nhojnavslig
- 13 dec 2005
Privacywetgeving
Private Sub ComboBox1_Change()
With Sheets("Blad3")
Select Case ComboBox1.Text
Case 6: .Range("E4") = .Range("E4") - 1
Case 8: .Range("F4") = .Range("F4") - 1
Case 10: .Range("G4") = .Range("G4") - 1
End Select
Private Sub CommandButton2_Click()
If ComboBox1.ListIndex > -1 Then
With Sheets("blad3").Range("E4")
.Offset(, ComboBox1.ListIndex) = .Offset(, ComboBox1.ListIndex) - 1
Unload Me
kol = Choose(ComboBox1.Text, , , , , , 5, , 6, , 7)
.Cells(4, kol) = .Cells(4, kol) - 1
Sheets("Blad3").Cells(4, Choose(ComboBox1.Text, , , , , , 5, , 6, , 7)) = Sheets("Blad3").Cells(4, Choose(ComboBox1.Text, , , , , , 5, , 6, , 7)) - 1
If ComboBox1.ListIndex > -1 Then Sheets("Blad3").Cells(4, 2).Offset(, ComboBox1 / 2) = Sheets("Blad3").Cells(4, 2).Offset(, ComboBox1 / 2) - 1
Private Sub CommandButton1_Click()
ar = Sheets("Voorraad").Cells(17, 2).Resize(, 6)
Dim ar1(6) As Double
For j = 2 To 7
If Not IsNumeric(Me("TextBox" & j)) And Me("TextBox" & j) <> "" Then
Me("TextBox" & j).SetFocus
Exit Sub
Else
B = True
ar1(j - 1) = Val(Me("TextBox" & j))
ar(1, j - 1) = ar(1, j - 1) + ar1(j - 1)
Next j
If B Then
ar1(0) = Date
Sheets("Log").Cells(Rows.Count, 1).End(xlUp).Offset(1).Resize(, 7) = ar1
Sheets("Voorraad").Cells(17, 2).Resize(, 6) = ar
Unload Me
Private Sub UserForm_Initialize()
ComboBox1.List = [diameter].Value
Private Sub UserForm_QueryClose(Cancel As Integer, CloseMode As Integer)
y = ComboBox1.ListIndex
If y > -1 Then Blad3.Cells(4, 5).Offset(, y) = Blad3.Cells(4, 5).Offset(, y) - 1
