maartenmars
- 29 apr 2008
Ik heb een klein probeem. Mijn macro werkt. Alleen wil ik nu zorgen dat de locatie aangepast kan worden door mensen. Dus wil ik graag de locatie in een cel neerzetten. Hoe doe ik dit??
Dit is de macro.
Private Sub CommandButton1_DblClick(ByVal Cancel As MSForms.ReturnBoolean)
ActiveWindow.ScrollColumn = 40
ActiveWindow.ScrollColumn = 38
ActiveWindow.ScrollColumn = 36
ActiveWindow.ScrollColumn = 35
ActiveWindow.ScrollColumn = 34
ActiveWindow.ScrollColumn = 33
ActiveWindow.ScrollColumn = 31
ActiveWindow.ScrollColumn = 30
ActiveWindow.ScrollColumn = 29
ActiveWindow.ScrollColumn = 28
ActiveWindow.ScrollColumn = 26
ActiveWindow.ScrollColumn = 25
ActiveWindow.ScrollColumn = 23
ActiveWindow.ScrollColumn = 21
ActiveWindow.ScrollColumn = 20
ActiveWindow.ScrollColumn = 19
ActiveWindow.ScrollColumn = 18
ActiveWindow.ScrollColumn = 17
ActiveWindow.ScrollColumn = 16
ActiveWindow.ScrollColumn = 15
ActiveWindow.ScrollColumn = 14
ActiveWindow.ScrollColumn = 13
ActiveWindow.ScrollColumn = 12
ActiveWindow.ScrollColumn = 11
ActiveWindow.ScrollColumn = 10
ActiveWindow.ScrollColumn = 9
ActiveWindow.ScrollColumn = 8
ActiveWindow.ScrollColumn = 7
ActiveWindow.ScrollColumn = 6
Columns("F:M").Select
Selection.EntireColumn.Hidden = True
Columns("O:V").Select
Columns("X:AE").Select
Columns("AG:AN").Select
Columns("AP:AW").Select
Range("B6").Select
Dim Bestandsnaam As String
Bestandsnaam = "G:\DATAPROJ\riolen\Weekstaten\Weekstaten" & CStr(Range("A1").Value) & ".xls"
ThisWorkbook.SaveAs Bestandsnaam
Nu moet hij opslaan op de locatie die in de cel A2 vermeld staat. Dus G:\DATAPROJ\riolen\Weekstaten\Weekstaten moet iets van [A2] worden, maar daar kom ik niet uit.
Antwoord bleek zo simpel als verwacht. Range("A2")
Dit is de macro.
Range("B6").Select
