verwijderen AD
justmehaxe
12 aug 2001
Hey,
ik wil mijn AD (active Directory) verwijderen maar dit gaat niet omdat hij deze fout geeft.
The operation failed because:
A domein controller could not be contacted for the domain ********.nl that contained an account for this computer.
Make the computer a member of a workgroup then rejoin the domain before retrying the promotion.
"THe specified domain either does not exist or could not be contacted"
greetz,
Had je meerdere servers?
Welk gedeelte van de tekst snap je nog niet?
tis trouwens Small Busines Server 2003........ik begrijp de foutmelding niet helemaal
Heb je al geprobeerd wat er in die link stond of krijg je dan die foutmelding?
Ik probeer uit te vogelen wat JIJ niet snapt ;)
nou de vraag is hoe los ik het op he......dus heb je enig idee....ik staat dat ik een account moet lid maken ofzo..
administrator is al lid van DnsAdmins
greetz,
Heb je dit al geprobeerd:
Click Start, click Run, type dcpromo, and then click OK.
This starts the Active Directory Installation Wizard. Click Next.
There is a check box in the Remove Active Directory screen. If this computer is the last domain controller in the domain, click to select the check box. Otherwise, click Next.
In the next screen, set the password for the administrator account on the server after Active Directory is removed. Type the appropriate password in the Password and Confirm Password boxes, and then click Next.
In the Summary screen, review and confirm the options you selected, and then click Next.
The wizard begins the process of removing Active Directory from the server. After the process is finished, a message indicates that Active Directory was removed from the computer.
Click Finish to quit the wizard.
Restart the computer
