SOMPRODUCT?, Hoe vind combinaties die op een specifiek bedrag uitkomen
999wrld
22 jun 2022
Ik probeer via SOMPRODUCT richting 1000 cijfers (deelbedragen) te koppelen aan zo'n... 150ish bedragen? Alleen kom ik er niet helemaal uit, manueel is het niet te doen.. en ik weet niet zo goed hoe ik het moet uitleggen, in het engels is het wat makkelijker voor mij (gezien geleerd via engels artikel/2e taal).
Goodday, I am having some issues:confused: (note: big excel noob)
I tried to use this guide: (i cant post links but the title is How To Find All Combinations That Equal A Given Sum In Excel?, and the websites called ExtendOffice dot com.. the article;
extendoffice.com/documents/excel/3557-excel-find-all-combinations-that-equal-given-sum.html
The article used a couple of different methodes, I tried the second method (with seemed to worked yesterday with less possible combinations. (second article headline from link; Find Cells Combination That Equal A Given Sum With Solver Add-In )
I added a screenshot of the excel (it''s still loading because of SOMPRODUCT, i cant do anything excel wise, this has unironically be since 6 hours!!!! The subproblem in the left has reached (nearly) 500.000.
These are 40 of the 1500+ numbers that i need to figure out where they belong. For example, right in row Q you see 77,05, 137,40, 124,85 etc, and I need to figure out which of the K (Debet) row belongs with the combinations.... Why is it taking 6 hours? Doing it manually is hell too but to spend 6 (slowly nearing 8 hours...) for just one combination, with somewhere between 50 to 150 to go.........
Could you guys please advise me on how i can do this efficiently? I would love to answer/elaborate any questions you may have, but formost i sincerely thank you for taking the time to read this.
Thank you!
J2PEj9f9a8gAAAAASUVORK5CYII=
    25,8 KB · Weergaven: 17
Welkom.
Waarom je geen link in jouw editor kunt plaatsen is mij een raadsel. En waarom alles vetgedrukt?
Google vertaling:
Goedendag, ik heb wat problemen (let op: grote Excel-noob)
Ik heb geprobeerd deze handleiding te gebruiken: (ik kan geen links plaatsen, maar de titel is Hoe vind je alle combinaties die gelijk zijn aan een bepaalde som in Excel? en de websites met de naam ExtendOffice punt com.. het artikel;
How to find all combinations that equal a given sum in Excel?
Het artikel gebruikte een aantal verschillende methodes, ik probeerde de tweede methode (met leek gisteren te werken met minder mogelijke combinaties. (tweede artikelkop van link; Vind cellencombinatie die gelijk is aan een gegeven som met oplosser-invoegtoepassing)
Ik heb een screenshot van de Excel toegevoegd (het is nog steeds aan het laden vanwege SOMPRODUCT, ik kan niets excelleren, dit is onronisch al sinds 6 uur!!!! Het subprobleem aan de linkerkant heeft (bijna) 500.000 bereikt.
Dit zijn 40 van de 1500+ nummers die ik nodig heb om erachter te komen waar ze thuishoren. Bijvoorbeeld, rechts in rij Q zie je 77,05, 137,40, 124,85 etc, en ik moet uitzoeken welke van de K (Debet) rij bij de combinaties hoort.... Waarom duurt het 6 uur ? Handmatig doen is ook een hel, maar om 6 (langzaam bijna 8 uur...) te besteden aan slechts één combinatie, met nog ergens tussen de 50 en 150 te gaan.........
Kunnen jullie mij adviseren hoe ik dit efficiënt kan doen? Ik zou graag al uw vragen beantwoorden/uitwerken, maar ik dank u vooral dat u de tijd heeft genomen om dit te lezen.
Dank je!
