Muziek ripprogramma
Nascada
17 feb 2007
Kijk, Audacity is een geweldig programma. Je kan muziek er op heel veel manieren mee mixen. Maar hij valt mij toch tegen. Ik mix daar de leukste liedjes, die opgeslagen worden met een .aup bestand. Ik heb deze problemen :
1. ik kan de bestanden niet over msn. versturen (ookal heeft die persoon ook Audacity)
2. ik kan de bestanden niet openen in videomakers (bijv. Nero Version)
Ik zoek dus een ander mixprogramma, zodat die twee problemen opgelost zijn. ;)
groeten Nascada
In de handleiding van Audacity zelf (ik heb er nog nooit mee gewerk hoor) staan standaard de volgende mogelijkheden:
Export As WAV... - exports all of the audio in your project as a WAV file, an industry-standard format for uncompressed audio. You can change the standard file format used for exporting from Audacity by opening the File Format Preferences . Note that exporting will automatically mix and resample if you have more than one track, or varying sample rates. See also File Formats.
Export Selection As WAV... - same as above, but only exports the current selection.
Export as MP3... - exports all of the audio as an MP3 file. MP3 files are compressed and therefore take up much less disk space, but they lose some audio quality. Another compressed alternative is Ogg Vorbis (below). You can set the quality of MP3 compression in the File Format Preferences. See alsoMP3 Exporting.
Export Selection As MP3... - same as above, but only exports the current selection.
Export as Ogg Vorbis... - exports all of the audio as an Ogg Vorbis file. Ogg Vorbis files are compressed and therefore take up much less disk space, but they lose some audio quality. Ogg Vorbis files tend to take up a little less disk space than MP3 for similar compression quality, and Ogg Vorbis is free from patents and licensing restrictions, but Ogg Vorbis files are not as widespread. You can set the quality of Ogg compression in the File Format Preferences.
Export Selection As Ogg Vorbis... - same as above, but only exports the current selection.
Is het probleem daar niet simpel mee opgelost?
Dan gebruik je Audacity niet te volle.
Wanneer je een mix of wat dan ook klaar hebt, exporteer je het als MP3 of .wav
Dat kan je gewoon versturen hoor.
Vandaar dat er regelmatig wordt aangeraden om de manual eens te lezen.
nee nietecht, ik ben niet zogoed in engens XD (ben 13 ;P)
Dat is het juist !! :( ik kan het niet als mp3 of wav opslaan, alleen als .aup :S
Maar we hebben het ook niet over opslaan, maar over exporteren!
Dus eerst opslaan als .aup bestand en daarna dat bestand exporteren als .wav, .MP3 enz.
okey....en hoe doe je dat ? :D sorry ik ben een beetje dom, maar ik weet nietecht wat exporteren is :p
Wanneer je klaar bent met een mix of wat ook, selecteer je hele geluidsbestand.
Dan ga je naar bestand en exporteren.
