Sof2 ddouble helix test multiplayer kan niet opstarten
bryanb
24 okt 2008
hallo ik heb weer eens een vraagje dit keer over sof2. demo
ik heb laatst mijn pc helemaal schoongemaakt met een disc van vista toen was alles naar windows.old verplaatst.
dus ik heb hem ge uninstalt.
en opnieuw geinstallt en alles gedaan en dan
elke keer als ik dit spel wil opstarten staat er dit:
SOF2MP V1.02t win-x86 Apr 5 2002
Initialising zone memory .....
----- FS_Startup -----
Current search path:
C:\PROGRA~1\SOLDIE~1/base/MP
0 files in pk3 files
Running in restricted demo mode.
C:\PROGRA~1\SOLDIE~1/demo/MP
C:\PROGRA~1\SOLDIE~1\demo\assets.pk3 (1703 files)
1703 files in pk3 files
execing sof2mp_default.cfg
couldn't exec sof2mp.cfg
couldn't exec autoexec.cfg
Hunk_Clear: reset the hunk ok
OS: Microsoft winnt
CPU Detected: Unknown
Unknown
---------- Input Initialization ----------
Skipping check for DirectInput
Joystick is not active.
----- Client Initialization -----
----- Initializing Renderer ----
----- Client Initialization Complete -----
----- R_Init -----
WARNING: tess.xyz not 16 byte aligned
Initializing OpenGL subsystem
...initializing QGL
...calling LoadLibrary( 'C:\Windows\system32\opengl32.dll' ): succeeded
...setting mode 3: 640 480 FS
...using desktop display depth of 32
...calling CDS: ok
...registered window class
...created window@0,0 (640x480)
Initializing OpenGL driver
...getting DC: succeeded
...GLW_ChoosePFD( 32, 24, 8 )
...35 PFDs found
...GLW_ChoosePFD failed
...GLW_ChoosePFD( 32, 24, 0 )
...35 PFDs found
...failed to find an appropriate PIXELFORMAT
...restoring display settings
...WARNING: could not set the given mode (3)
...using colorsbits of 16
...calling CDS: ok
...GLW_ChoosePFD( 16, 16, 0 )
...35 PFDs found
...35 PFDs found
...shutting down QGL
...unloading OpenGL DLL
...assuming '3dfxvgl' is a standalone driver
...initializing QGL
...WARNING: missing Glide installation, assuming no 3Dfx available
----- CL_Shutdown -----
RE_Shutdown( 1 )
R_Terrain: Shutting down RENDERER terrain.....
GLW_StartOpenGL() - could not load OpenGL subsystem
------------- Input Shutdown -------------
dit vindt ik egt een vervelend probleem kan iemand mij helpen het spel weer te laten werken?
