Heb dit aan de hand gehad met 'n pc van een kennis en vond toen dit en het werkte!
Vul de zoekterm wmploc.dll bij zoeken in (alleen op C)en je hebt ze zó gevonden!
N.B.
Werkt ook met SP3
The version of Windows Media Technologies is incompatible With This Version Of Windows
found the solution
> If you installed XP SP2 simply COPY the file wmploc.dll(version 10.0.0.3802) from
> C:/WINDOWS/SERVICE PACK FILES/I386
> TO
> C:/WINDOWS/SYSTEM32
> It worked for me
You have deleted key system files from your machine. Restore the file
c:\windows\system32\wmploc.dll by copying it from
c:\windows\system32\dllcache (or from your XP CD) and then you should be
able to move forward again.
Here is the fix. From the question below, I searched to
>> find that answer myself. I found that wmploc.dll was not
>> in my system32 folder. So I did a search for that .dll
>> file in my system and I found it in my
>> c:\windows\ServicePackFiles\i386 folder. For some
>> reason, the file was in what I assume is the SP2
>> installation folder, or something to do with the
>> install. I copied the file from there into my system32
>> folder. I started Windows Media Player and version 9
>> started. I installed the upgrade to version 10 and it
>> worked fine
C:\WINDOWS\RegisteredPackages\{DD90D410-1823-43EB-9A16-A2331BF08799}\wmploc.dll(version 10.0.0.3802) 3.324 kb
Bron: onbekend
