2gb ram meer dan genoeg voor Vista!
mrmusic
Inventaris
29 okt 2006
Speciaal voor iedereen die zich afvraagt hoeveel ram geheugen Vista nu echt nodig heeft om soepel te draaien en alle indianen-verhalen hierover, onderstaand de gecopieerde tekst van een (Engels-talig) artikel hierover met bijbehorende test, een echte eye-opener:
I’ve got a lot of experience with different PC configurations, and I can say with confidence that 2GB is more than enough for even the most demanding business user. There are two important exception to that rule: If you use one or more virtual machines in the same session, you’ll benefit from as much RAM as you can install, and 2GB probably won’t be enough. You’ll also need (and want) the extra RAM if you run 64–bit Windows Vista, a topic I’ll get to shortly. First, let’s talk about that 2GB configuration.
I’ve used Vista on more than a dozen machines from at least six manufacturers. Currently, my working machines are an Asus Tablet PC and a Dell XPS 410 desktop, both with 2GB of memory. In more than a month of sometimes insanely heavy use with each one, I have never reached a state where either one performed unacceptably because it was gasping for RAM. It’s really, really difficult to use 2GB of RAM with any edition of Windows Vista. At the moment, as you can see from the Task Manager snippet on the right, I’m running 81 processes on this desktop PC, including the following:
* Two instances of Internet Explorer 7 with a total of 40 tabs open (note that this load would have brought the system to its knees if I hadn’t also increased the size of the desktop heap)
* Firefox 2.0.0.6 with five Ajax-heavy tabs in use
* Adobe Acrobat Standard
* Outlook 2007, with a 610MB OST file synching with an Exchange Server about 2000 miles away
* Two remote sessions, one to Windows Home Server (via its own console), the other to Windows Server 2008 (via Remote Desktop).
* OneNote, with 90MB of notebook files open
* Four Windows Sidebar gadgets
* Windows Media Player, connected to a library of 20,000 songs and pictures stored on a Vista-based media server in the living room
* 11 Windows Explorer windows representing local folders, network shares, searches, and bits of the Windows Control Panel like the Installed Programs list, Network and Sharing Center, and Sync Center
* A bunch of useful programs running in the background, including RoboForm, ClipMate, SnagIt, the Windows Home Server Connector, and Windows Live Messenger
* Oh, and I’m composing this in Windows Live Writer
That’s a lot of stuff, but I’m not even close to using up the 2GB of RAM installed on this machine. According to Task Manager, 1.44GB are in use by all processes from all users, including caches and indexing tasks and other system functions. From experience, I know I could open another half-dozen programs and rip a music CD and still not notice any change in performance.
If you use a similar mix of apps, you should see similar results. For that type of heavy multitasking, the bump from 1GB to 2GB has a clear impact and costs very little. But adding an extra 2GB beyond that doesn’t usually result in any noticeable improvement in performance or reliability.
Lijkt mij sterk. Het is wel genoeg hoor 2gb, maar als je zoveel tegelijk doet? Ga maar eens zwaar video bewerken en deze daarna opslaan, comprimeren etc. Dan zit je al rap aan je 2gb (HD VIdeo).
En ik denk dat de rest van je configuratie belangrijk is om volledig profijt te kunnen trekken van die 2 GB. Als voorbeeld: Je kan 2 GB bijvoorbeeld in een P3 stoppen. (voordat ik commentaar krijg, dit is een voorbeeld) of in een pc met een quadcore processor. De presties die je dan krijgt zijn toch heel anders.
