Hallo HSV,
Bedankt voor je reactie, ik weet echter niet hoe ik deze code binnen excel kan toepassen.
Er is reeds een VB programma in het bestand werkzaam, wellicht past jou code daar tussen maar ik weet niet waar.
De tekst van het VB programma luidt:
Option Explicit
'32-bit API declarations
Declare Function SHGetPathFromIDList Lib "shell32.dll" _
Alias "SHGetPathFromIDListA" (ByVal pidl As Long, ByVal _
pszpath As String) As Long
Declare Function SHBrowseForFolder Lib "shell32.dll" _
Alias "SHBrowseForFolderA" (lpBrowseInfo As BrowseInfo) _
As Long
Public Type BrowseInfo
hOwner As Long
pIDLRoot As Long
pszDisplayName As String
lpszTitle As String
ulFlags As Long
lpfn As Long
lParam As Long
iImage As Long
End Type
Function GetDirectory(Optional msg) As String
On Error Resume Next
Dim bInfo As BrowseInfo
Dim path As String
Dim r As Long, x As Long, pos As Integer
'Root folder = Desktop
bInfo.pIDLRoot = 0&
'Title in the dialog
If IsMissing(msg) Then
bInfo.lpszTitle = "Please select the folder of the excel files to copy."
Else
bInfo.lpszTitle = msg
'Type of directory to return
bInfo.ulFlags = &H1
'Display the dialog
x = SHBrowseForFolder(bInfo)
'Parse the result
path = Space$(512)
r = SHGetPathFromIDList(ByVal x, ByVal path)
If r Then
pos = InStr(path, Chr$(0))
GetDirectory = Left(path, pos - 1)
Else
GetDirectory = ""
End Function
Public Function WorksheetExists(ByVal WorksheetName As String) As Boolean
WorksheetExists = (Sheets(WorksheetName).Name <> "")
On Error GoTo 0
End Function
Sub CombineFiles()
Dim path As String
Dim FileName As String
Dim LastCell As Range
Dim Wkb As Workbook
Dim WS As Worksheet
Dim ThisWB As String
ThisWB = ThisWorkbook.Name
With Application
.ScreenUpdating = False
.EnableEvents = False
.DisplayAlerts = False
path = GetDirectory
FileName = Dir(path & "\*.xls", vbNormal)
Do Until FileName = ""
If FileName <> ThisWB Then
Set Wkb = Workbooks.Open(FileName:=path & "\" & FileName)
For Each WS In Wkb.Worksheets
Set LastCell = WS.Cells.SpecialCells(xlCellTypeLastCell)
If LastCell.Value = "" And LastCell.Address = Range("$A$1").Address Then
Else
WS.Name = WS.[E6].Value
WS.Copy After:=ThisWorkbook.Sheets(ThisWorkbook.Sheets.Count)
If WorksheetExists(WS.Name & Chr(32) & "(2)") Then
Sheets(WS.Name).Delete
Sheets(WS.Name & Chr(32) & "(2)").Name = [E6].Value
Next WS
Wkb.Close False
FileName = Dir()
Loop
.DisplayAlerts = True
.EnableEvents = True
.ScreenUpdating = True
Set Wkb = Nothing
Set LastCell = Nothing
Het VB programma zorgt er voor dat losse excel bestanden in een map geopend worden in een excel bestand als tabbladen. Hoop dat je de code kunt tussenvoegen.
Bedankt al vast
