Hallo allemaal,
Heb de onderstaande macro gemaakt,
Hij geeft echter de volgende foutmelding. " compileer fout end with wordt verwacht."
Wat is er mis mee?
Sub wegkopieren()
With Sheets("selecteren")
.Cells(1).CurrentRegion.AutoFilter 5, Filter(Application.Transpose([if(criteria!a2:a9="","~",criteria!a2:a9)]), "~", False), 7
.AutoFilter.Range.Offset(1).Columns(2).Copy Sheets("1nir").Range("A2")
.Cells(1).CurrentRegion.AutoFilter 5, Filter(Application.Transpose([if(criteria!b2:b8="","~",criteria!b2:b8)]), "~", False), 7
.AutoFilter.Range.Offset(1).Columns(2).Copy Sheets("2nir").Range("A2")
.Cells(1).CurrentRegion.AutoFilter 5, Filter(Application.Transpose([if(criteria!c2:c11="","~",criteria!c2:c11)]), "~", False), 7
.AutoFilter.Range.Offset(1).Columns(2).Copy Sheets("3nir").Range("A2")
.Cells(1).CurrentRegion.AutoFilter 5, Filter(Application.Transpose([if(criteria!d2:d18="","~",criteria!d2:d18)]), "~", False), 7
.AutoFilter.Range.Offset(1).Columns(2).Copy Sheets("4nir").Range("A2")
.Cells(1).CurrentRegion.AutoFilter 5, Filter(Application.Transpose([if(criteria!e2:e8="","~",criteria!e2:e8)]), "~", False), 7
.AutoFilter.Range.Offset(1).Columns(2).Copy Sheets("6nir").Range("A2")
.Cells(1).CurrentRegion.AutoFilter 5, Filter(Application.Transpose([if(criteria!f2:f3="","~",criteria!f2:f3)]), "~", False), 7
.AutoFilter.Range.Offset(1).Columns(2).Copy Sheets("8nir").Range("A2")
.Cells(1).CurrentRegion.AutoFilter 5, Filter(Application.Transpose([if(criteria!g2:g3="","~",criteria!g2:g3)]), "~", False), 7
.AutoFilter.Range.Offset(1).Columns(2).Copy Sheets("12nir").Range("A2")
.Cells(1).CurrentRegion.AutoFilter 5, Filter(Application.Transpose([if(criteria!h2:h100="","~",criteria!h2:h100)]), "~", False), 7
.AutoFilter.Range.Offset(1).Columns(2).Copy Sheets("13nir").Range("A2")
.Cells(1).CurrentRegion.AutoFilter 5, Filter(Application.Transpose([if(criteria!i2:i11="","~",criteria!i2:i11)]), "~", False), 7
.AutoFilter.Range.Offset(1).Columns(2).Copy Sheets("16nir").Range("A2")
Wat is er mis mee?
Sub wegkopieren()
