hallo allemaal,
heb nu een andere melding van nero tijdens het branden gekregen:
1A22-0223-0130-1468-9939-1861*
Windows XP 5.1
IA32
WinAspi: -
ahead WinASPI: File 'C:\Program Files\Ahead\nero\Wnaspi32.dll': Ver=2.0.1.59, size=160016 bytes, created 17-6-2003 15:25:03
Nero-versie: 6.0.0.28 (Nero Express)
Recorder: <_NEC DVD_RW ND-2500A> Versie: 1.06 - HA 0 TA 1 - 6.0.0.28
Adapter-stuurprogramma:<atapi> HA 0
Drive buffer : 2048kB
Bus Type : default (0) -> ATAPI, detected: ATAPI
CD-ROM: <TSSTcorp DVD-ROM TS-H352A>Versie: TS03 - HA 0 TA 0 - 6.0.0.28
=== Scsi-Device-Map ===
CdRomPeripheral : TSSTcorp DVD-ROM TS-H352A atapi Port 0 ID 0 DMA: On
CdRomPeripheral : _NEC DVD_RW ND-2500A atapi Port 0 ID 1 DMA: On
DiskPeripheral : HDS722516VLSA80 atapi Port 3 ID 0 DMA: On
CdRomPeripheral : AXV CD/DVD-ROM 2.2a a347scsi Port 6 ID 0 DMA: Off
=== CDRom-Device-Map ===
TSSTcorp DVD-ROM TS-H352 F: CDRom0
_NEC DVD_RW ND-2500A G: CDRom4
AXV CD/DVD-ROM H: CDRom2
AutoRun : 1
Excluded drive IDs:
CmdQueuing : 1
CmdNotification: 2
WriteBufferSize: 83886080 (0) Byte
ShowDrvBufStat : 0
EraseSpeed : 0
BUFE : 0
Physical memory : 1023MB (1048048kB)
Free physical memory: 506MB (519152kB)
Memory in use : 50 %
Uncached PFiles: 0x0
Use Static Write Speed Table: 0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
1.5.2005
UDF/ISO-compilatie
14:56:44 #1 Phase 112 File dlgbrnst.cpp, Line 1800
Opnieuw toewijzen DVD-Videobestanden gestart
14:56:44 #2 Phase 114 File dlgbrnst.cpp, Line 1800
Opnieuw toewijzen DVD-Videobestanden voltooid (geen bestand gewijzigd)
14:56:44 #3 Text 0 File Isodoc.cpp, Line 6024
Iso document burn settings
Determine maximum speed : TRUE
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Multisession : FALSE
Burning mode : DAO
Mode : 1
ISO Level : 1 (Max. of 11 = 8 + 3 char)
Character set : ISO 9660
Joliet : TRUE
Allow pathdepth more than 8 directories : FALSE
Allow more than 255 characters in path : FALSE
Write ISO9660 ;1 file extensions : TRUE
14:56:44 #4 Phase 111 File dlgbrnst.cpp, Line 1800
DVD-Videobestanden gesorteerd
14:56:44 #5 Text 0 File Reader.cpp, Line 118
Reader running
14:56:44 #6 Text 0 File Writer.cpp, Line 124
Writer _NEC DVD_RW ND-2500A running
14:56:44 #7 ISO9660GEN -11 File geniso.cpp, Line 3882
First writeable address = 0 (0x00000000)
14:56:44 #8 ISO9660GEN -11 File geniso.cpp, Line 3882
14:56:44 #9 Text 0 File Burncd.cpp, Line 3128
Turn on Disc-at-once, using DVD media
14:56:45 #10 Text 0 File DlgWaitCD.cpp, Line 237
Last possible write address on media: 2295103 (510:01.28)
Last address to be written: 2286175 (508:02.25)
14:56:45 #11 Text 0 File DlgWaitCD.cpp, Line 242
Write in overburning mode: FALSE
14:56:45 #12 Text 0 File DlgWaitCD.cpp, Line 2043
Recorder: _NEC DVD_RW ND-2500A, Media type: DVD+R
14:56:45 #13 Text 0 File DlgWaitCD.cpp, Line 403
>>> Protocol of DlgWaitCD activities: <<<
14:56:45 #14 Text 0 File ThreadedTransferInterface.cpp, Line 775
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 (CTransferItem)
2 indices, index0 (150) not provided
original disc pos #0 + 2286176 (2286176) = #2286176/508:2.26
relocatable, disc pos for caching/writing not required/required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2286176 blocks [_NEC DVD_RW ND-2500A ]
14:56:45 #15 Text 0 File ThreadedTransferInterface.cpp, Line 944
Prepare recorder [_NEC DVD_RW ND-2500A ] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 4682088448, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_RecDep_|_CtrlAdr_
0 | lead-in | 0 | 0x00 | 0x41
0 | 1 | 0 | 0x00 | 0x41
0 | 1 | 1 | 0x00 | 0x41
2286176 | lead-out | 1 | 0x00 | 0x41
14:56:45 #16 Phase 24 File dlgbrnst.cpp, Line 1800
Begin met cache-opslag van bestanden
14:56:45 #17 Text 0 File Burncd.cpp, Line 4095
Cache writing successful.
14:56:45 #18 Phase 25 File dlgbrnst.cpp, Line 1800
Cache-opslag van bestanden voltooid
14:56:45 #19 Phase 28 File dlgbrnst.cpp, Line 1800
Begin snelheidsmeting
14:56:45 #20 Text 0 File ThreadedTransferInterface.cpp, Line 2167
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
14:58:36 #21 Text 0 File WriterStatus.cpp, Line 113
<_NEC DVD_RW ND-2500A > start writing Lead-Out at LBA 2286176 (22E260h), lenght 0 blocks
14:58:36 #22 Text 0 File ThreadedTransfer.cpp, Line 229
all writers idle, stopping conversion
14:58:37 #23 Text 0 File dlgbrnst.cpp, Line 1658
Set remaining time: 0:00,000 (0ms) -> OK
14:58:37 #24 Phase 29 File dlgbrnst.cpp, Line 1751
Snelheidsmeting voltooid: 30,1x (41.602 kB/sec)
14:58:37 #25 Phase 36 File dlgbrnst.cpp, Line 1800
Begin brandproces met 8x (11.040 kB/sec)
14:58:37 #26 Text 0 File ThreadedTransferInterface.cpp, Line 2167
14:58:37 #27 SCSI -1066 File Cdrdrv.cpp, Line 1170
SCSI Exec, HA 0, TA 1, LUN 0, buffer 0x036E6000
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
Sense Code: 0x24
Sense Qual: 0x00
CDB Data: 0xAD 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x08 0x04 0x00 0x00
Sense Data: 0x70 0x00 0x05 0x00 0x00 0x00 0x00 0x0A
0x00 0x00 0x00 0x00 0x24 0x00
14:58:37 #28 Text 0 File dlgbrnst.cpp, Line 1658
Set remaining time: 7:11,345 (431345ms) -> OK
14:58:37 #29 Text 0 File DVDPlusRW.cpp, Line 607
Start write address at LBA 0
DVD high compatibility mode: Yes
15:01:06 #30 SCSI -1135 File Cdrdrv.cpp, Line 1430
SCSI Exec, HA 0, TA 1, LUN 0, buffer 0x04B20000
Sense Key: 0x03 (KEY_MEDIUM_ERROR)
Sense Code: 0x0C
Sense Qual: 0x00
CDB Data: 0x2A 0x00 0x00 0x06 0x49 0xE0 0x00 0x00 0x20 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x03 0x00 0x00 0x00 0x00 0x0A
0x00 0x00 0x00 0x00 0x0C 0x00
15:01:06 #31 CDR -1135 File Writer.cpp, Line 301
Schrijffout
15:01:06 #32 Text 0 File ThreadedTransfer.cpp, Line 229
15:01:06 #33 Text 0 File ThreadedTransfer.cpp, Line 223
conversion idle, stopping reader
15:01:06 #34 SCSI -1135 File Cdrdrv.cpp, Line 1170
Sense Code: 0x0C
Sense Qual: 0x00
CDB Data: 0x5B 0x01 0x01 0x00 0x00 0x01 0x00 0x00 0x00 0x00 0x00 0x00
15:01:06 #35 SCSI -1176 File Cdrdrv.cpp, Line 1170
Sense Code: 0x72
Sense Qual: 0x03
CDB Data: 0x5B 0x01 0x05 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
0x00 0x00 0x00 0x00 0x72 0x03
15:01:06 #36 Phase 127 File dlgbrnst.cpp, Line 1800
Bezig met genereren dvd-borders met hoge compatibiliteit
15:01:06 #37 Text 0 File dlgbrnst.cpp, Line 1658
15:01:06 #38 CDR -1135 File WriterStatus.cpp, Line 162
Schrijffout
_NEC DVD_RW ND-2500A\H0 T1
15:01:06 #39 TRANSFER -24 File WriterStatus.cpp, Line 162
Kon einde van 'disc-at-once' niet uitvoeren
15:01:06 #40 Text 0 File dlgbrnst.cpp, Line 1658
15:01:06 #41 Phase 38 File dlgbrnst.cpp, Line 1800
Brandproces mislukt met 8x (11.040 kB/sec)
Existing drivers:
File 'Drivers\atapi.sys': Ver=?.?.?.?, size=95360 bytes, created 4-8-2004 14:00:00 (Adapter driver for rec)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
