Privacywetgeving
Option Explicit
Sub combinaties()
Dim r As Range
Dim iUpperLimit As Integer
Dim s
Dim i As Integer, j As Integer, k As Integer, l As Integer
Dim q As Integer, iSum As Integer
Dim lCombos As Long
s = Timer
For Each r In Range("B9:B25")
iUpperLimit = Int(r.Value / WorksheetFunction.Min(Range("C8:F8")))
For i = 0 To iUpperLimit
For j = 0 To iUpperLimit
For k = 0 To iUpperLimit
For l = 0 To iUpperLimit
lCombos = lCombos + 1
If lCombos Mod 10 = 0 Then Application.StatusBar = lCombos & " combinaties gecheckt"
iSum = i * Range("C8").Value + j * Range("D8").Value + k * Range("E8").Value + l * Range("F8").Value
If iSum = r.Value And WorksheetFunction.CountIf(Columns(7), CStr(i & j & k & l)) = 0 Then
For q = 1 To 4
If Choose(q, i, j, k, l) Then
r.Offset(, q).Value = Range("C8:F8").Cells(q).Value & "x" & Choose(q, i, j, k, l)
r.Offset(, 5).Value = CStr(i & j & k & l)
Next
GoTo here
Next: Next: Next: Next
here:
Next
MsgBox Int(Timer - s) & " sec.", vbInformation
Application.StatusBar = False
Sub combinaties()
Dim r As Range
Dim rSums As Range, rNumbers As Range
Dim s
Dim lCombos As Long
s = Timer
[B] Set rSums = Range("B9:B25")
Set rNumbers = Range("C8:F8")[/B]
For Each r In rSums
iUpperLimit = Int(r.Value / WorksheetFunction.Min(rNumbers))
[B]iSum = WorksheetFunction.SumProduct(rNumbers, Array(i, j, k, l))[/B]
For q = 1 To 4
r.Offset(, q).Value = rNumbers.Cells(q).Value & "x" & Choose(q, i, j, k, l)
Next
GoTo here
here:
Next
[B] MsgBox Round(Timer - s, 2) & " sec.", vbInformation[/B]
Wigi, ik snap het gebruik van die code niet helemaal.
Volgends mij is dat niet wat Jack zoekt!
