jolly01
- 12 apr 2009
Onderstaand de code van Ron de Bruin om een range uit een sheet om te zetten naar de body van een email.
Ron's voorbeeld toont 1 range voor de Body. Ik zou graag 2 ranges voor de body willen gebruiken. De eerste range in tabblad "Sjabloon" A1:A10 en de tweede Range in tabblad "Export" A1:F43 direct eronder in de body van de email.
Kan iemand Ron's code aanpassen zodat ik beide ranges onder elkaar in de body van de email krijg?
Function RangetoHTML(rng As Range)
' Changed by Ron de Bruin 28-Oct-2006
' Working in Office 2000-2010
Dim fso As Object
Dim ts As Object
Dim TempFile As String
Dim TempWB As Workbook
TempFile = Environ$("temp") & "\" & Format(Now, "dd-mm-yy h-mm-ss") & ".htm"
'Copy the range and create a new workbook to past the data in
rng.Copy
Set TempWB = Workbooks.Add(1)
With TempWB.Sheets(1)
.Cells(1).PasteSpecial Paste:=8
.Cells(1).PasteSpecial xlPasteValues, , False, False
.Cells(1).PasteSpecial xlPasteFormats, , False, False
.Cells(1).Select
On Error Resume Next
.DrawingObjects.Visible = True
.DrawingObjects.Delete
On Error GoTo 0
'Publish the sheet to a htm file
With TempWB.PublishObjects.Add( _
SourceType:=xlSourceRange, _
Filename:=TempFile, _
Sheet:=TempWB.Sheets(1).Name, _
Source:=TempWB.Sheets(1).UsedRange.Address, _
HtmlType:=xlHtmlStatic)
.Publish (True)
'Read all data from the htm file into RangetoHTML
Set fso = CreateObject("Scripting.FileSystemObject")
Set ts = fso.GetFile(TempFile).OpenAsTextStream(1, -2)
RangetoHTML = ts.readall
ts.Close
RangetoHTML = Replace(RangetoHTML, "align=center x:publishsource=", _
"align=left x:publishsource=")
'Close TempWB
TempWB.Close savechanges:=False
'Delete the htm file we used in this function
Kill TempFile
Set ts = Nothing
Set fso = Nothing
Set TempWB = Nothing
End Function
Sub Mail_Range_Outlook_Body()
' Don't forget to copy the function RangetoHTML in the module.
Dim rng As Range
Dim OutApp As Object
Dim OutMail As Object
With Application
.EnableEvents = False
.ScreenUpdating = False
Set rng = Nothing
[COLOR="red"]Set rng = Sheets("Sjabloon").Range("A1:B10").SpecialCells(xlCellTypeVisible)
Set rng = Sheets("Export").Range("A1:F43").SpecialCells(xlCellTypeVisible)[/COLOR] On Error GoTo 0
If rng Is Nothing Then
MsgBox "The selection is not a range or the sheet is protected" & _
vbNewLine & "please correct and try again.", vbOKOnly
Exit Sub
Set OutApp = CreateObject("Outlook.Application")
Set OutMail = OutApp.CreateItem(0)
With OutMail
.To = "aaaaa@bbbbbb.com"
.CC = ""
.BCC = ""
.Subject = "This is the Subject line"
.HTMLBody = RangetoHTML(rng)
.Display 'or use .Send
On Error GoTo 0
With Application
.EnableEvents = True
.ScreenUpdating = True
Set OutMail = Nothing
Set OutApp = Nothing
