Sub Navios()
' Sneltoets: Ctrl+Shift+N
Sheets("READ IN FILE").Select
Rows("3:1250").Select
Selection.Delete Shift:=xlUp
Range("Tabel1[Nav Code]").Select
Sheets("COPY TOTAL INQUIRY").Select
Rows("1:22").Select
Range("B1").Activate
Range("B1").Select
Columns("A:A").ColumnWidth = 7.57
Range("A1").Select
ActiveCell.FormulaR1C1 = "X"
Range("A1").Select
Selection.Copy
Range("A2").Select
ActiveWindow.ScrollRow = 1065
ActiveWindow.SmallScroll Down:=150
Range("A2:A1250").Select
Selection.PasteSpecial Paste:=xlPasteValues, Operation:=xlNone, SkipBlanks _
:=False, Transpose:=False
Columns("D:H").Select
Range("D2").Activate
With Selection
.HorizontalAlignment = xlGeneral
.VerticalAlignment = xlBottom
.WrapText = False
.Orientation = 0
.AddIndent = False
.IndentLevel = 0
.ShrinkToFit = False
.ReadingOrder = xlContext
.MergeCells = True
Selection.UnMerge
Range("E:H,K:P").Select
Range("K1").Activate
Selection.Delete Shift:=xlToLeft
Range("T9").Select
Columns("D:D").ColumnWidth = 21.57
Columns("E:E").ColumnWidth = 17.57
Columns("F:F").ColumnWidth = 21.29
Columns("G:M").Select
Selection.ColumnWidth = 20.71
Columns("F:F").Select
Selection.Copy
Columns("G:G").Select
ActiveSheet.Paste
Range("H1").Select
ActiveCell.FormulaR1C1 = "A"
Range("I1").Select
ActiveCell.FormulaR1C1 = "B"
Range("J1").Select
ActiveCell.FormulaR1C1 = "C"
Range("A1:J1").Select
Selection.AutoFilter
Rows("2:2").Select
ActiveWindow.FreezePanes = True
Range("J9").Select
ActiveSheet.Range("$A$1:$J$1250").AutoFilter Field:=2, Criteria1:="="
ActiveWindow.SmallScroll Down:=49
ActiveWindow.LargeScroll Down:=3
ActiveWindow.SmallScroll Down:=14
Rows("18:1250").Select
Range("A1250").Activate
Range("D1022").Select
ActiveSheet.Range("$A$1:$J$1018").AutoFilter Field:=2
ActiveWindow.ScrollRow = 2
Range("A2").Select
ActiveSheet.Range("$A$1:$J$1018").AutoFilter Field:=4, Criteria1:=RGB(250, 250, 210), Operator:=xlFilterCellColor
ActiveWindow.SmallScroll Down:=169
Rows("18:1200").Select
Range("A1200").Activate
ActiveSheet.Range("$A$1:$J$994").AutoFilter Field:=4
Range("H3").Select
ActiveCell.FormulaR1C1 = _
"=IFERROR(IF(SEARCH(""="",RC[-1])>0,RC[-1],""""),"""")"
Range("H3").Select
Selection.Copy
Range("H4:H1242").Select
Selection.PasteSpecial Paste:=xlPasteFormulas, Operation:=xlNone, SkipBlanks:=False, Transpose:=False
Selection.Replace What:="=*", Replacement:="", LookAt:=xlPart, _
SearchOrder:=xlByRows, MatchCase:=False, SearchFormat:=False, ReplaceFormat:=False
Range("I2").Select
ActiveCell.FormulaR1C1 = "=IF(RC[-7]>0,IF(RC[-4]="""",CONCATENATE(""*** DEPARTMENT: "",RC[-7]),CONCATENATE(RC[-5],"" ("",RC[-1],"")"")),"""")"
Range("I2").Select
Selection.Copy
Range("I3").Select
ActiveWindow.ScrollRow = 1208
Range("I3:I1250").Select
Columns("I:I").Select
Selection.Copy
Selection.PasteSpecial Paste:=xlPasteValues, Operation:=xlNone, SkipBlanks:=False, Transpose:=False
Selection.Replace What:=" ()", Replacement:="", LookAt:=xlPart, SearchOrder:=xlByRows, MatchCase:=False, SearchFormat:=False, ReplaceFormat:=False
Range("A1").Select
Range(Selection, Selection.End(xlDown)).Select
Range("A1").Select
Selection.End(xlDown).Select
Range("A994:K994").Select
Selection.ClearContents
Range("G2").Select
ActiveCell.FormulaR1C1 = "=IF(RC[-2]="""","""",RC[-5])"
Selection.Copy
Range("G3").Select
Range("G3:G1250").Select
Range("P1249").Select
Selection.Cut
Columns("D:D").Select
Selection.Insert Shift:=xlToRight
Columns("E:E").Select
Range("D2").Select
Range(Selection, Selection.End(xlToRight)).Select
Selection.Copy
Range("Tabel1[Description]").Select
Range(Selection, Selection.End(xlToLeft)).Select
Range("C2:D993").Select
Selection.Copy
Range("B2").Select
Cells.Select
Range("A1").Select
Range("A2").Select
ActiveWorkbook.Save
