Click Start, point to Settings, click Control Panel, and then double-click Display.
On the Settings tab, click Advanced, and then click Change on the Adapter tab.
Click Next, click Display a list of all the drivers in a specific location, so you can select the driver you want, and then click Next.
Click Show All Devices, and then click (Standard Display Types) in the Manufacturers box.
In the Models box, click Standard Display Adapter (VGA), click OK, and then click Next.
Click Next, click Next again, and then click Finish.
Click Close, click Close again, and then click Yes to restart your computer.
Sorry, fout zit volgens M$ niet in explorer, maar in de drivers van je videokaart.
instaleer de nieuwste drivers die voor jouw videokaart zijn
suc6
Oossie
