waarvan de omvang te groot is te 'shrinken' tot een omvang die wél op een (in de regel 4.7Gb) dvd past .....
Zo lijkt het erop dat je film niet compleet is. Kijk eens of dat bestand wel in de map staat die je wilde branden met Nero?
Of misschien stel je de DVD verkeerd samen:
Voor een geldige DVD is een map VIDEO_TS op de dvd verplicht.
Als je in Nero aangeeft een DVD-video te willen branden dan geeft/maakt Nero zelf al een VIDEO_TS map aan. Je moet dan dus alle bestanden die je met DVD Shrink hebt gebouwd in die VIDEO_TS map slepen. Heb je op je harddisk een map VIDEO_TS staan met de film, dan moet je dus de inhoud van die map naar VIDEO_TS slepen in je DVD-Video compilatie in Nero.
We horen het wel.
Tijs.
