Foxconn Motherboard 6627MA-RS2H SiS 662 LGA775 FSB800MHz 2DDR2 SATA RAID Video Audio 10/100 LAN MATX
Detail Specifications
Processor - Intel Pentium D, Pentium 4, Celeron D processors, Socket T (LGA775)
Chipset - SIS 662 + 966L
Front Side Bus - 800 / 533 MHz FSB
Memory - DDRII 667 / 533 / 400 x2 DIMMs, Max 2GB
VGA on Die - Integrated
Expansion Slots - 1 x PCIe x16, 1 x PCIe x1, 2 x PCI
IDE - PATA 133 x 2
Serial ATA(SATA)/RAID - SATA x 2 with RAID 0 , 1 , JBOD
Audio - 5.1 channel, AC 97 Interface, Realtek ALC653
LAN - 10/100 M LAN, Realtek (RLT 8100C)
Back Panel I/O Ports
-1 x PS/2 keyboard, 1 x PS/2 mouse
-4 x USB 2.0 ports, 1 x RJ45 port
-1 x parallel port, 1 x serial port
-1 set 5.1 channel Audio jack (3 jacks)
-1 x VGA
Internal I/O Connectors
-2 x USB 2.0 headers; support 4 ports
-1 x S/PDIF out header (reserve)
-1 x CD-IN header
-1 x COM2 header (reserve)
-1 x IrDA header (reserve)
-1 x speaker header (reserve)
-1 x front audio header
-1 x buzzer
-1 x TPM 1 x AUX IN
-1 x Front panel
BIOS Features
4Mb flash ROM, PnP1.0a, DMI 2.0, WfM 2.0, SMBIOS 2.3, ACPI 1.0b
Support CD
Drivers, DirectX, Adobe Reader, SuperUtilities, Norton Internet Security, Live update, Wordperfect
Standards/Manageability - PCI 2.3, USB2.0; WfM 2.0, DMI 2.0
Special Features - SuperUtilities Liveupdate
Form Factor - Micro ATX (9.6" x 8.9")
Software: drivers voor moederbord
Geheugen totaal 2048 MB DDR2 PC533 TA 100% getest geheugen
Harde schijf 300 GB 7200 RPM HARDE SCHIJF MAXTOR MET 16 MB CACHE!! TOPMERK
LAN netwerkkaart on Board, 10/100Mbit
Geluidskaart 5.1 kanaals on Board
Grafische Interface PCI-e 16x SLOT on Board, + VGAkaart on board, 128 mb (shared) SIS Mirage 1
The integrated Mirage™ 1 graphic engine features a 3D, a 2D Graphics engine, a video accelerator, a MPEG I/II motion compensation decoder, and a High Definition Vedio (combined with PCIe port) to support TV-out & digital flat panels. To maintain a cost-effective PC system, SiS662 adopts the UMA, and eliminates the need and thus the cost of the frame buffer memory by organizing the frame buffer in the system memory from programming the system BIOS.
The integrated Mirage™ 1 graphic engine integrates a high performance / high quality 2-pixel pipelined 3D graphics engine comprising a programmable 512KB to 4MB Command Queue sustaining zero-wait 3D-command acceptance, a 32 bit floating point Setup Engine specially designed to fit the entire Microsoft Direct3D API data formats and a built-in Texture Cache significantly improving texture mapping performance. It also integrates a 128 bit 2D accelerator with a 1T pipeline BITBLT engine.
USB 2.0, 4 x on Board, 2 x extra in uw kast
DVDbrander +/- DVD/speler/CDBrander/Rewriter LITEON, 20 SPEED double layer dvd+ dvd- BRANDER (met NERO 7 software!!)
Schrijven (DVD+R) 20 x
Schrijven (DVD-R) 20 x
Schrijven (DVD+R9) 8 x
Schrijven (DVD-R9) 8 x
Schrijven (CD-R) 48 x
Herschrijven (DVD+RW) 8 x
Herschrijven (DVD-RW) 6 x
Herschrijven (CD-RW) 32 x
Lezen (DVD-ROM) 16 x
Lezen (CD-ROM) 40 x
Toegangstijd (DVD) -
Toegangstijd (CD) -
Buffer 2 MB
Aansluiting IDE / ATAPI
Ondersteunt DVD formaten: DVD-ROM, DVD-R, DVD-RW, DVD+RW, DVD+R, DVD+R DL, DVD-R DL, DVD RAM
CD formaten: CD Extra, CD-DA (audio), CD-I, CD-ROM XA, Photo CD, Video CD, CD-ROM, CD+G (Karaoke CD)
een betere vraag wat zijn de overige specs van de pc?
