Sub tellen()
Dim rngToDo As Range
Set rngToDo = Range("J3:J200")
MsgBox "Let op! Er moeten " & IIf(SumByCFColorIndex(rngToDo, 3) = 0, "geen", SumByCFColorIndex(rngToDo, 3)) _
& " artikelen gekeurd worden."
Function SumByCFColorIndex(Rng As Range, CI As Integer)
Dim R As Range, Total As Double
For Each R In Rng.Cells
If ColorIndexOfCF(R, False) = CI Then
Total = Total + 1
Next R
SumByCFColorIndex = Total
End Function
Function ColorIndexOfCF(Rng As Range, Optional OfText As Boolean = False) As Integer
Dim AC As Integer
AC = ActiveCondition(Rng)
If AC = 0 Then
If OfText = True Then
ColorIndexOfCF = Rng.Font.ColorIndex
Else
ColorIndexOfCF = Rng.Interior.ColorIndex
Else
ColorIndexOfCF = Rng.FormatConditions(AC).Font.ColorIndex
Else
ColorIndexOfCF = Rng.FormatConditions(AC).Interior.ColorIndex
End Function
Function ActiveCondition(Rng As Range) As Integer
Dim Ndx As Long
Dim FC As FormatCondition
Dim Temp As Variant
Dim Temp2 As Variant
If Rng.FormatConditions.Count = 0 Then
ActiveCondition = 0
Else
For Ndx = 1 To Rng.FormatConditions.Count
Set FC = Rng.FormatConditions(Ndx)
Select Case FC.Type
Case xlCellValue
Select Case FC.Operator
Case xlBetween
Temp = GetStrippedValue(FC.Formula1)
Temp2 = GetStrippedValue(FC.Formula2)
If IsNumeric(Temp) Then
If CDbl(Rng.Value) >= CDbl(FC.Formula1) And _
CDbl(Rng.Value) <= CDbl(FC.Formula2) Then
ActiveCondition = Ndx
Exit Function
Else
If Rng.Value >= Temp And _
Rng.Value <= Temp2 Then
Exit Function
Case xlGreater
If CDbl(Rng.Value) > CDbl(FC.Formula1) Then
Exit Function
Else
If Rng.Value > Temp Then
Exit Function
Case xlEqual
If CDbl(Rng.Value) = CDbl(FC.Formula1) Then
Exit Function
Else
If Temp = Rng.Value Then
Exit Function
Case xlGreaterEqual
If CDbl(Rng.Value) >= CDbl(FC.Formula1) Then
Exit Function
Else
If Rng.Value >= Temp Then
Exit Function
Case xlLess
If CDbl(Rng.Value) < CDbl(FC.Formula1) Then
Exit Function
Else
If Rng.Value < Temp Then
Exit Function
Case xlLessEqual
If CDbl(Rng.Value) <= CDbl(FC.Formula1) Then
Exit Function
Else
If Rng.Value <= Temp Then
Exit Function
Case xlNotEqual
If CDbl(Rng.Value) <> CDbl(FC.Formula1) Then
Exit Function
Else
If Temp <> Rng.Value Then
Exit Function
Case xlNotBetween
If Not (CDbl(Rng.Value) <= CDbl(FC.Formula1)) And _
(CDbl(Rng.Value) >= CDbl(FC.Formula2)) Then
Exit Function
Else
If Not Rng.Value <= Temp And _
Rng.Value >= Temp2 Then
Exit Function
Case Else
Debug.Print "UNKNOWN OPERATOR"
End Select
Case xlExpression
If Application.Evaluate(FC.Formula1) Then
Exit Function
Case Else
Debug.Print "UNKNOWN TYPE"
End Select
Next Ndx
ActiveCondition = 0
End Function
Function GetStrippedValue(CF As String) As String
Dim Temp As String
If InStr(1, CF, "=", vbTextCompare) Then
Temp = Mid(CF, 3, Len(CF) - 3)
If Left(Temp, 1) = "=" Then
Temp = Mid(Temp, 2)
Else
Temp = CF
GetStrippedValue = Temp
End Function
