; USAGE: KeyboardLED(LEDvalue,"Cmd") ; LEDvalue: ScrollLock=1, NumLock=2, CapsLock=4 ; Cmd = on/off/switch
Sleep, 1 ; improve reliability of setting LED state sometimes
If (GetKeyState("Enter", "T"))
KeyboardLED(2,"off")
Else
KeyboardLED(2,"on")
Return
KeyboardLED(LEDvalue, Cmd) ; LEDvalue: ScrollLock=1, NumLock=2, CapsLock=4 ; Cmd = on/off/switch
Static h_device
If ! h_device ; initialise
device =\Device\KeyBoardClass0
SetUnicodeStr(fn,device)
h_device:=NtCreateFile(fn,0+0x00000100+0x00000080+0x00100000,1,1,0x00000040+0x00000020,0)
VarSetCapacity( output_actual, 4, 0 )
input_size = 4
VarSetCapacity( input, input_size, 0 )
If Cmd= switch ;switches every LED according to LEDvalue
KeyLED:= LEDvalue
If Cmd= on ;forces all choosen LED's to ON (LEDvalue= 0 ->LED's according to keystate)
KeyLED:= LEDvalue | (GetKeyState("ScrollLock", "T") + 2*GetKeyState("NumLock", "T") + 4*GetKeyState("CapsLock", "T"))
If Cmd= off ;forces all choosen LED's to OFF (LEDvalue= 0 ->LED's according to keystate)
LEDvalue:= LEDvalue ^ 7
KeyLED:= LEDvalue & (GetKeyState("ScrollLock", "T") + 2*GetKeyState("NumLock", "T") + 4*GetKeyState("CapsLock", "T"))
; EncodeInteger( KeyLED, 1, &input, 2 ) ;input bit pattern (KeyLED): bit 0 = scrolllock ;bit 1 = numlock ;bit 2 = capslock
input := Chr(1) Chr(1) Chr(KeyLED)
input := Chr(1)
input=
success := DllCall( "DeviceIoControl"
, "uint", h_device
, "uint", CTL_CODE( 0x0000000b ; FILE_DEVICE_KEYBOARD
, 2
, 0 ; METHOD_BUFFERED
, 0 ) ; FILE_ANY_ACCESS
, "uint", &input
, "uint", input_size
, "uint", 0
, "uint", 0
, "uint", &output_actual
, "uint", 0 )
CTL_CODE( p_device_type, p_function, p_method, p_access )
Return, ( p_device_type << 16 ) | ( p_access << 14 ) | ( p_function << 2 ) | p_method
NtCreateFile(ByRef wfilename,desiredaccess,sharemode,createdist,flags,fattribs)
VarSetCapacity(fh,4,0)
VarSetCapacity(objattrib,24,0)
VarSetCapacity(io,8,0)
VarSetCapacity(pus,8)
uslen:=DllCall("lstrlenW","str",wfilename)*2
InsertInteger(uslen,pus,0,2)
InsertInteger(uslen,pus,2,2)
InsertInteger(&wfilename,pus,4)
InsertInteger(24,objattrib,0)
InsertInteger(&pus,objattrib,8)
status:=DllCall("ntdll\ZwCreateFile","str",fh,"UInt",desiredaccess,"str",objattrib,"str",io,"UInt",0,"UInt",fattribs
,"UInt",sharemode,"UInt",createdist,"UInt",flags,"UInt",0,"UInt",0, "UInt")
return % ExtractInteger(fh)
SetUnicodeStr(ByRef out, str_)
VarSetCapacity(st1, 8, 0)
InsertInteger(0x530025, st1)
VarSetCapacity(out, (StrLen(str_)+1)*2, 0)
DllCall("wsprintfW", "str", out, "str", st1, "str", str_, "Cdecl UInt")
ExtractInteger(ByRef pSource, pOffset = 0, pIsSigned = false, pSize = 4)
; pSource is a string (buffer) whose memory area contains a raw/binary integer at pOffset.
; The caller should pass true for pSigned to interpret the result as signed vs. unsigned.
; pSize is the size of PSource's integer in bytes (e.g. 4 bytes for a DWORD or Int).
; pSource must be ByRef to avoid corruption during the formal-to-actual copying process
; (since pSource might contain valid data beyond its first binary zero).
Loop %pSize% ; Build the integer by adding up its bytes.
result += *(&pSource + pOffset + A_Index-1) << 8*(A_Index-1)
if (!pIsSigned OR pSize > 4 OR result < 0x80000000)
return result ; Signed vs. unsigned doesn't matter in these cases.
; Otherwise, convert the value (now known to be 32-bit) to its signed counterpart:
return -(0xFFFFFFFF - result + 1)
InsertInteger(pInteger, ByRef pDest, pOffset = 0, pSize = 4)
; The caller must ensure that pDest has sufficient capacity. To preserve any existing contents in pDest,
; only pSize number of bytes starting at pOffset are altered in it.
Loop %pSize% ; Copy each byte in the integer into the structure as raw binary data.
DllCall("RtlFillMemory", "UInt", &pDest + pOffset + A_Index-1, "UInt", 1, "UChar", pInteger >> 8*(A_Index-1) & 0xFF)
