xmbc installeren met geforce mx 440
bryanwilms
8 mei 2007
beste forumleden,
ik wilde XBMC op mijn oude desktop installeren en alles ging geweldig totdat hij zijn gui niet laadde.
ik weet dat deze kaart niet ondersteund wordt maar er was iets voor dat de kaart wel ondersteund werd.
ik heb dit geprobeerd maar zonder succes omdat linux simpelweg de drivers niet wil installeren. en rare foutmeldingen geeft.
heeft iemand een idee
Alvast bedankt
ik heb ook de mogelijkheid om xubuntu te installeren en dat in combinatie met XBMC
maar.. het MOET snel opstarten (een paar seconden dus)
It took forever for 2 of us to figure this out,
This tutorial is intended to help those with less than the supported cards (6 Series) and should be easily applicable to others.
The Problem: The ubuntu repositiories don't host the proper driver for earlier nVidia cards.
The Solution: Venture over to nvidia.com and download the driver for your own project.
Then
sudo apt-get install linux-headers-`uname -r` build-essential
cd to the directory where your nvidia driver that you just downloaded is and run
sudo sh *run
Finally, modify your xorg.conf
Our setup used composite out look here for more information.
HTML Code:
http://en.wikibooks.org/wiki/NVidia/TV-OUT
This was our xorg.conf
Section "ServerLayout"
Identifier "Default Layout"
Screen "Default Screen" 0 0
InputDevice "Generic Keyboard" "CoreKeyboard"
InputDevice "Configured Mouse"
EndSection
Section "Files"
EndSection
Section "Module"
Load "glx"
EndSection
Section "InputDevice"
Identifier "Generic Keyboard"
Driver "kbd"
Option "XkbRules" "xorg"
Option "XkbModel" "pc105"
Option "XkbLayout" "us"
EndSection
Identifier "Configured Mouse"
Driver "mouse"
Option "CorePointer"
EndSection
Section "Monitor"
Identifier "Configured Monitor"
EndSection
Section "Device"
Identifier "Configured Video Device"
Driver "nvidia"
EndSection
Section "Screen"
Identifier "Default Screen"
Device "Configured Video Device"
Monitor "Configured Monitor"
DefaultDepth 24
Option "AddARGBGLXVisuals" "True"
Option "RenderAccel" "1"
Option "TVStandard" "NTSC-M"
Option "TVOutFormat" "COMPOSITE"
Option "TVOverScan" "0.6"
Option "ConnectedMonitor" "TV"
SubSection "Display"
Depth 24
Modes "nvidia-auto-select"
EndSubSection
EndSection
Section "Extensions"
Option "Composite" "Enable"
EndSection
dit heb ik geprobeert met driver 185.18.14
maar dat werkte niet
weet iemand welke driver ik moet gebruiken
ik krij nu steeds de foutmelding dat er al een standaard versie van de driver is geinstalleerd alleen deze werkt niet met de geforce iemand een idee
