Sub Mail_ActiveSheet()
' Works in Excel 2000, Excel 2002, Excel 2003, Excel 2007, Excel 2010, Outlook 2000, Outlook 2002, Outlook 2003, Outlook 2007, Outlook 2010
Dim FileExtStr As String, shtName As String
Dim FileFormatNum As Long
Dim SourceWB As Workbook
Dim DestWB As Workbook
Dim TempFilePath As String
Dim TempFileName As String
With Application
.ScreenUpdating = False
.EnableEvents = False
Set SourceWB = ActiveWorkbook
' Next, copy the sheet to a new workbook.
shtName = ActiveSheet.Name
ActiveSheet.Copy
Set DestWB = ActiveWorkbook
With DestWB
' For Excel 2007-2010, exit the subroutine if you answer NO in the security dialog
' that is displayed when you copy a sheet from an .xlsm file with macros disabled.
If SourceWB.Name = .Name Then
With Application
.ScreenUpdating = True
.EnableEvents = True
MsgBox "You answered NO in the security dialog."
Exit Sub
Else
Select Case SourceWB.FileFormat
Case 51: FileExtStr = ".xlsx": FileFormatNum = 51
Case 52:
If .HasVBProject Then
FileExtStr = ".xlsm": FileFormatNum = 52
Else
Case 56: FileExtStr = ".xls": FileFormatNum = 56
Case Else: FileExtStr = ".xlsb": FileFormatNum = 50
End Select
' You can use the following statements to change all cells in the worksheet to values.
' With Destwb.Sheets(1).UsedRange
' .Cells.Copy
' .Cells.PasteSpecial xlPasteValues
' .Cells(1).Select
' End With
' Application.CutCopyMode = False
' Save the new workbook, mail, and then delete it.
TempFilePath = Environ$("temp") & "\"
TempFileName = shtName & " " & Format(Now, "dd-mmm-yy h-mm-ss")
With DestWB
.SaveAs TempFilePath & TempFileName & FileExtStr, FileFormat:=FileFormatNum
.Close SaveChanges:=False
With Application
