SjonR
Verenigingslid
- 10 nov 2016
- Office versie
- 2016/365
Goedemorgen,
Ik heb een userform waar bedragen moeten worden ingevuld. Bijvoorbeeld tb30. Nu worden deze bedragen als tekst weggeschreven in mijn werkblad en daardoor neemt het blad het bedrag niet mee in de berekening.
Wat doe ik fout?
Wat doe ik fout?
Private Sub CommandButton2_Click()
If Me.ob22.Value = True Then Blad1.Range("D2").Value = tb30.Value
If Me.ob9.Value = True Then Blad1.Range("E2").Value = tb30.Value
If Me.OptionButton21.Value = True Then Blad1.Range("D3").Value = TextBox24.Value
If Me.OptionButton11.Value = True Then Blad1.Range("E3").Value = TextBox24.Value
If Me.OptionButton20.Value = True Then Blad1.Range("D4").Value = TextBox27.Value
If Me.OptionButton13.Value = True Then Blad1.Range("E4").Value = TextBox27.Value
If Me.OptionButton19.Value = True Then Blad1.Range("D5").Value = TextBox28.Value
If Me.OptionButton15.Value = True Then Blad1.Range("E5").Value = TextBox28.Value
If Me.OB1.Value = True Then Blad1.Range("a2").Value = 1
If Me.OB2.Value = True Then Blad1.Range("a2").Value = 2
If Me.OptionButton3.Value = True Then Blad1.Range("a2").Value = 3
If Me.OptionButton4.Value = True Then Blad1.Range("a2").Value = 4
If Me.OB3.Value = True Then Blad1.Range("a2").Value = 5
If Me.OB4.Value = True Then Blad1.Range("b3").Value = 0
If Me.OB5.Value = True Then Blad1.Range("b3").Value = 1
Blad1.Range("b2").Value = TB7.Value
Blad1.Range("f2").Value = tb44.Value
Blad1.Range("f3").Value = tb46.Value
Blad1.Range("f4").Value = tb50.Value
Blad1.Range("g2").Value = tb61.Value
Blad1.Range("f10").Value = TextBox7.Value
Blad1.Range("F11").Value = TextBox9.Value
Blad1.Range("F12").Value = TextBox13.Value
Blad1.Range("F13").Value = TextBox14.Value
Blad1.Range("F14").Value = TextBox40.Value
If Me.CheckBox6.Value = True Then Blad1.Range("b11").Value = 1
If Me.CheckBox5.Value = True Then Blad1.Range("c11").Value = 1
If Me.CheckBox4.Value = True Then Blad1.Range("b12").Value = 1
If Me.CheckBox3.Value = True Then Blad1.Range("c12").Value = 1
If Me.CheckBox1.Value = True Then Blad1.Range("b13").Value = 1
If Me.CheckBox2.Value = True Then Blad1.Range("c13").Value = 1
If Me.CheckBox14.Value = True Then Blad1.Range("b14").Value = 1
If Me.CheckBox13.Value = True Then Blad1.Range("c14").Value = 1
Blad1.Range("L10").Value = TB16.Value
Blad1.Range("L11").Value = TextBox17.Value
Blad1.Range("L12").Value = TextBox20.Value
Blad1.Range("L13").Value = TextBox21.Value
If Me.CheckBox11.Value = True Then Blad1.Range("i11").Value = 1
If Me.CheckBox9.Value = True Then Blad1.Range("i12").Value = 1
If Me.CheckBox7.Value = True Then Blad1.Range("i13").Value = 1
If Me.OptionButton1.Value = True Then Blad1.Range("a6").Value = 0
If Me.OptionButton2.Value = True Then Blad1.Range("a6").Value = 1
TextBox43.Value = Blad1.Range("h28").Value
TextBox36.Value = Blad1.Range("d36").Value
TextBox37.Value = Blad1.Range("d37").Value
TextBox39.Value = Blad1.Range("e36").Value
TextBox38.Value = Blad1.Range("e37").Value
Frame6.Visible = True
Frame8.Visible = True
If Me.OB2.Value = True Then Frame7.Visible = True
If Me.OptionButton4.Value = True Then Frame7.Visible = True
If Me.OptionButton1.Value = True Then MsgBox "Partner kan mogelijk een voorlopige teruggave IB krijgen"
