Kristal
Ik denk niet mp3, op het internet is veel info over kristal
Zoek maar op Krstal audio
KRISTAL Audio Engine
16 audio tracks
32 Bit floating point audio engine
44.1 to 192 kHz sample rate*
Downmix to 16/24/32 Bit audio files
3-band parametric EQ &
2 VST insert slots per channel
3 VST master effect slots
ASIO low latency audio driver support
4 KRISTAL Plug-In slots
Load/Save KRISTAL project files
Supported file formats: WAVE, AIFF, FLAC, OGG Vorbis
The following Plug-Ins are included in the KRISTAL package:
KRISTAL Waver
the sequencer Plug-In for KRISTAL
multichannel harddisk recording via ASIO/MME
ASIO input monitoring
audio clip arrangement
audio clip fade-in/fade-out/crossfade
unlimited undo/redo
AES31 Export
