lg gsa-4120b brandt geen dual layer
houseguru
27 sep 2005
beste mensen,
sinds vandaag probeer in een dual layer dvd te branden. dit gaat echter niet zoals het hoort. ik heb platinum en verbatim schijfjes gebruikt om te kijken of het aan de media ligt.
4,7 gb dvd''s branden en cd's lukt wel, brander is dus niet kapot. ik heb geprobeerd te branden met nero, imgburn, clonecd maar niks werkt. brandsnelheid maakt ook niks uit evenals de booktype/bitsettings.
dit is de foutmelding die imgburn geeft :
I 22:29:57 ImgBurn Version 2.3.2.0 started!
I 22:29:57 Microsoft Windows XP Home Edition (5.1, Build 2600 : Service Pack 2)
I 22:29:57 Total Physical Memory: 1.047.280 KB - Available: 600.584 KB
I 22:29:57 Initialising SPTI...
I 22:29:57 Searching for SCSI / ATAPI devices...
I 22:29:57 Found 1 DVD-ROM and 1 DVD±RW/RAM!
I 22:38:04 Operation Started!
I 22:38:04 Source File: D:\games\xbox360\NFSMW\need.dvd
I 22:38:04 Source File Sectors: 3.697.696 (MODE1/2048)
I 22:38:04 Source File Size: 7.572.881.408 bytes
I 22:38:04 Source File Volume Identifier: XBOX360
I 22:38:05 Source File Implementation Identifier: Daikin U.S. Comtec Lab
I 22:38:05 Source File File System(s): ISO9660; UDF (1.02)
I 22:38:05 Destination Device: [1:0:0] HL-DT-ST DVDRAM GSA-4120B A116 (F:) (ATA)
I 22:38:05 Destination Media Type: DVD+R DL (Disc ID: MKM-003-00) (Speeds: 4x)
I 22:38:05 Destination Media Sectors: 4.173.824
I 22:38:05 Write Mode: DVD
I 22:38:05 Write Type: DAO
I 22:38:05 Write Speed: 4x
I 22:38:05 Link Size: Auto
I 22:38:05 Test Mode: No
I 22:38:05 BURN-Proof: Enabled
I 22:38:05 Optimal L0 Data Zone Capacity: 1.913.760
I 22:38:05 Optimal L0 Data Zone Method: Copied From Original Disc
I 22:39:22 Filling Buffer... (40 MB)
I 22:39:24 Writing LeadIn...
W 22:39:49 Failed to Write Sectors 544 - 575 - Write Error
W 22:39:49 Retrying (1 of 20)...
W 22:39:49 Retry Failed - Write Error
W 22:39:49 Retrying (2 of 20)...
W 22:39:49 Retry Failed - Invalid Address For Write
W 22:39:49 Retrying (3 of 20)...
W 22:39:49 Retrying (4 of 20)...
W 22:39:49 Retrying (5 of 20)...
W 22:39:49 Retrying (6 of 20)...
W 22:39:49 Retrying (7 of 20)...
W 22:39:49 Retrying (8 of 20)...
W 22:39:49 Retrying (9 of 20)...
W 22:39:49 Retrying (10 of 20)...
W 22:39:49 Retrying (11 of 20)...
W 22:39:49 Retrying (12 of 20)...
W 22:39:49 Retrying (13 of 20)...
W 22:39:49 Retrying (14 of 20)...
W 22:39:49 Retrying (15 of 20)...
W 22:39:49 Retrying (16 of 20)...
W 22:39:49 Retrying (17 of 20)...
W 22:39:49 Retrying (18 of 20)...
W 22:39:49 Retrying (19 of 20)...
W 22:39:49 Retrying (20 of 20)...
E 22:39:52 Failed to Write Sectors 544 - 575 - Write Error
I 22:39:52 Synchronising Cache...
I 22:39:53 Closing Track...
I 22:41:08 Finalising Disc...
W 22:41:45 Potential 'WaitImmediateIO' Deferred Error - (0/2) - Write Error
E 22:47:54 Finalise Disc Failed! - Reason: Write Error
I 22:47:54 Finalising Disc (Last Attempt!)...
E 22:49:08 Finalise Disc Failed! - Reason: Write Error
E 22:49:08 Failed to Write Image!
E 22:49:08 Operation Failed! - Duration: 00:11:03
I 22:49:08 Average Write Rate: 0 KB/s (0.0x) - Maximum Write Rate: 0 KB/s (0.0x)
iemand een idee hoe ik dit op kan lossen?
heb alle brandprogrammas behalve imgburn verwijderd, virtuele schijven uitgescakeld etc.
firmware is ook up to date
Kijk ook voor de zekerheid in Apparaatbeheer, IDE ATA/ATAPI controllers, klik rechts daarop, kies Eigenschappen en dan Geavanceerde instellingen. Staan de twee keer Overdrachtmodi op "DMA, indien beschikbaar"?
Mijn suggestie:
'Brand' eerst eens een image van die originele dvd/cd op je harde schijf, zodat je zeker weet dat niet de schijf die je kopieren wilt het probleem vormt (beveiligingen, leesfouten etc.)
Brand daarna dat image op een echte recordable.
Tijs.
ja, zowel bij primair ide-kanaal als secundair ide-kanaal staan ze op DMA indien beschikbaar als overdrachtsmodus.
vind het toch vreemd dat hij alles brandt behalve dual layer.
heb meerdere .dvd/ iso files gebrobeerd te branden, ook alleen de iso geprobeerd en dan handmatig de layer break ingesteld. Dit mag allemaal niet baten helaas.
zal eens de laatste firmware erop knallen, heb nu de een na laatste maar dat zou eigenlijk niet mogen uitmaken volgens mij
ImgBurn rapporteert een schrijffout (E 22:39:52 Failed to Write Sectors 544 - 575 - Write Error), maar waarom is me niet duidelijk.
Ik heb in de ImgBurn forum's rondgekeken.
Misschien kun je zelf nog wat verder kijken daar, of je vraag stellen?
