Goedenmiddag,
Ik heb de volgende code staan en krijg daar sinds vandaag de volgende foutmelding bij:
"Fout 1004 tijdens uitvoering: Methode PasteSpecial van klasse Range mislukt."
Weet iemand waardoor ik deze foutmelding krijg, nog beter hoe ik dit kan oplossen? De code is vrij omslachtig, maar werkte vreemd genoeg tot vandaag.
Alvast bedankt!
Alvast bedankt!
Sub Vue_Input_Input()
If Sheets("Vue_Input").Range("C11").Value = "" Then
MsgBox "Fill in your name."
Exit Sub
If Sheets("Vue_Input").Range("C12").Value = "" Then
MsgBox "Fill in the Vue cinema of rental."
Exit Sub
If Sheets("Vue_Input").Range("C16").Value = "" Then
MsgBox "Fill in the date of rental."
Exit Sub
If Sheets("Vue_Input").Range("C18").Value = "" Then
MsgBox "Fill in the rental type."
Exit Sub
If Sheets("Vue_Input").Range("C19").Value = "" Then
MsgBox "Fill in the company or person of rental."
Exit Sub
If Sheets("Vue_Input").Range("C20").Value = "" Then
MsgBox "Fill in the contact for the rental."
Exit Sub
If Sheets("Vue_Input").Range("C21").Value = "" Then
MsgBox "Fill in the address of the company or person of rental."
Exit Sub
If Sheets("Vue_Input").Range("C22").Value = "" Then
MsgBox "Fill in the zippcode and city of the company or person of rental."
Exit Sub
If Sheets("Vue_Input").Range("C24").Value = "" Then
MsgBox "Fill in the email address of the contact."
Exit Sub
If Sheets("Vue_Input").Range("C25").Value = "" Then
MsgBox "Fill in the form of payment."
Exit Sub
If Sheets("Vue_Input").Range("C27").Value = "" Then
MsgBox "Fill in the start time of the rental."
Exit Sub
If Sheets("Vue_Input").Range("C28").Value = "" Then
MsgBox "Fill in the end time of the rental."
Exit Sub
If Sheets("Vue_Input").Range("C29").Value = "" Then
MsgBox "Fill in the cinemas used for the rental."
Exit Sub
If Sheets("Vue_Input").Range("C31").Value = "" Then
MsgBox "Fill in if there is a break during the rental."
Exit Sub
If Sheets("Vue_Input").Range("F16").Value = "" Then
MsgBox "Fill in if the cinema of rental is notified."
Exit Sub
If Sheets("Vue_Input").Range("F18").Value = "" Then
MsgBox "Fill in if the rental is optional or definitive."
Exit Sub
If Sheets("Vue_Input").Range("F19").Value = "" Then
MsgBox "Fill in the number of persons attending the rental."
Exit Sub
If Sheets("Vue_Input").Range("F28").Value = "" Then
MsgBox "Fill in the movies or content used for the rental."
Exit Sub
If Sheets("Vue_Input").Range("C31").Value = "Yes" Then
If Sheets("Vue_Input").Range("F31").Value = "" Then
MsgBox "Fill in by who the F&B is arranged."
Exit Sub
If Sheets("Vue_Input").Range("B34").Value = "" Then
MsgBox "Fill in the arrangements made with the tenant."
Exit Sub
If Sheets("Vue_Input").Range("F36").Value = "" Then
MsgBox "Fill in the agreed price of the rental."
Exit Sub
Dim x
x = InputBoxDK("Fill in the required password.", "Password Required")
If x = "" Then End
If x <> Sheets("Data").Range("F60") Then
MsgBox "You didn't enter the correct password."
End
Sheets("Vue_Input").Select
ActiveSheet.Unprotect Password:="JTAMER"
ActiveWorkbook.Unprotect Password:="tj3rkie"
Sheets("All_Rentals").Visible = xlSheetVisible
Sheets("All_Rentals").Select
Sheets("All_Rentals").Range("A8").Select
Sheets("All_Rentals").Range("A8").Activate
Selection.EntireRow.Insert , CopyOrigin:=xlFormatFromLeftOrAbove
Range("B34").Select
Selection.Copy
Range("AA8").Select
Selection.PasteSpecial Paste:=xlPasteValues, Operation:=xlNone, SkipBlanks _
:=False, Transpose:=False
Range("C10").Select
Selection.Copy
Range("F8").Select
Range("C11").Select
Selection.Copy
Range("E8").Select
Range("C12").Select
Selection.Copy
Range("D8").Select
Range("C13").Select
Selection.Copy
Range("O8").Select
Range("C15").Select
Selection.Copy
Range("C8").Select
Range("C16").Select
Selection.Copy
Range("L8").Select
Range("C18").Select
Selection.Copy
Range("M8").Select
Range("C19").Select
Selection.Copy
Range("G8").Select
Range("C20").Select
Selection.Copy
Range("H8").Select
Range("C21").Select
Selection.Copy
Range("I8").Select
Range("C22").Select
Selection.Copy
Range("J8").Select
Range("C24").Select
Selection.Copy
Range("K8").Select
Range("C25").Select
Selection.Copy
Range("N8").Select
Range("C27").Select
Selection.Copy
Range("R8").Select
Range("C28").Select
Selection.Copy
Range("S8").Select
Range("C29").Select
Selection.Copy
Range("P8").Select
Range("C31").Select
Selection.Copy
Range("W8").Select
Range("F10").Select
Selection.Copy
Range("Y8").Select
Range("F13").Select
Selection.Copy
Range("Z8").Select
Range("F16").Select
Selection.Copy
Range("B8").Select
Range("F18").Select
Selection.Copy
Range("V8").Select
Range("F19").Select
Selection.Copy
Range("U8").Select
Range("F27").Select
Selection.Copy
Range("T8").Select
Range("F28").Select
Selection.Copy
Range("Q8").Select
Range("F31").Select
Selection.Copy
Range("X8").Select
Range("F36").Select
Selection.Copy
Range("AB8").Select
Range("B7:AG2506").Select
Application.AddCustomList ListArray:=Array("Definitive", "Optional", _
"Cancelled")
ActiveWorkbook.Worksheets("All_Rentals").Sort.SortFields.Clear
ActiveWorkbook.Worksheets("All_Rentals").Sort.SortFields.Add Key:=Range( _
"D7:D2506"), SortOn:=xlSortOnValues, Order:=xlAscending, DataOption:= _
xlSortNormal
"V7:V2506"), SortOn:=xlSortOnValues, Order:=xlAscending, CustomOrder:= _
"Definitive,Optional,Cancelled", DataOption:=xlSortNormal
"L7:L2506"), SortOn:=xlSortOnValues, Order:=xlDescending, DataOption:= _
xlSortNormal
With ActiveWorkbook.Worksheets("All_Rentals").Sort
.SetRange Range("B6:AG2506")
.Header = xlYes
.MatchCase = False
.Orientation = xlTopToBottom
.SortMethod = xlPinYin
.Apply
Rows("2507:2507").Select
Selection.Delete Shift:=xlUp
Range("B34,C11:C12,C16,C18:C22,C24:C25,C27:C29,C31,F16,F18:F19,F29,F31,F36").Select
Selection.ClearContents
ActiveSheet.Protect Password:="JTAMER", DrawingObjects:=True, Contents:=True, Scenarios:=True _
, AllowFiltering:=True
ActiveSheet.EnableSelection = xlNoSelection
Sheets("All_Rentals").Visible = xlVeryHidden
ActiveWorkbook.Protect Password:="tj3rkie"
ActiveWorkbook.Save
Range("C11").Select
