Kan wp-admin niet laden
ohdude
15 jul 2007
Hallo allemaal,
Ik ben bezig met het overzetten van onze website, naar een andere provider.
Dit aangezien onze oude provider nog al langzaam is.
Nu heb ik eindelijk de hoofdsite online gekregen, echter krijg ik de melding als ik naar wp-admin ga dat deze niet goed door
Mijn domeinnaam is nooit veranderd
dit is mijn .htaccess bestand
# BEGIN WordPress
<IfModule mod_rewrite.c>
RewriteEngine On
RewriteBase /
RewriteRule ^index\.php$ - [L]
RewriteCond %{REQUEST_FILENAME} !-f
RewriteCond %{REQUEST_FILENAME} !-d
RewriteRule . /index.php [L]
</IfModule>
Bestanden
drwxr-x---   10 **username**   99               4096 Feb 10 10:39 .
drwx--x--x   20 **username**   **username**         4096 Feb 10 10:44 ..
-rwxr-xr-x    1 **username**   **username**          237 Feb 10 10:40 .htaccess
drwxrwxr-x    2 **username**   **username**         4096 Feb  9 16:32 cgi-bin
drwxrwxr-x    4 **username**   **username**         4096 Feb  9 16:32 costumer
-rw-r--r--    1 **username**   **username**          202 Feb 10 01:45 error_log
-rwxr-xr-x    1 **username**   **username**          418 Feb  9 18:03 index.php
drwxrwxr-x    2 **username**   **username**         4096 Feb  9 16:35 info
-rwxr-xr-x    1 **username**   **username**        19545 Feb  9 18:03 license.txt
drwxrwxr-x    2 **username**   **username**         4096 Feb  9 18:50 piwik
drwxrwxr-x    2 **username**   **username**         4096 Feb  9 18:50 piwik.realsociallife.com
-rwxr-xr-x    1 **username**   **username**         4951 Feb  9 18:03 wp-activate.php
drwxrwxr-x    9 **username**   **username**         4096 Feb  9 16:36 wp-admin
-rwxr-xr-x    1 **username**   **username**          271 Feb  9 18:03 wp-blog-header.php
-rwxr-xr-x    1 **username**   **username**         5008 Feb  9 18:03 wp-comments-post.php
-rwxr-xr-x    1 **username**   **username**         2726 Feb  9 18:03 wp-config-sample.php
-rwxr-xr-x    1 **username**   **username**         3381 Feb  9 18:29 wp-config.php
drwxrwxr-x    8 **username**   **username**         4096 Feb  9 16:37 wp-content
-rwxr-xr-x    1 **username**   **username**         2956 Feb  9 18:03 wp-cron.php
drwxrwxr-x   12 **username**   **username**         4096 Feb  9 18:26 wp-includes
-rwxr-xr-x    1 **username**   **username**         2380 Feb  9 18:03 wp-links-opml.php
-rwxr-xr-x    1 **username**   **username**         2714 Feb  9 18:03 wp-load.php
-rwxr-xr-x    1 **username**   **username**        33435 Feb  9 18:03 wp-login.php
-rwxr-xr-x    1 **username**   **username**         8252 Feb  9 18:03 wp-mail.php
-rwxr-xr-x    1 **username**   **username**        11115 Feb  9 18:03 wp-settings.php
-rwxr-xr-x    1 **username**   **username**        25152 Feb  9 18:03 wp-signup.php
-rwxr-xr-x    1 **username**   **username**         4035 Feb  9 18:03 wp-trackback.php
-rwxr-xr-x    1 **username**   **username**         3032 Feb  9 18:03 xmlrpc.php
hu leg uit je domein over verhuisd naar andere hoster of ligt het anders
want als het eerste geval is dan moet conectie database aanpassen
Ik heb eerst een export gemaakt uit Direct Admin (DA), waarna ik deze heb geinporteerd heb, op Cpanel (welk mijn nieuwe host gebruikt). Heb de rechte ingesteld, en de database functioneert (aangezien front site het wel doet).
Nou, dus website bestanden overgezet, rechten ingesteld.
oke maar conectie naar je database heb je die ook gemaakt anders heb toch een probleem
Ja, deze werkt gewoon. Want alle data van de frontpage wordt gewoon geladen
Er zijn een aantal linkjes die je op de backend moet aanpassen als je een Wordpress site verhuist.
Deze link zou je kunnen verder helpen.
