<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN" "http://www.w3.org/TR/html4/strict.dtd">
<html>
<head>
<meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1">
<meta name="description"content="Hondenschool SimonSays in Elsloo, een gezellige hondenschool waar honden op een positieve manier getraind worden!">
<meta name="keywords"content="Hondenschool, Hondenschool Elsloo, leuke hondenschool, SimonSays, Simone Otter, Puppycursus, Hondenschool Friesland,
puppycursus Friesland, Probleemhonden, Probleemgedrag honden, Gedragstherapie honden, Probleemhonden Friesland, opvoeding honden">
<title>Hondenschool SimonSays, de leukste hondenschool van Friesland!</title>
<link rel="stylesheet" type="text/css" href="style.css">
function roll_over(img_name, img_src)
document[img_name].src = img_src;
function MM_swapImgRestore() { //v3.0
var i,x,a=document.MM_sr; for(i=0;a&&i<a.length&&(x=a[i])&&x.oSrc;i++) x.src=x.oSrc;
function MM_preloadImages() { //v3.0
var d=document; if(d.images){ if(!d.MM_p) d.MM_p=new Array();
var i,j=d.MM_p.length,a=MM_preloadImages.arguments; for(i=0; i<a.length; i++)
if (a[i].indexOf("#")!=0){ d.MM_p[j]=new Image; d.MM_p[j++].src=a[i];}}
function MM_findObj(n, d) { //v4.01
var p,i,x; if(!d) d=document; if((p=n.indexOf("?"))>0&&parent.frames.length) {
d=parent.frames[n.substring(p+1)].document; n=n.substring(0,p);}
if(!(x=d[n])&&d.all) x=d.all[n]; for (i=0;!x&&i<d.forms.length;i++) x=d.forms[i][n];
for(i=0;!x&&d.layers&&i<d.layers.length;i++) x=MM_findObj(n,d.layers[i].document);
if(!x && d.getElementById) x=d.getElementById(n); return x;
function MM_swapImage() { //v3.0
var i,j=0,x,a=MM_swapImage.arguments; document.MM_sr=new Array; for(i=0;i<(a.length-2);i+=3)
if ((x=MM_findObj(a[i]))!=null){document.MM_sr[j++]=x; if(!x.oSrc) x.oSrc=x.src; x.src=a[i+2];}
</script>
</head>
<body onLoad="MM_preloadImages('img/voorstellen2.gif','img/home2.gif','img/cursussen2.gif','img/tarieven2.gif','img/therapie2.gif','img/links2.gif','img/contact2.gif')">
<div id="container">
<div id="header"></div>
<div id="menu">
<a href="index.html"><img src="img/home2.gif" alt=""></a><img src="img/slash.gif" alt="">
<a href="voorstellen.html" onMouseOut="MM_swapImgRestore()" onMouseOver="MM_swapImage('Voorstellen','','img/voorstellen2.gif',1)"><img src="img/voorstellen.gif" name="Voorstellen" width="127" height="30" alt=""></a><img src="img/slash.gif" alt="">
<a href="cursus.html" onMouseOut="MM_swapImgRestore()" onMouseOver="MM_swapImage('Cursus','','img/cursussen2.gif',1)"><img src="img/cursussen.gif" name="Cursus" width="77" height="30" alt=""></a><img src="img/slash.gif" alt="">
<a href="tarieven.html" onMouseOut="MM_swapImgRestore()" onMouseOver="MM_swapImage('Tarieven','','img/tarieven2.gif',1)"><img src="img/tarieven.gif" name="Tarieven" width="66" height="30" alt=""></a><img src="img/slash.gif" alt="">
<a href="therapie.html" onMouseOut="MM_swapImgRestore()" onMouseOver="MM_swapImage('Therapie','','img/therapie2.gif',1)"><img src="img/therapie.gif" name="Therapie" width="129" height="30" alt=""></a><img src="img/slash.gif" alt="">
<a href="links.html" onMouseOut="MM_swapImgRestore()" onMouseOver="MM_swapImage('Links','','img/links2.gif',1)"><img src="img/links.gif" name="Links" width="39" height="30" alt=""></a><img src="img/slash.gif" alt="">
<a href="contact.html" onMouseOut="MM_swapImgRestore()" onMouseOver="MM_swapImage('Contact','','img/contact2.gif',1)"><img src="img/contact.gif" name="Contact" width="61" height="30" alt=""></a>
</div>
<div id="content">
<div id="foto"> <img src="img/2klein.jpg" alt=""> <br>
<img src="img/7klein.jpg" alt=""> </div>
<div id="tekst">
<p>DE HONDENSCHOOL</p>
De relatie tussen baas en hond is een heel bijzondere. U als baas moet aan
de ene kant vertrouwen en veiligheid uitstralen en aan de andere kant moet
u duidelijk zijn, eerlijk en consequent. Voor een optimale relatie tussen
baas en hond is het belangrijk dat u uw hond kunt 'lezen'. Dat u weet waarom
hij doet wat hij doet en wat hij daarmee bedoelt. SimonSays laat u naar
uw hond kijken op een hondse manier! <br>
<br>
Ik vind het belangrijk dat een hond uitgroeit tot een evenwichtige vriendelijke
viervoeter die gewend is aan alledaagse dingen, dieren en kinderen. Een
hond die goed luistert naar de baas, en niet trekt aan de riem. Minder belangrijk
vind ik hoe recht de hond naast de baas zit, of hoe snel hij gaat liggen
op het commando af. Aan welke kant de hond 'behoort' te lopen en of hij
met zijn neus omhoog of omlaag loopt. Een hond moet vooral hond kunnen zijn
in mijn lessen, en natuurlijk daarbuiten. <br>
<br>
We trainen met de honden op een positieve manier. Dat wil zeggen dat we
gewenst gedrag belonen, en ongewenst gedrag zo veel mogelijk negeren. Hierbij
kijk ik naar de rasspecifieke kenmerken van de verschillende honden zodat
ieder op zijn eigen niveau en eigen manier kan trainen. Dit betekent dus
dat er geen goed of fout is, maar wel goed en beter. <br>
<br>
Wilt u ook het beste voor uw hond? Dan heet ik u graag van harte welkom
op mijn hondenschool! <br>
<br>
<p>WAAROM EEN CURUS BIJ SIMONSAYS?</p>
<img src="img/pootje.gif" alt="">Kleine groepjes (3 tot 5 honden).<br>
<img src="img/pootje.gif" alt="">Positieve trainingsmethode!<br>
<img src="img/pootje.gif" alt="">U mag per les betalen, als u een les mist hoeft
u deze ook niet te betalen.<br>
<img src="img/pootje.gif" alt="">We maken eens per 4 weken een leuk, leerzaam uitstapje.<br>
<img src="img/pootje.gif" alt="">U kunt doorlopend instromen.<br>
<img src="img/pootje.gif" alt="">Het hele gezin mag mee!<br>
<img src="img/pootje.gif" alt="">Niets hoeft, alles mag.<br>
<img src="img/pootje.gif" alt="">Er is ruimte voor eigen inbreng.<br>
<img src="img/pootje.gif" alt="">Enthousiaste, gediplomeerd instructrice, tevens
gedragstherapeut<br>
<img src="img/pootje.gif" alt="">Geen vaste lestijden, maar lessen op afspraak.<br>
<img src="img/pootje.gif" alt="">Trainen op je eigen niveau.<br>
<img src="img/pootje.gif" alt="">Ook voor oudere honden heb ik plaats (je bent
nooit te oud om te leren!!) </div>
<div class="clear"></div>
<div id="onderrand"></div>
</div>
</div>
var gaJsHost = (("https:" == document.location.protocol) ? "https://ssl." : "http://www.");
document.write(unescape("%3Cscript src='" + gaJsHost + "google-analytics.com/ga.js' type='text/javascript'%3E%3C/script%3E"));
</script>
try {
var pageTracker = _gat._getTracker("UA-10141656-1");
pageTracker._trackPageview();
} catch(err) {}</script>
</body>
</html>
