Hoe start ik met c++
kenikavanbis
22 mei 2007
ik heb codeblocks en mingw.
maar de compiler kan hello world niet compileren tja.
tegen morgen moet ik Qt hebben.
ik zal er niet zijn denk ik .
code
#include <iostream>
//#include "std"
using namespace std;
int main()
    cout << "Hello world!" << endl;
    return 0;
error
||=== Build: Debug in testproject (compiler: GNU GCC Compiler) ===|
c:\mingw\include\sys\stat.h|173|error: '_dev_t' does not name a type|
c:\mingw\include\sys\stat.h|173|error: '_ino_t' does not name a type|
c:\mingw\include\sys\stat.h|173|error: '_mode_t' does not name a type|
c:\mingw\include\sys\stat.h|173|error: '_off_t' does not name a type|
c:\mingw\include\sys\stat.h|173|error: 'time_t' does not name a type|
c:\mingw\include\sys\stat.h|180|error: '_dev_t' does not name a type|
c:\mingw\include\sys\stat.h|180|error: '_ino_t' does not name a type|
c:\mingw\include\sys\stat.h|180|error: '_mode_t' does not name a type|
c:\mingw\include\sys\stat.h|180|error: '_off_t' does not name a type|
c:\mingw\include\sys\stat.h|180|error: 'time_t' does not name a type|
c:\mingw\include\sys\stat.h|188|error: '_dev_t' does not name a type|
c:\mingw\include\sys\stat.h|188|error: '_ino_t' does not name a type|
c:\mingw\include\sys\stat.h|188|error: '_mode_t' does not name a type|
c:\mingw\include\sys\stat.h|188|error: '__off64_t' does not name a type|
c:\mingw\include\sys\stat.h|188|error: 'time_t' does not name a type|
c:\mingw\include\sys\stat.h|195|error: '_dev_t' does not name a type|
c:\mingw\include\sys\stat.h|195|error: '_ino_t' does not name a type|
c:\mingw\include\sys\stat.h|195|error: '_mode_t' does not name a type|
c:\mingw\include\sys\stat.h|195|error: '__off64_t' does not name a type|
c:\mingw\include\sys\stat.h|195|error: '__time64_t' does not name a type|
c:\mingw\include\io.h|335|error: 'time_t' does not name a type|
c:\mingw\include\io.h|336|error: 'time_t' does not name a type|
c:\mingw\include\io.h|362|error: '__time64_t' does not name a type|
c:\mingw\lib\gcc\mingw32\5.3.0\include\c++\cwchar|146|error: '::fwide' has not been declared|
c:\mingw\lib\gcc\mingw32\5.3.0\include\c++\cwchar|153|error: '::mbsinit' has not been declared|
c:\mingw\lib\gcc\mingw32\5.3.0\include\c++\cwchar|198|error: '::wmemcmp' has not been declared|
c:\mingw\lib\gcc\mingw32\5.3.0\include\c++\cwchar|199|error: '::wmemcpy' has not been declared|
c:\mingw\lib\gcc\mingw32\5.3.0\include\c++\cwchar|200|error: '::wmemmove' has not been declared|
c:\mingw\lib\gcc\mingw32\5.3.0\include\c++\cwchar|201|error: '::wmemset' has not been declared|
c:\mingw\lib\gcc\mingw32\5.3.0\include\c++\cwchar|208|error: '::wmemchr' has not been declared|
c:\mingw\lib\gcc\mingw32\5.3.0\include\c++\cwchar||In function 'wchar_t* std::wmemchr(wchar_t*, wchar_t, std::size_t)':|
c:\mingw\lib\gcc\mingw32\5.3.0\include\c++\cwchar|229|error: invalid conversion from 'const wchar_t*' to 'wchar_t*' [-fpermissive]|
c:\mingw\lib\gcc\mingw32\5.3.0\include\c++\cwchar|228|note: initializing argument 1 of 'wchar_t* std::wmemchr(wchar_t*, wchar_t, std::size_t)'|
c:\mingw\lib\gcc\mingw32\5.3.0\include\c++\bits\char_traits.h|353|error: 'wmemcmp' was not declared in this scope|
||More errors follow but not being shown.|
||Edit the max errors limit in compiler options...|
||=== Build failed: 50 error(s), 0 warning(s) (0 minute(s), 0 second(s)) ===|
Om QT te gebruiken hoef je geen C++ te doen an sich. Er zijn ook binding voor vele andere talen.
Puur om met C++ te werken kun je ook uit de voeten met MS visual studio 2015: https://stackoverflow.com/questions/32894097/how-do-i-use-qt-in-my-visual-studio-2015-projects
Je huidige probleem lijkt erop dat je PATH variabelen niet helemaal goed staan. Ik heb echter al bijna 25 jaar geen losse compiler op windows meer gebruikt, dus misschien heeft iemand anders specifiek een oplossing voor de huidige software
nu zou het qt.nokia.com de oplossing moeten zijn.ik moet het nog bekijken
