Kan niet branden??
  • Onderwerp starter Onderwerp starter obl
obl
7 nov 2006
Ik kan met Nero niet branden. Dit is de log:
Uw gebruikersnaam
Uw bedrijfsnaam
Windows XP 5.1
IA32
WinAspi: -
ahead WinASPI: File 'C:\Program Files\Ahead\nero\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 26-10-2004 17:35:32
Nero Version: 6.6.0.16
Internal Version: 6, 6, 0, 16b
(Nero Express)
Recorder: <HL-DT-ST DVDRRW GWA-4164B>Version: 1.03 - HA 0 TA 3 - 6.6.0.16
Adapter driver: <nvata> HA 0
Drive buffer : 2048kB
Bus Type : default (0) -> ATAPI, detected: ?
CD-ROM: <PHILIPS DROM6216 >Version: DD08 - HA 0 TA 2 - 6.6.0.16
=== Scsi-Device-Map ===
DiskPeripheral : ST3160021A nvata Port 0 ID 0 DMA: Off
CdRomPeripheral : PHILIPS DROM6216 nvata Port 0 ID 2 DMA: Off
CdRomPeripheral : HL-DT-ST DVDRRW GWA-4164B nvata Port 0 ID 3 DMA: Off
CdRomPeripheral : Generic DVD-ROM 1.0 d347prt Port 3 ID 0 DMA: Off
=== CDRom-Device-Map ===
PHILIPS DROM6216 D: CDRom0
HL-DT-ST DVDRRW GWA-4164B E: CDRom1
Generic DVD-ROM J: CDRom2
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 83886080 (0) Byte
ShowDrvBufStat : 0
BUFE : 0
Physical memory : 1023MB (1048048kB)
Free physical memory: 421MB (431972kB)
Memory in use : 58 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
7.11.2006
ISO-compilatie
21:41:46 #1 Text 0 File Isodoc.cpp, Line 6356
Iso document burn settings
Determine maximum speed : FALSE
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Multisession : FALSE
Burning mode : DAO
Mode : 1
ISO Level : 1 (Max. of 11 = 8 + 3 char)
Character set : ISO 9660
Joliet : TRUE
Allow pathdepth more than 8 directories : TRUE
Allow more than 255 characters in path : TRUE
Write ISO9660 ;1 file extensions : TRUE
21:41:46 #2 Text 0 File Reader.cpp, Line 127
Reader running
21:41:46 #3 Text 0 File Writer.cpp, Line 122
Writer HL-DT-ST DVDRRW GWA-4164B running
21:41:46 #4 ISO9660GEN -11 File geniso.cpp, Line 3309
First writeable address = 0 (0x00000000)
21:41:46 #5 Text 0 File Burncd.cpp, Line 3233
Turn on Disc-At-Once, using DVD media
21:41:47 #6 Text 0 File DlgWaitCD.cpp, Line 270
Last possible write address on media: 2295103 (510:01.28, 4482MB)
Last address to be written: 2242095 (498:14.45, 4379MB)
21:41:47 #7 Text 0 File DlgWaitCD.cpp, Line 282
Write in overburning mode: NO (enabled: CD)
21:41:47 #8 Text 0 File DlgWaitCD.cpp, Line 2483
Recorder: HL-DT-ST DVDRRW GWA-4164B, Media type: DVD+R
Disc Manufacturer ID: CMC MAG, Media Type ID: E01, Product revision number: 0
Disc Application Code: 0, Extended Information Indicators: 3
21:41:47 #9 Text 0 File DlgWaitCD.cpp, Line 448
>>> Protocol of DlgWaitCD activities: <<<
21:41:47 #10 Text 0 File ThreadedTransferInterface.cpp, Line 838
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 ()
2 indices, index0 (150) not provided
original disc pos #0 + 2242096 (2242096) = #2242096/498:14.46
relocatable, disc pos for caching/writing not required/ required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2242096 blocks [HL-DT-ST DVDRRW GWA-4164B]
21:41:47 #11 Text 0 File ThreadedTransferInterface.cpp, Line 1051
Prepare recorder [HL-DT-ST DVDRRW GWA-4164B] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 4591812608, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_CtrlAdr_|_RecDep__________
0 | lead-in | 0 | 0x41 | 0x00
0 | 1 | 0 | 0x41 | 0x00
0 | 1 | 1 | 0x41 | 0x00
2242096 | lead-out | 1 | 0x41 | 0x00
21:41:47 #12 Phase 24 File dlgbrnst.cpp, Line 1832
Caching of files started
21:41:47 #13 Text 0 File Burncd.cpp, Line 4120
Cache writing successful.
21:41:47 #14 Phase 25 File dlgbrnst.cpp, Line 1832
Caching of files completed
21:41:47 #15 Phase 36 File dlgbrnst.cpp, Line 1832
Burn process started at 8x (11.080 kB/sec)
21:41:47 #16 Text 0 File ThreadedTransferInterface.cpp, Line 2654
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
21:41:47 #17 Text 0 File Cdrdrv.cpp, Line 8862
---- DVD Structure: Physical Format Information (00h) ----
Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD+R (10), Part Version: 1.0x (1)
Disc Size: 120 mm, Maximum Rate: <not specified> (F h)
Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
End Physical Sector Number of Data Area: 26053F h
End Sector Number in Layer 0: 0 h (LBN: FFFD0000 h, 4193920 MB)
Data in Burst Cutting Area (BCA) does not exist
Disc Application Code: 0 / 0 h
Extended Information indicators: 3 h
Disc Manufacturer ID: CMC.MAG.
Media type ID: E01
Number of Physical format information bytes in use in ADIP up to byte 63: 56
Media Specific [16..63]:
00 00 03 43 4D 43 20 4D - 41 47 00 45 30 31 00 38 ...CMC.MAG.E01.8
23 54 37 10 02 38 6A 02 - 88 67 15 15 0B 0B 08 08 #T7..8j..g......
01 19 1B 0C 0C 0C 0D 01 - 00 00 00 00 00 00 00 00 ................
21:41:47 #18 Text 0 File DVDR.cpp, Line 5135
Drive: HL-DT-ST DVDRRW GWA-4164B
Book Type request [LG]: DVD-ROM
Changing the Book Type was finished successfully, return code 0
21:41:47 #19 CDR -1211 File DVDR.cpp, Line 5056
Book Type set to: DVD-ROM
21:41:47 #20 Text 0 File DVDPlusRW.cpp, Line 665
Start write address at LBA 0
DVD high compatibility mode: Yes
21:44:38 #21 SCSI -1093 File Cdrdrv.cpp, Line 1434
SCSI Exec, HA 0, TA 3, LUN 0, buffer 0x07DE0000
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x03 (KEY_MEDIUM_ERROR)
Sense Code: 0x02
Sense Qual: 0x00
CDB Data: 0x2A 0x00 0x00 0x00 0x02 0xA0 0x00 0x00 0x20 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x03 0x00 0x00 0x00 0x00 0x0E
0x00 0x00 0x00 0x00 0x02 0x00
21:44:38 #22 CDR -1093 File Writer.cpp, Line 311
No seek complete
21:44:38 #23 Text 0 File ThreadedTransfer.cpp, Line 228
all writers idle, stopping conversion
21:44:38 #24 Text 0 File ThreadedTransfer.cpp, Line 222
conversion idle, stopping reader
21:44:38 #25 Phase 127 File dlgbrnst.cpp, Line 1832
Generating DVD high compatibility borders
21:44:38 #26 Phase 129 File dlgbrnst.cpp, Line 1832
Generating DVD borders completed successfully
21:44:39 #27 Phase 38 File dlgbrnst.cpp, Line 1832
Burn process failed at 8x (11.080 kB/sec)
Existing drivers:
File 'Drivers\PXHELP20.SYS': Ver=2.03.32a, size=20640 bytes, created 25-4-2005 10:03:00 (Prassi/Veritas driver for win 2K)
File 'Drivers\nvata.sys': Ver=5.10.2600.0552 built by: WinDDK, size=93568 bytes, created 18-8-2005 16:52:06 (Adapter driver for rec)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
Ik heb nu begrepen dat het wss ligt aan de no seek complete foutmelding. Wat betekent dat de gebruikte media niet goed is? Ik gebruik platinum dvd's. Tig dvd's mee gebrandt, maar nu werkt het ineens dus niet. Vorige week zelfde foutmelding, kwartiertje daarna geprobeerd en toen werkte het weer ineens met die platinum dvd's. Maar nu na drie dvd's wil het nog niet lukken. Kom er net achter dat m'n pc het ook gewoon herkent als cd's, snap daar helemaaaaaaaal niets van. Volgens mij is mijn pc goed ziek.
Probeer eens dit
Ga naar Start -> Uitvoeren, type daar in regedit en klik op OK.
Zoek naar : HKEY_LOCAL_MACHINE/System/Currentcontrolset/Control/Class/
Klik nu met rechter muisknop op de volgende sleutel {4d36e965-e325-11ce-bfc1-08002be10318} en kies voor Exporteren. Vul een naam in en blader naar de directory waar je de backup wilt plaatsen en klik op opslaan.
Verwijder nu in het rechter venster de sleutels met de volgende naam: UpperFilters en LowerFilters
Sluit het register en start de PC opnieuw op. Hij zal de verdwenen spelers nu opnieuw installeren.
Indien noodzakelijk mocht blijken kun je altijd de backup terugzetten door te dubbelklikken op dat bestand.
Probeer eens dit
Is dit echt nodig? Mijn pc spaced hem zowiezo al, al maanden heb ik er last van dat ie niet wil opstarten. Dan doe ik hem aan, krijg ik een irritante piep om de 3 seconden ofzo(geen beeld) en soms werkt het dan wel weer ineens. Het is een fujitsu siemens Scaleo nog geen half jaar oud, maar kan helaas geen aanspraak doen op de garantie.
Ik denk dat ik eerst maar ga kijken of het niet aan die dvd ligt. Want vorige week had ik die fout ook al en een kwartier daarna werkte het wel ineens. Heb geen dvd's van andere merken hier liggen. Dus morgen mss ff uitproberen. Wel vaag
Half jaar en geen garantie ???vreemd
Wat ik je voorstel kan geen kwaad.
En wil vaak wel een en ander oplossen.
Edit:Volgens mij staat in Bios ook je DMA uit
Heb wel garantie maar kan er geen aanspraak op doen, lang verhaal.
Hoe kan ik in mijn bios kijken dan of ie uit staat? En wat is DMA? :D
Dit is het foutje in de log:
Oftewel: die brander vindt dit medium "krom", het medium is echt krom, of je hebt de brandersnelheid te hoog staan en kunnen deze schijven dat niet aan....
Alternatief kan het zijn dat je lens vuil is..... haal eens een lenscleanerschijfje bij de platenboer en laat het een paar maal draaien
Ik moet toegeven, ik hoor wel hele rare geluiden. Ik heb branden staan op 8* horen ze aan te kunnen. Dan maar ff lenscleanerschijf proberen.
Maaaaaaaaaar, hij leest het zowiezo als cd!!! Daar gaat het al mis. Heeft dan zo'n lenscleanerschijf nog wel zin dan?
Kan! maar
Direct Memory Access (DMA) zorgt ervoor dat gegevens rechtstreeks van het geheugen naar de harde schijf kunnen worden geschreven en gelezen. Hierdoor wordt de processor ontlast.
Zodat de Buffer ook wat regelmatiger wordt en er minder fouten optreden
Oke, ik heb ff het volgende uitgevoerd.
Ik heb een originele dvd(Lama's) ingestopt en die herkent ie wel gewoon als dvd-film. Een reeds gebrande dvd heb ik er ook ingestopt en die herkent ie ook gewoon. Dus die herkenning zit wel goed toch? Misschien ligt het dan aan de dvd's, zou wel vaag zijn want ik heb er nog 70 over en heb willekeurig 4 lege al geprobeerd allemaal herkent ie als lege cd, van het merk Platinum overigens.
Wat kan ik dan nu het beste doen volgens jou BANDIT123?
