[help] slidebar
slabbetje
5 mei 2007
weet iemand hoe ik het beste een slide bar kan maken?
dus zon balkje die de value van een txt-vak veranderd door simpel weg het puntje/pijltje te slepen?
zoiets?
PHP:
<html><body>
function showSbarVal(){
p=document.getElementById('sbar')
alert(p.scrollTop)
</script>
<div id="sbar" style="width:20px;height:100px;overflow:auto" onmouseleave="showSbarVal()">
<img width="1" height="400" alt="" />
</div><body></html>
ja zoiets maar ik had al een script gevonden..
moet alleen nu nog de valuta in een txt field zetten en hij werkt :thumb:
var Slider = new Class({
	options: {
		onChange: Class.empty,
		onComplete: Class.empty,
		onTick: function(pos){
			this.knob.setStyle(this.p, pos);
		mode: 'horizontal',
		steps: 10,
		offset: 0
	initialize: function(el, knob, options){
		this.element = $(el);
		this.knob = $(knob);
		this.setOptions(options);
		this.previousChange = -1;
		this.previousEnd = -1;
		this.step = -1;
		this.element.addEvent('mousedown', this.clickedElement.bindWithEvent(this));
		var mod, offset;
		switch(this.options.mode){
			case 'horizontal':
				this.z = 'x';
				this.p = 'left';
				mod = {'x': 'left', 'y': false};
				offset = 'offsetWidth';
				break;
			case 'vertical':
				this.z = 'y';
				this.p = 'top';
				mod = {'x': false, 'y': 'top'};
				offset = 'offsetHeight';
		this.max = this.element[offset] - this.knob[offset] + (this.options.offset * 2);
		this.half = this.knob[offset]/2;
		this.getPos = this.element['get' + this.p.capitalize()].bind(this.element);
		this.knob.setStyle('position', 'relative').setStyle(this.p, - this.options.offset);
		var lim = {};
		lim[this.z] = [- this.options.offset, this.max - this.options.offset];
		this.drag = new Drag.Base(this.knob, {
			limit: lim,
			modifiers: mod,
			snap: 0,
			onStart: function(){
				this.draggedKnob();
			}.bind(this),
			onDrag: function(){
				this.draggedKnob();
			}.bind(this),
			onComplete: function(){
				this.draggedKnob();
				this.end();
			}.bind(this)
		if (this.options.initialize) this.options.initialize.call(this);
	set: function(step){
		this.step = step.limit(0, this.options.steps);
		this.checkStep();
		this.end();
		this.fireEvent('onTick', this.toPosition(this.step));
		return this;
	setDefault: function(step){
		if (step > this.options.steps) step = this.options.steps;
		else if (step < 0) step = 0;
		this.step = step;
		this.checkStep();
		this.end();
		this.knob.setStyle(this.p, this.toPosition(this.step)+'px');
		return this;
	scrolledElement: function(event){
		if (event.wheel < 0) this.set(this.step + 1);
		else if (event.wheel > 0) this.set(this.step - 1);
		event.stop();
	clickedElement: function(event){
		var position = event.page[this.z] - this.getPos() - this.half;
		position = position.limit(-this.options.offset, this.max -this.options.offset);
		this.step = this.toStep(position);
		this.checkStep();
		this.end();
		//this.fireEvent('onTick', position);
		this.set(this.step);
	draggedKnob: function(){
		this.step = this.toStep(this.drag.value.now[this.z]);
		this.checkStep();
		this.setDefault(this.step);
	checkStep: function(){
		if (this.previousChange != this.step){
			this.previousChange = this.step;
			this.fireEvent('onChange', this.step);
	end: function(){
		if (this.previousEnd !== this.step){
			this.previousEnd = this.step;
			this.fireEvent('onComplete', this.step + '');
	toStep: function(position){
		return Math.round((position + this.options.offset) / this.max * this.options.steps);
	toPosition: function(step){
		return this.max * step / this.options.steps;
Slider.implement(new Events);
Slider.implement(new Options);
			window.addEvent('domready', function(){
				var slider1 = new Slider('slideContainer1', 'slideHandle1',{onComplete: function(val){$('pos1').setHTML(val);}});
		</script>
edit: hoe kan ik die div value naar een txt vak doorsturen zodat ik het in een query kan verwerken?
Edit2: Mijn probleem is opgelost bedankt helpers!
