Exchange 2007 alle mailadressen in inbox exporteren
issam007
3 aug 2015
Beste mensen,
Ik wil in exchange 2007 alle binnengekomen mailadressen in mijn inbox gebruiken, zodat ik deze groep een nieuwsbrief kan versturen.
Kan iemand mij op weg helpen hoe ik dit gedaan kan krijgen.
Over de jaren heen zijn dit best veel mailtjes, dus handmatig kopiëren plakken gaat mij heel veel tijd kosten.
Opgelost
Step 1: Export “From Name” and “From Address” to a csv-file
In this example, we’ll use the Inbox folder as a source but you can use any other mail folder as well. See the section below Step 5 when you want to use the Sent Items folder as a source.
Select the folder you wish to use as the source.
Start the Import and Export Wizard.
Outlook 2007
File-> Import and Export
Outlook 2010
File-> Open-> Import
Outlook 2013
File-> Open & Export-> Import/Export
Choose: Export to a file
Choose: Comma Separated Values
Verify that the correct folder is selected.
Select a folder location and name for your csv-file.
For instance: export-addresses-inbox.csv
If not selected yet, select the checkbox in front of: Export “E-Mail messages” from folder: Inbox
Press: Map Custom Fields…
In the “Map Custom Fields” dialog press: Clear Map
Drag and drop the following fields to the “To:” box on the right.
Press OK and then Finish to start the export process.
