NoSuchMethodException @ Extended class
Maximvdw
7 feb 2009
Beste,
Ik heb een probleem dat ik niet echt kan achterhalen:
[16:42:22 ERROR]: Error occurred while enabling FFA v1.0.0 (Is it up to date?)
java.lang.NoSuchMethodError: be.maximvdw.baseplugin.commands.SubCommand.<init>(L
java/lang/String;Ljava/lang/String;)V
        at be.maximvdw.ffa.commands.AddSpawnCommand.<init>(AddSpawnCommand.java:
23) ~[?:?]
        at be.maximvdw.ffa.commands.FFACommand.<init>(FFACommand.java:34) ~[?:?]
        at be.maximvdw.ffa.FFAPlugin.registerCommands(FFAPlugin.java:47) ~[?:?]
        at be.maximvdw.baseplugin.license.Validator.<init>(Validator.java:78) ~[
        at be.maximvdw.ffa.FFAPlugin.onEnable(FFAPlugin.java:28) ~[?:?]
        at org.bukkit.plugin.java.JavaPlugin.setEnabled(JavaPlugin.java:250) ~[c
raftbukkit.jar:git-Bukkit-1.7.2-R0.3-2-g85f5776-b3023jnks]
        at org.bukkit.plugin.java.JavaPluginLoader.enablePlugin(JavaPluginLoader
.java:324) [craftbukkit.jar:git-Bukkit-1.7.2-R0.3-2-g85f5776-b3023jnks]
        at org.bukkit.plugin.SimplePluginManager.enablePlugin(SimplePluginManage
r.java:404) [craftbukkit.jar:git-Bukkit-1.7.2-R0.3-2-g85f5776-b3023jnks]
        at org.bukkit.craftbukkit.v1_7_R1.CraftServer.loadPlugin(CraftServer.jav
a:439) [craftbukkit.jar:git-Bukkit-1.7.2-R0.3-2-g85f5776-b3023jnks]
        at org.bukkit.craftbukkit.v1_7_R1.CraftServer.enablePlugins(CraftServer.
java:375) [craftbukkit.jar:git-Bukkit-1.7.2-R0.3-2-g85f5776-b3023jnks]
        at org.bukkit.craftbukkit.v1_7_R1.CraftServer.reload(CraftServer.java:77
3) [craftbukkit.jar:git-Bukkit-1.7.2-R0.3-2-g85f5776-b3023jnks]
        at org.bukkit.Bukkit.reload(Bukkit.java:279) [craftbukkit.jar:git-Bukkit
        at org.bukkit.command.defaults.ReloadCommand.execute(ReloadCommand.java:
23) [craftbukkit.jar:git-Bukkit-1.7.2-R0.3-2-g85f5776-b3023jnks]
        at org.bukkit.command.SimpleCommandMap.dispatch(SimpleCommandMap.java:17
        at org.bukkit.craftbukkit.v1_7_R1.CraftServer.dispatchCommand(CraftServe
r.java:683) [craftbukkit.jar:git-Bukkit-1.7.2-R0.3-2-g85f5776-b3023jnks]
        at org.bukkit.craftbukkit.v1_7_R1.CraftServer.dispatchServerCommand(Craf
tServer.java:670) [craftbukkit.jar:git-Bukkit-1.7.2-R0.3-2-g85f5776-b3023jnks]
        at net.minecraft.server.v1_7_R1.DedicatedServer.aw(DedicatedServer.java:
286) [craftbukkit.jar:git-Bukkit-1.7.2-R0.3-2-g85f5776-b3023jnks]
        at net.minecraft.server.v1_7_R1.DedicatedServer.u(DedicatedServer.java:2
51) [craftbukkit.jar:git-Bukkit-1.7.2-R0.3-2-g85f5776-b3023jnks]
        at net.minecraft.server.v1_7_R1.MinecraftServer.t(MinecraftServer.java:5
45) [craftbukkit.jar:git-Bukkit-1.7.2-R0.3-2-g85f5776-b3023jnks]
        at net.minecraft.server.v1_7_R1.MinecraftServer.run(MinecraftServer.java
:457) [craftbukkit.jar:git-Bukkit-1.7.2-R0.3-2-g85f5776-b3023jnks]
        at net.minecraft.server.v1_7_R1.ThreadServerApplication.run(SourceFile:6
17) [craftbukkit.jar:git-Bukkit-1.7.2-R0.3-2-g85f5776-b3023jnks]
SubCommand classe (Linked Source):
package be.maximvdw.baseplugin.commands;
import org.bukkit.entity.Player;
import be.maximvdw.baseplugin.lang.Messages;
import be.maximvdw.baseplugin.ui.SendGame;
 * SubCommand
 * MVdW Plugin Sub Command
 * @project MVdW Software Plugin Interface
 * @version 12-02-2014
 * @author Maxim Van de Wynckel (Maximvdw)
 * @site http://www.mvdw-software.be/
public class SubCommand {
	/** Command description */
	private String description = "";
	/** Command usage */
	private String usage = "";
	/** Command usage format */
	private String usageFormat = "";
	/** Command description format */
	private String descriptionFormat = "";
	/** Command */
	private String command = "";
	/** Permission */
	private String permission = "";
	/** Base command */
	private BaseCommand baseCommand = null;
	public SubCommand() {
	 * Initialize sub command
	 * @param command
	 *            Command
	 * @param permission
	 *            Permission
	public SubCommand(String command, String permission) {
		setCommand(command);
		setPermission(permission);
	 * Get base command
	 * @return Base Command
	public BaseCommand getBaseCommand() {
		return baseCommand;
	 * Set base command
	 * @param command
	 *            Command
	public void setBaseCommand(BaseCommand command) {
		this.baseCommand = command;
	 * Get permission
	 * @return Permission
	public String getPermission() {
		return permission;
	 * Set permission
	 * @param permission
	 *            Permission
	public void setPermission(String permission) {
		this.permission = permission;
	 * Get command
	 * @return Command
	public String getCommand() {
		return command;
	 * Set command
	 * @param command
	 *            Command
	public void setCommand(String command) {
		this.command = command;
	 * Get usage format
	 * @return Usage Format
	public String getUsageFormat() {
		return usageFormat;
	 * Get description format
	 * @return Description Format
	public String getDescriptionFormat() {
		return descriptionFormat;
	 * Set usage format
	 * @param format
	 *            Usage Format
	public void setUsageFormat(String format) {
		this.usageFormat = format;
	 * Set description format
	 * @param format
	 *            Description Format
	public void setDescriptionFormat(String format) {
		this.descriptionFormat = format;
	 * Get command usage
	 * @return Usage
	public String getUsage() {
		return usage;
	 * Set command usage
	 * @param usage
	 *            Usage
	public void setUsage(String usage) {
		this.usage = usage;
	 * Get command description
	public String getDescription() {
		return description;
	 * Set command description
	 * @param description
	 *            Description
	public void setDescription(String description) {
		this.description = description;
	 * Get player
	 * @param sender
	 *            Sender
	 * @return Player
	public Player getPlayer(Object sender) {
		if (sender instanceof Player) {
			return (Player) sender;
		return null;
	 * On command
	 * @param sender
	 *            Sender
	 * @param args
	 *            Arguments
	 * @param Command
	 *            status
	public void onCommand(Object sender, String[] args) {
		Player player = getPlayer(sender);
		if (player != null) {
			if (!player.hasPermission(getPermission())) {
				String message = Messages.getString("no-permission");
				SendGame.toPlayer(
						message == null ? "&cYou do not have permission!"
								: message, player);
AddSpawnCommand (extended van SubCommand):
package be.maximvdw.ffa.commands;
import org.bukkit.Location;
import be.maximvdw.baseplugin.commands.SubCommand;
import be.maximvdw.baseplugin.game.Arena;
import be.maximvdw.baseplugin.ui.SendConsole;
import be.maximvdw.ffa.FFAPlugin;
public class AddSpawnCommand extends SubCommand {
	 * @param command
	 *            Command
	 * @param permission
	 *            Permission
	public AddSpawnCommand(String command, String permission) {
		super(command,permission);
	 * On command
	@Override
		super.onCommand(sender, args);
		/** Check if player */
		if (player == null) {
			SendConsole.warning("This command can only be used ingame!");
			return;
		Location location = player.getLocation();
		Arena arena = ((FFAPlugin) this.getBaseCommand().getPlugin())
				.getArena();
		/** Add spawn location */
		arena.addSpawn(location);
		String message = Messages.getString("spawn-set");
		message = message.replace("{SPAWN}", arena.getSpawns().size() + "");
		SendGame.toPlayer(message, player);
Weet iemand raad :)
- Maximvdw
Voel me een volslagen idioot nu xD..
Probleem was dat mijn "baseplugin" package al in een ander project zat waar deze functies ontbraken
gr,
Maximvdw
