kan niet meer branden NEC-ND-2510A
anthony68
3 aug 2006
Ik heb altijd goed kunnen branden alles mappen en iso. Maar na install pinnacle instant dvd kan ik nieer branden. Ik heb mijn backup terug gezet maar dat helpt ook niet nero zegt disk at once error en alcohol zegt image error. zie hier logs;
Wie kan helpen...
nero;
anthony
prive
1A20-0223-0000-1285-6030-9273*
1A25-0806-7130-1280-1945-2242
Windows XP 5.1
IA32
WinAspi: File 'Wnaspi32.dll': Ver=4.57 (1008), size=48128 bytes, created 23-12-1997 2:00:00
ahead WinASPI: File 'C:\Program Files\Ahead\Nero\Wnaspi32.dll': Ver=2.0.1.59, size=160016 bytes, created 16-12-2003 19:18:06
Nero version: 6.3.0.2
Recorder: <_NEC DVD_RW ND-2510A> Version: 2.15 - HA 1 TA 0 - 6.3.0.2
Adapter driver: <atapi> HA 1
Drive buffer : 2048kB
Bus Type : via Inquiry data (1) -> ATAPI, detected: ATAPI
Connected to MMC as unknown drive with class-nr : 1
Drive is autodetected - recorder class: Std. MMC recorder
CD-ROM: <_NEC DVD_RW ND-2510A >Version: 2.15 - HA 1 TA 0 - 6.3.0.2
=== Scsi-Device-Map ===
DiskPeripheral : IBM-DJNA-371350 atapi Port 0 ID 0 DMA: On
DiskPeripheral : HDS722525VLAT80 atapi Port 0 ID 1 DMA: On
CdRomPeripheral : _NEC DVD_RW ND-2510A atapi Port 1 ID 0 DMA: On
CdRomPeripheral : AXV CD/DVD-ROM 2.2a a347scsi Port 2 ID 0 DMA: Off
CdRomPeripheral : AXV CD/DVD-ROM 2.1b axvodka Port 4 ID 0 DMA: Off
=== CDRom-Device-Map ===
_NEC DVD_RW ND-2510A L: CDRom0
AXV CD/DVD-ROM J: CDRom1
AXV CD/DVD-ROM N: CDRom2
AutoRun : 1
Excluded drive IDs:
CmdQueuing : 1
CmdNotification: 2
WriteBufferSize: 83886080 (0) Byte
ShowDrvBufStat : 0
EraseSpeed : 0
BUFE : 0
Physical memory : 1023MB (1047788kB)
Free physical memory: 350MB (359316kB)
Memory in use : 65 %
Uncached PFiles: 0x0
Use Static Write Speed Table: 0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
26.3.2007
Burn DVD Image
15:56:23 #1 Text 0 File Reader.cpp, Line 118
Reader running
15:56:23 #2 Text 0 File Writer.cpp, Line 124
Writer _NEC DVD_RW ND-2510A running
15:56:24 #3 IMAGEGEN -10 File ImageGen.cpp, Line 366
Image was written as DAO.
DAOI:
MediaCatalogNumber = ''
TocType = 0x00
Finalized = 1
First/Last Track = 1 / 1
1: ISRC = ''
Blocksize = 2048
TrackMode = 'TRM_DATA_MODE1'
TrackConfig = 0x00
First/Last Index = 0 / 1
Index0FilePos = 0, Index1FilePos = 0, NextTrackFilePos = -699990016
CUES:
0: Ctrl=0x41 Trk= 0 (0x00) Index=00 RecDep=0x00 Start=00:00.00 ( 0)
1: Ctrl=0x41 Trk= 1 (0x01) Index=00 RecDep=0x00 Start=00:00.00 ( 0)
2: Ctrl=0x41 Trk= 1 (0x01) Index=01 RecDep=0x00 Start=00:00.00 ( 0)
3: Ctrl=0x41 Trk=110 (0xAA) Index=01 RecDep=0x00 Start=390:04.60 ( 1755360)
MTYP: Mediumtype = DVD (old format) (0x1C)
Image file name: <D:\mydoc\nero\prince.nrg>
15:56:25 #4 Text 0 File Burncd.cpp, Line 3101
Turn on Disc-at-once, using DVD media
15:56:26 #5 Text 0 File DlgWaitCD.cpp, Line 240
Last possible write address on media: 2298495 (510:46.45, 4489MB)
Last address to be written: 1755209 (390:02.59, 3428MB)
15:56:26 #6 Text 0 File DlgWaitCD.cpp, Line 245
Write in overburning mode: FALSE
15:56:26 #7 Text 0 File DlgWaitCD.cpp, Line 2085
Recorder: _NEC DVD_RW ND-2510A, Media type: DVD-R
Disc Manufacturer: SONY16 - D1
Disc Application Code: 64, Disc Physical Code: 193
15:56:26 #8 Text 0 File DlgWaitCD.cpp, Line 406
>>> Protocol of DlgWaitCD activities: <<<
15:56:26 #9 Text 0 File ThreadedTransferInterface.cpp, Line 779
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 (1 - DVD-ROM)
2 indices, index0 (0) not provided
original disc pos #0 + 1755360 (1755360) = #1755360/390:4.60
not relocatable, disc pos for caching/writing not required/not required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 1755360 blocks [_NEC DVD_RW ND-2510A ]
15:56:26 #10 Text 0 File ThreadedTransferInterface.cpp, Line 948
Prepare recorder [_NEC DVD_RW ND-2510A ] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 3594977280, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_RecDep_|_CtrlAdr_
0 | lead-in | 0 | 0x00 | 0x41
0 | 1 | 0 | 0x00 | 0x41
0 | 1 | 1 | 0x00 | 0x41
1755360 | lead-out | 1 | 0x00 | 0x41
15:56:26 #11 Phase 28 File dlgbrnst.cpp, Line 1800
Speed measurement started
15:56:26 #12 Text 0 File ThreadedTransferInterface.cpp, Line 2264
Verifying disc position of item 0 (not relocatable, no disc pos, no patch infos, orig at #0): write at #0
15:57:48 #13 Text 0 File WriterStatus.cpp, Line 115
<_NEC DVD_RW ND-2510A > start writing Lead-Out at LBA 1755360 (1AC8E0h), lenght 0 blocks
15:57:48 #14 Text 0 File ThreadedTransfer.cpp, Line 229
all writers idle, stopping conversion
15:57:48 #15 Text 0 File dlgbrnst.cpp, Line 1658
Set remaining time: 0:00,000 (0ms) -> OK
15:57:48 #16 Phase 29 File dlgbrnst.cpp, Line 1751
Speed measurement completed: 31.7x (43.874 KB/s)
15:57:48 #17 Phase 36 File dlgbrnst.cpp, Line 1800
Burn process started at 2.4x (3.312 KB/s)
15:57:48 #18 Text 0 File ThreadedTransferInterface.cpp, Line 2264
15:57:48 #19 Text 0 File dlgbrnst.cpp, Line 1658
Set remaining time: 10:58,666 (658666ms) -> OK
15:57:48 #20 Text 0 File DVDR.cpp, Line 1512
Recording mode: Sequential Recording Mode
15:57:48 #21 Text 0 File Mmc.cpp, Line 19451
Set BUFE: JustLink -> ON
15:57:48 #22 Text 0 File DVDR.cpp, Line 1643
Start write address at LBA 0
DVD high compatibility mode: Yes
15:57:48 #23 Text 0 File Cdrdrv.cpp, Line 7941
---- DVD Structure: Physical Format Information (00h) ----
Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD-R (2), Part Version: 5
Disc Size: 120 mm, Maximum Rate: <not specified> (F h)
Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
End Physical Sector Number of Data Area: 26127F h
End Sector Number in Layer 0: 0 h
Data in Burst Cutting Area (BCA) does not exist
Media Specific:
60 00 10 20 30 40 50 00 - 00 00 21 00 00 00 00 00 `...0@P...!.....
02 FE 10 00 02 FF A0 00 - 00 00 00 00 00 00 00 00 ................
00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
15:57:48 #24 SCSI -1046 File Cdrdrv.cpp, Line 1171
SCSI Exec, HA 1, TA 0, LUN 0
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
Sense Code: 0x30
Sense Qual: 0x05
CDB Data: 0x53 0x00 0x00 0x00 0x00 0x00 0x1A 0xC8 0xE0 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x05 0x00 0x00 0x00 0x00 0x0A
0x00 0x00 0x00 0x00 0x30 0x05
15:57:48 #25 CDR -1046 File ThreadedTransferInterface.cpp, Line 1573
Illegal disc
15:57:48 #26 TRANSFER -27 File ThreadedTransferInterface.cpp, Line 1573
Could not perform start of Disc-at-once
15:57:48 #27 Text 0 File dlgbrnst.cpp, Line 1658
15:57:49 #28 Phase 38 File dlgbrnst.cpp, Line 1800
Burn process failed at 2.4x (3.312 KB/s)
Existing drivers:
File 'Drivers\CDRALW2K.SYS': Ver=8.0.0.212 , size=2560 bytes, created 25-8-2006 5:47:00
File 'Drivers\ASPI32.SYS': Ver=4.57 (1008), size=23936 bytes, created 23-12-1997 2:00:00
File 'Drivers\PXHELP20.SYS': Ver=3.00.41a, size=36560 bytes, created 27-9-2006 23:53:22 (Prassi/Veritas driver for win 2K)
File 'Drivers\atapi.sys': Ver=?.?.?.?, size=95360 bytes, created 3-8-2004 22:59:44 (Adapter driver for rec)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
Alcohol
log;
########################### System Information ###########################
Windows XP Professional 5.1 Service Pack 2 (Build 2600)
Processor info: Intel(R) Pentium(R) 4 CPU 3.00GHz x 2 (3007MHz)
Memory Available to Windows: 1.047.788 KB
############################ Program Information ###########################
File Name: D:\Program Files\Alcohol Soft\Alcohol 120\Alcohol.exe
Company Name: Alcohol Soft Development Team
Description: Alcohol 120%
Original: alcohol.exe
Product: Alcohol 120%
Trademarks: Alcohol Soft Development Team
Copyright: Copyright(C) 2002-2004 Alcohol Soft Development Team
Version: 1.9.2 ( Build 1705 )
Date: 2004/05/06
Hash: 7e9552025078b455c4c3d666f57dd414
Hash(1): d1a7659659473ef648eb5a05e23b291c5580f355673fdab02d81ff332d01c5
Hash(2): 5e3cbc5c0e68bc7c14704ffb3f53bad933f799e64ef3f900475aa845b2cb00
File Name: D:\Program Files\Alcohol Soft\Alcohol 120\alcoholx.dll
Description: Alcohol virtual device control library
Original: alcoholx.dll
Copyright: Copyright (C) 2000-2004
Version: 3.47.0 ( Build 0 )
Date: 2004/04/30
Hash: c11b59c21722ca30141696c21b72578d
File Name: D:\Program Files\Alcohol Soft\Alcohol 120\devsupp.dll
Description: Alcohol Software Device Capability Library
Original: devsupp.dll
Product: Alcohol Software Device Capability Library
Copyright: Copyright(C) 2002-2003 Alcohol Soft Development Team
Version: 2.3.7 ( Build 505 )
Date: 2004/05/05
Hash: 0e6f733d3f570f3b0328261d11a2794e
########################### User Information ###########################
User Name: anthony
Company Name: prive
Registered User ID: 61DB
########################### Options Setting ###########################
Devices control interface: Default Driver Control Interface
CPU Priority Level: High
Memory Buffer Size (MB): 128
Examine the accuracy of data read from physical device: Yes
Turn off "Auto-Select best write speed" function if possible: No
Overburn disc(s): No
Fill memory buffer before recording discs: Yes
Ignore Media Type: Yes
RMPS (Recordable Media Physical Signature) Emulation: No
BAD Sectors Emulation: No
Sub-Channel Data Fixed & Emulation: No
Laserlock Emulation: No
Current Language: Dutch
############################ Device(s) List ############################
(L:) _NEC DVD_RW ND-2510A (atapi, Port 1, Bus 0, Target 0, Lun 0)
(J:) AXV CD/DVD-ROM (a347scsi, Port 2, Bus 0, Target 0, Lun 0)
(N:) AXV CD/DVD-ROM (axvodka, Port 4, Bus 0, Target 0, Lun 0)
##################### Installed Device Drivers List #####################
a347bus.sys a347scsi.sys ACPI.sys aeaudio.sys afd.sys
agp440.sys ASAPIW2k.sys ASPI32.SYS ATMFD.DLL audstub.sys
AvgAsCln.sys axvdkbus.sys axvodka.sys Beep.SYS BOOTVID.dll
Cdfs.SYS cdrom.sys CLASSPNP.SYS cmaudio.sys disk.sys
dmboot.sys dmio.sys dmload.sys dptrackerd.sys drmk.sys
Dxapi.sys dxg.sys dxgthk.sys EIO.sys ElbyCDFL.sys
ElbyCDIO.sys ElbyDelay.sys fdc.sys Fips.SYS flpydisk.sys
fltmgr.sys Fs_Rec.SYS ftdisk.sys fwdrv.sys gameenum.sys
hal.dll HPZid412.sys HPZipr12.sys HPZius12.sys HTTP.sys
i8042prt.sys ikhfile.sys ikhlayer.sys imagesrv.sys imapi.sys
InCDFs.sys InCDrec.SYS InCDRm.sys intelppm.sys ipfltdrv.sys
ipnat.sys ipsec.sys isapnp.sys kbdclass.sys KDCOM.DLL
khips.sys kmixer.sys ks.sys KSecDD.sys L8042Kbd.sys
L8042mou.Sys LMouKE.Sys MarxDev1.SYS MarxDev2.SYS MarxDev3.SYS
mbmiodrvr.sys mc21.tmp mmrtkrnl.sys mnmdd.SYS mouclass.sys
MountMgr.sys MpFirewall.sys mrxdav.sys mrxsmb.sys Msfs.SYS
msgpc.sys mssmbios.sys Mup.sys MxlW2k.SYS naiavf5x.sys
NDIS.sys ndistapi.sys ndiswan.sys NDProxy.SYS netbios.sys
netbt.sys Npfs.SYS ntdll.dll Ntfs.sys ntoskrnl.exe
Null.SYS nv4_disp.dll nv4_mini.sys parport.sys PartMgr.sys
ParVdm.SYS pci.sys pciide.sys PCIIDEX.SYS Pcouffin.sys
pfc.sys portcls.sys psched.sys ptilink.sys PxHelp20.sys
R8139n51.SYS rasacd.sys rasl2tp.sys raspppoe.sys raspptp.sys
raspti.sys rdbss.sys RDPCDD.sys rdpdr.sys redbook.sys
rob_v.sys SCSIPORT.SYS secdrv.sys serenum.sys serial.sys
smwdm.sys snapman.sys sr.sys srv.sys STREAM.SYS
STV680.sys swenum.sys sysaudio.sys tcpip.sys TDI.SYS
termdd.sys tifsfilt.sys timntr.sys update.sys usbccgp.sys
USBD.SYS usbehci.sys usbhub.sys USBPORT.SYS usbprint.sys
usbscan.sys USBSTOR.SYS usbuhci.sys vga.sys VIDEOPRT.SYS
VolSnap.sys wanarp.sys watchdog.sys wdmaud.sys win32k.sys
WMILIB.SYS ws2ifsl.sys yukonwxp.sys
################## Detailed Information of Device(s) ##################
(L:) _NEC DVD_RW ND-2510A(1:0) detail information.
Vendor Identification: _NEC
Product Identification: DVD_RW ND-2510A
Production Revision Level: 2.15
Support recording method: DAO, RAW DAO(96), TAO, DVD DAO
BURN-Free Technology: BURN-Proof
Auto-Select best write speed: Not Supported
-* Note: This information below is provided by the unit, it might be inaccurate. *-
-* This software does not use this information! *-
Removable media: Yes
Version: ATAPI (INF-8090i/INF-8020i/INF-8028i)
Response Data Format: 02h
CD-R Read/Write: Yes/Yes
CD-RW Read/Write: Yes/Yes
Read CD-R Fixed Packet: Yes
Test Write: Yes
DVD-ROM Read: Yes
DVD-R Read/Write: Yes/Yes
DVD-RAM Read/Write: No/No
Audio Play: Yes
Composite Audio and Video Data Stream: No
Digital output (IEC958) on port 1 Supported: No
Digital output (IEC958) on port 2 Supported: No
Mode 1 Form 2: Yes
Mode 2 Form 2: Yes
Multi-Session: Yes
BUF: Yes
CD-DA Commands supported: Yes
CD-DA Stream is Accurate: Yes
R-W Supported: Yes
R-W De-interleaved and Corrected: No
C2 Pointers Support: Yes
ISRC Supported: Yes
UPC Supported: Yes
Read Bar Code: No
Lock media into the drive: Yes
Currently drive Lock state: Unlocked
Prevent Jumper: No
Eject Command: Yes
Separate volume levels: Yes
Separate channel mute: Yes
Changer Supports Disc Present: No
Software slot selection: No
Side change capable: No
P through W in Lead-In: Yes
Maximum Read Speed Supported (with current disc): 40X (6000 KB/Sec)
Maximum Write Speed Supported (with current Disc): 32X (4800 KB/Sec)
Current Read Speed Supported (with current Disc): 40X (6000 KB/Sec)
Current Write Speed Supported (with current Disc): 32X (4800 KB/Sec)
(N:) AXV CD/DVD-ROM(4:0) detail information.
Vendor Identification: AXV
Product Identification: CD/DVD-ROM
Production Revision Level: 2.1b
Version: ANSI X3.131:1994 (SCSI-2)
CD-R Read/Write: Yes/No
CD-RW Read/Write: Yes/No
Test Write: No
DVD-ROM Read: Yes
DVD-R Read/Write: Yes/No
DVD-RAM Read/Write: Yes/No
Audio Play: Yes
Digital output (IEC958) on port 1 Supported: Yes
Mode 1 Form 2: Yes
Mode 2 Form 2: Yes
Multi-Session: Yes
BUF: No
R-W Supported: Yes
R-W De-interleaved and Corrected: Yes
ISRC Supported: Yes
UPC Supported: Yes
Read Bar Code: No
Prevent Jumper: No
Eject Command: Yes
Separate volume levels: No
Separate channel mute: No
P through W in Lead-In: No
Maximum Read Speed Supported (with current disc): 32X (4800 KB/Sec)
Current Read Speed Supported (with current Disc): 32X (4800 KB/Sec)
###################### Source Disc/Image Information ######################
Type: Nero image-bestand
Lokatie: D:\mydoc\nero\
Naam: prince.nrg
Grootte: 3428.44 MB
Sessie: 1
Track: 1
Sessie 01:
Track 01: DVD, Lengte: 1755360(3.35 GB), Adres: 000000
####################### Dumping/Recording Progress Log #######################
16:05:51 Processor info : Intel(R) Pentium(R) 4 CPU 3.00GHz x 2 (3006MHz)
16:05:51 Hoeveelheid geheugen beschikbaar voor Windows: 1.047.788 KB
16:05:51 Geheugen Buffer gebruik: 128 MB
16:05:51 Image-bestand bezig met laden: D:\mydoc\nero\prince.nrg
16:05:51 DVD Source Info : Sessie: 1, Track: 1, Lengte: 3.35 GB / 390:04:60
16:05:51 (L:) _NEC DVD_RW ND-2510A(1:0): Brand methode/snelheid
16:05:51 Branden - DVD DAO - 4.0X (5520 KB/Sec)
16:05:51 (L:) _NEC DVD_RW ND-2510A(1:0): Branden mislukt!
16:05:51 Fout bericht : [05/30/05] - Cannot Write Medium - Incompatible Format
16:05:51 Image-bestand laden geannuleerd!
16:05:53 Er is iets mis met de brand-procedure!
Bekijk de log-bestand en vertel de Technical Support over de fouten die erin staan.
Waarom gooi je Pinnacle er niet af en stap over op Nero?
Zet de schrijfsnelheid lager dat wil vaak helpen.
