Vraag over De Magicool Liquid Cooled Case
bartklaaaaw
19 sep 2009
Ik ben van plan om bij een online internet winkel de volgende case te kopen:
http://www.magicool.biz/Magicool/LiquidCoolingCase.html
Specs:
* Easy & Quick ready to go case with dual 140 radiator & Pump700
* hand screwed 1/4" Fitting, with decouple for HDD & power unit
* toolfree mounting for HDD CD and ADD-ON cards
* with 4x silent (1000 RPM) 12 cm fan
* universal CPU cooling block, compatible for
i1366/S775/478/AM3/AM2/AM64 ETC.
Case Specifications:
Case Type Midi Tower
Side Panel model standard non-window
optional unique design window
10 Drive Bays External 5.25" x 5 or 5.25" x 4, 3.5" x 1
Internal 3.5" x 5 or 2.5" x 5 for HDD / SSD
Colour Full Black for exterior & interior
Motherboard ATX, Micro ATX, mini-ITX
Bottom PSU Support Standard ATX PS2, EPS 12V
Liquid cooling Support 1/2", 3/8", 1/4" water tube
I/O Ports USB2.0 x 2, e-SATA connector, HDA
Expansion Slots 7
Case Dimensions 478 x 210 x 510 mm (H x W x D)
Water Cooling Specifications:
Radiator [mc-radi280] Magicool 280mm radiator
Pump [mc-pump700] Magicool 700 l/h pump
Cooling block [mc-block-cpu-revII] Magicool universal
cooling block for CPU
Coolant [mc-lq500] Magicool High Performance
Coolant
Tube [MC-PUR8/10] Magicool tube standard
Fitting [MC-FT8/10Q]
Screw Connector with G1/8"
inch outside thread
Fan 4x silent (1000 RPM) 120 mm fan
Nu is mijn vraag... heeft een van jullie deze case in bezit (gehad) en wat is jullie mening erover
ook zou ik graag wat extra fotos ervan willen maar die zijn niet te vinden op google of de site van de fabrikant
