Privacywetgeving
Private Sub Calendar1_Click()
ActiveCell.Value = CDbl(Calendar1.Value)
ActiveCell.NumberFormat = "dd/mm/yyyy"
ActiveCell.Select
Private Sub Worksheet_SelectionChange(ByVal Target As Range)
If Target.Cells.Count > 1 Then Exit Sub
If Not Application.Intersect(Range("A1:A10000"), Target) Is Nothing Then
Calendar1.Left = Target.Left + Target.Width - Calendar1.Width
Calendar1.Top = Target.Top + Target.Height
Calendar1.Visible = True
' select Today's date in the Calendar
Calendar1.Value = Date
Else: Calendar1.Visible = False
' ISO norm
Private Sub Calendar1_DblClick()
'This will insert the Weeknumber / Weekday in the cell
ActiveCell.Value = "W/D " & IsoWeekNum(Calendar1.Value) & " - " & _
Application.WorksheetFunction.Weekday(Calendar1.Value, 2)
ActiveCell.Select
Public Function IsoWeekNum(d1 As Date) As Integer
' Daniel Maher
Dim d2 As Long
d2 = DateSerial(Year(d1 - Weekday(d1 - 1) + 4), 1, 3)
IsoWeekNum = Int((d1 - d2 + Weekday(d2) + 5) / 7)
End Function
PS : dit is nachttarief aan het worden![]()
