hoe laat ik div vullen, pas als script loop klaar is
phobia
4 sep 2006
ik heb een script, maar ik wil dat de div pas gevuld word als het script klaar is.
dit is wat ik gebruik
<HTML>
<HEAD>
 <TITLE>Div's leren besturen JAVA</TITLE>
 <style type="text/css">
.div {
		filter: alpha(opacity=70); // IE syntax
			-moz-opacity: .70; // Mozilla
			opacity: .70; // De rest;
		text-align: center;
		color: white;
.style10 {
	background-color: #FFFFFF;
	font-family: "Agent Orange";
.style11 {
	text-align: center;
</style>
function getXMLHTTP() { //fuction to return the xml http object
    var xmlhttp=false;
    try {
        xmlhttp=new XMLHttpRequest();
    } catch(e) {
        try {
            xmlhttp= new ActiveXObject("Microsoft.XMLHTTP");
        } catch(e) {
            try{
                xmlhttp = new ActiveXObject("Msxml2.XMLHTTP");
            } catch(e1) {
                xmlhttp=false;
    return xmlhttp;
function link(strURL) {
  var req = getXMLHTTP(); // fuction to get xmlhttp object
  if (req) {
    req.onreadystatechange = function() {
      if (req.readyState == 4) { //data is retrieved from server
        if (req.status == 200) { // which reprents ok status
          document.getElementById('id').innerHTML=req.responseText;
        } else {
          alert("There was a problem while using XMLHTTP:\n");
    req.open("GET", strURL, true); //open url using get method
    req.send(null);
function toggle(id,x,y)
// ---- hoogte en breedte
var ie=document.all && !window.opera //
var iebody=(document.compatMode=="CSS1Compat")? document.documentElement : document.body
var x =(ie)? iebody.clientWidth : window.innerWidth // ----scherm breedte
var y=(ie)? iebody.clientHeight : window.innerHeight // ----scherm hoogte
x
   var obj = document.getElementById(id);
   if(obj.style.visibility == 'visible')
      toggleObject(obj, true,x-3,y-3);
   }else{
      toggleObject(obj, false,x-3,y-3);
var inc = 10;
function toggleObject(obj,close,x,y)
   var w, h, go;
   w  = parseInt(obj.style.width);
   h  = parseInt(obj.style.height);
   go = false;
   if(close === false)
      obj.style.visibility = 'visible';
      if(w < x)
         obj.style.width = w + inc + 'px';
         go = true;
      if(h < y)
         obj.style.height = h + inc + 'px';
         go = true;
   }else{
		obj.innerHTML = "";
      if(w > 0)
         obj.style.width = w - inc + 'px';
         go = true;
      if(h > 0)
         obj.style.height = h - inc + 'px';
         go = true;
   if(go === true)
      var f = function(){ toggleObject(obj, close,x,y); }
      setTimeout(f, 5);
   }else{
      if(close === true)
         obj.style.visibility = 'hidden';
</script>
</HEAD>
<BODY>
<h1>Div sturen leren</h1>
<form id="form" >
			<input id="x" type="text" value= "test">
	   		<input type="button" value="Show DIV" onclick="toggle('id','600','150');link('test5.php');">
</form>
<div class="div" style="position: absolute;  visibility: hidden; background-color: black; width: 0px; height: 0px; z-index: 1; left: 0px; top: 0px;" id="id">
</div>
<p>jfsakf;ajsf;jg;asf</p>
<p>&nbsp;</p>
<p>asdfhgasfgkasdv.sdv.c.sa</p>
</BODY>
</HTML>
Haal de aanroep naar link() uit de onclick en zet die aan het einde van de toggle-functie.
ik heb dit aan het einde van de toggle op gezet. want zonder dit wordt de div na de eerste loop al gevuld
	  if( x == w)
	  link('test5.php');
