Range entries dynamisch maken VBA
  • Onderwerp starter Onderwerp starter TMD
TMD
27 jul 2015
Ik heb onderstaande code gemaakt en deze werkt perfect. Echter gaat hij alle entries af die ik heb ingegeven achter 'For X = 2 To 100' terwijl het er soms 92 en soms 110. Wanneer het er nu 92 zijn dan maakt het systeem 8 lege mailtjes, niet het grootste probleem in de wereld maar wel onhandig. Is er een manier om dit dynamisch te maken zodat hij altijd de hoeveelheid entries pakt die in het bestand staan?
Sub ORG_Generate_per_dept()
Application.DisplayAlerts = False
AWBN = ActiveWorkbook.Name
Sheets("Hulpsheet").Select
DBL = Sheets("Hulpsheet").Cells(Rows.Count, "A").End(xlUp).Row
For X = 2 To 100
STORENAME = Sheets("Hulpsheet").Cells(X, 2)
STORE = Application.IfError(Application.VLookup(STORENAME, Sheets("Stores").Range("A:B"), 2, 0), "")
DEPTNAME = Sheets("Hulpsheet").Cells(X, 3)
DEPT = Application.IfError(Application.VLookup(DEPTNAME, Sheets("Stores").Range("D:E"), 2, 0), "")
Sheets.Add.Name = STORE & " " & DEPT & " " & FormatDateTime(Date, vbShortDate)
Sheets("sheet1").Select
Selection.AutoFilter Field:=1, Criteria1:=STORENAME
Selection.AutoFilter Field:=2, Criteria1:=DEPTNAME
Sheets("sheet1").Range("A:O").Select
Selection.Copy Destination:=Sheets(STORE & " " & DEPT & " " & FormatDateTime(Date, vbShortDate)).Range("A1")
Sheets(STORE & " " & DEPT & " " & FormatDateTime(Date, vbShortDate)).Select
Sheets(STORE & " " & DEPT & " " & FormatDateTime(Date, vbShortDate)).Copy
    ActiveWorkbook.SaveAs Filename:= _
        "H:\" & STORE & " " & DEPT & " " & FormatDateTime(Date, vbShortDate) & ".xlsx", FileFormat:= _
        xlOpenXMLWorkbook, CreateBackup:=False
Windows(STORE & " " & DEPT & " " & FormatDateTime(Date, vbShortDate) & ".xlsx").Close , savechanges:=False
Windows(AWBN).Activate
Sheets(STORE & " " & DEPT & " " & FormatDateTime(Date, vbShortDate)).Delete
NTFind = Sheets("Email").Cells(Rows.Count, "A").End(xlUp).Row
Y = 2
Do While Y <= NTFind
If Sheets("Email").Cells(Y, 2) = STORENAME And Sheets("Email").Cells(Y, 1) = DEPTNAME Then
MAILNAME = Sheets("Email").Cells(Y, 1)
MAILADRESS = Sheets("Email").Cells(Y, 5)
Y = Y + 1
Loop
    Dim OutApp As Object
    Dim OutMail As Object
    With Application
        .ScreenUpdating = False
        .EnableEvents = False
    Set OutApp = CreateObject("Outlook.Application")
    Set OutMail = OutApp.CreateItem(0)
        On Error Resume Next
        With OutMail
            .To = MAILADRESS
            .Subject = " & STORE & " " & DEPT
            .HTMLBody = "<HTML><BODY>Test.</BODY></HTML>"
            .Attachments.Add ("H:\" & STORE & " " & DEPT & " " & FormatDateTime(Date, vbShortDate) & ".xlsx")
            .Display   'or use .Send
        On Error GoTo 0
    Set OutMail = Nothing
    Set OutApp = Nothing
    With Application
        .ScreenUpdating = True
        .EnableEvents = True
Next
Is dat niet een kwestie van deze aanpassing? (Waarom haal je anders het laatste rijnummer op?)
For X = 2 To DBL
