// Filename: sortTable.js
// Description: This javascript file can be applied to convert record tables
// in a HTML file to be client-side sortable by associating title columns with
// sort events.
// COPYRIGHT (C) 2001 HAN J. YU, LIPING DAI
// THIS PROGRAM IS FREE SOFTWARE; YOU CAN REDISTRIBUTE IT AND/OR MODIFY IT
// UNDER THE TERMS OF THE GNU GENERAL PUBLIC LICENSE AS PUBLISHED BY THE FREE
// SOFTWARE FOUNDATION; EITHER VERSION 2 OF THE LICENSE, OR (AT YOUR OPTION)
// ANY LATER VERSION. THIS PROGRAM IS DISTRIBUTED IN THE HOPE THAT IT WILL BE
// USEFUL, BUT WITHOUT ANY WARRANTY; WITHOUT EVEN THE IMPLIED WARRANTY OF
// MERCHANTABILITY OF FITNESS FOR A PARTICULAR PURPOSE. SEE THE GNU GENERAL
// PUBLIC LICENSE FOR MORE DETAILS.
// YOU SHOULD HAVE RECEIVED A COPY OF THE GNU GENERAL PUBLIC LICENSE ALONG
// WITH THIS PROGRAM; IF NOT, WRITE TO:
// THE FREE SOFTWARE FOUNDATION, INC.,
// 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA
// Bugs/Comments: han@velocityhsi.com
// Change History:
// 11-26-01:
// o Made a few more settings configurable (i.e. data delimiter etc).
// o Added a check for the browser type/version (>= IE 5.0 allowed).
// 11-27-01:
// o Used document.getElementById method to retrieve object
// o Now supports both IE 5.0 or greater and Netscape 6.0 or greater
// 11-28-01:
// o Fixed the status display for Netscape.
// o Fixed the cursor shape for Netscape. Used pointer instead of hand.
// 11-29-01:
// o Fixed a cursor bug for IE 5.5
// sortTable.js
// This script contains useful functions that can be used to convert ordinary
// tables into sortable tables by modifying the HTML sources.
// Here is how one can do that. The following assumptions are required
// for the tables to be sorted.
// 1. All the record columns must be the same lengh. Otherwise (i.e. the ones
// that contain colspan) the rows will be ignored.
// 2. Row spans can not happen in the record rows though column spans
// can be one of the record rows.
// 3. Row-spanned single column will be considered as title.
// To enable the sorting, simply include this javascript source file and
// add an onLoad event to the <body> like below:
// <body onLoad='initTable("table1");initTable("table2");' ...>
// Note that all the tables that need to be sorted MUST contain ID tag.
// So, if they do not exist, you must create one for each table that
// needs to be sorted.
// Global variables
var table; // Table object
var rowArray = new Array(); // Data row array
var titleRowArray = new Array(); // Contains title texts
var titleRowCellArray = new Array(); // Dynamically constructed title cells
var titleSpanCellArray = new Array(); // Title elelments from row-spanned
var colSpanArray = new Array(); // Rows col-spanned
var colTitleFilled = new Array(); // Indicates whether title is filled
var sortIndex; // Selected index for sort
var descending = false; // Descending order
var nRow, actualNRow, maxNCol; // Various table stats
var origColor; // Holds original default color
var isIE; // True if IE
var linkEventString = // What's insider <a> tag
'onMouseOver=\'setCursor(this);' +
'setColor(this,"selected");\' ' +
'onMouseOut=\'setColor(this,"default");\' ' +
'onClick=\'sortTable(';
// Configurable constants
var ascChr = "^"; // Symbol for ascending sort
var desChr = "v"; // Symbol for descending sort
var selectedColor = "blue"; // Color for sort focus
var defaultColor = "black"; // Default color for sort off-focus
var recDelimiter = '|'; // Char used as a record separator
var titleFace = 'b'; // Specifies the HTML tag for titles
var updownColor = 'gray'; // Specified the color for up/downs
// Main function. This is to be associated with onLoad event in <BODY>.
// IMPORTANT: This is the only function that needs to be included in the pages
// to be sorted. The rest of the functions are simply called by this
// function.
function initTable(obj)
// Check whether it's viewed by IE 5.0 or greater
if (! checkBrowser()) return;
// Local variables
var countCol;
var nChildNodes;
var innerMostNode;
var nColSpan, nRowSpannedTitleCol, colPos;
var cell, cellText;
var titleFound = false;
var rNRowSpan, rNColSpan;
// Initializing global table object variable
if (obj.tagName == "TABLE")
// Assumes that the obj is THE OBJECT
table = obj;
else
// Assumes that the obj is the id of the object
table = document.getElementById(obj);
// Check whether it's an object
if (table == null) return;
// Check whether it's a table
if (table.tagName != "TABLE") return;
// Initializing the max col number with the size of last data row
maxNCol = table.rows[table.rows.length-1].cells.length;
// Initializing arrays
for (var i=0; i<maxNCol; i++)
colTitleFilled[i] = false;
// Setting the number of rows
nRow = table.rows.length;
// Should have at least 1 row
if (nRow < 1) return;
// Initialization of local variables
actualNRow = 0; // Number of actual data rows
rNRowSpan = 0; // Remaining rows in the row span
rNColSpan = 0; // Remaining cols in the col span
nRowSpannedTitleCol = 0; // Number of title cols from row span
// Loop through rows
for (var i=0; i<nRow; i++)
nColSpan = 1, colPos = 0;
// Loop through columns
// Initializing
for (var j=0; j<table.rows[i].cells.length; j++)
// Do this iff title has not been found
if (titleFound == false)
if (table.rows[i].cells[j].rowSpan > 1)
if (table.rows[i].cells[j].colSpan < 2)
titleSpanCellArray[colPos] =
table.rows[i].cells[j];
colTitleFilled[colPos] = true;
nRowSpannedTitleCol++;
if (table.rows[i].cells[j].rowSpan - 1
> rNRowSpan)
rNRowSpan =
table.
rows[i].cells[j].
rowSpan - 1;
if (table.rows[i].
cells[j].colSpan > 1)
rNColSpan =
rNRowSpan + 1;
if (table.rows[i].cells[j].colSpan > 1 &&
rNColSpan == 0)
nColSpan = table.rows[i].cells[j].colSpan;
colPos += nColSpan;
else
colPos++;
// Setting up the title cells
if (titleFound == false && nColSpan == 1 &&
rNRowSpan == 0 && rNColSpan == 0 && titleFound == false)
colSpanArray[i] = true;
titleFound = true;
// Using indivisual cell as an array element
countCol = 0;
for (var j=0;
+ nRowSpannedTitleCol; j++)
if (colTitleFilled[j] != true)
titleRowCellArray[j] =
table.rows[i].cells[countCol];
countCol++;
else
titleSpanCellArray[j];
// Setting up the data rows
else if (titleFound == true && nColSpan == 1 && rNRowSpan == 0)
// Can't have row span in record rows ...
if (table.rows[i].cells[j].rowSpan > 1) return;
nChildNodes =
table.rows[i].
cells[j].firstChild.childNodes.
length;
innerMostNode =
table.rows[i].
cells[j].firstChild;
while ( nChildNodes != 0)
innerMostNode =
innerMostNode.
firstChild;
nChildNodes =
innerMostNode.
childNodes.
length;
if (j == 0)
rowArray[actualNRow] =
innerMostNode.data;
else
rowArray[actualNRow] += recDelimiter +
innerMostNode.data;
// Inconsistent col lengh for data rows
if (table.rows[i].cells.length > maxNCol)
return;
actualNRow++;
colSpanArray[i] = false;
else if (nColSpan == 1 && rNRowSpan == 0 &&
else
// Counters for row/column spans
if (rNRowSpan > 0) rNRowSpan--;
if (rNColSpan > 0) rNColSpan--;
// If the row number is < 1, no need to do anything ...
if (actualNRow < 1) return;
// Re-drawing the title row
for (var j=0; j<maxNCol; j++)
// If for some reason, the rows do NOT have any child, then
// simply return ...
if (titleRowCellArray[j].childNodes.length == 0) return;
if (titleRowCellArray[j].firstChild != null)
nChildNodes =
firstChild.childNodes.length;
innerMostNode =
titleRowCellArray[j].firstChild;
innerMostNode =
innerMostNode.firstChild;
nChildNodes =
innerMostNode.
childNodes.
length;
cellText = innerMostNode.data;
else
cellText = "column(" + j + ")";
titleRowArray[j] = cellText;
titleRowCellArray[j].innerHTML =
'<a ' +
linkEventString +
j + ',' + '"' + table.id + '"' + ');\'>' +
'<' + titleFace + '>' + cellText +
'</' + titleFace +'></a>';
// Function called when user clicks on a title to sort
function sortTable(index,obj)
// Re-inializing the table object
initTable(obj);
// Local variables
var nChildNodes;
var innerMostNode;
var rowContent;
var rowCount;
var cell, cellText;
var newTitle;
// Can't sort past the max allowed column size
if (index < 0 || index >= maxNCol) return;
// Assignment of sort index
sortIndex = index;
// Doing the sort using JavaScript generic function for an Array
rowArray.sort(compare);
cellText = titleRowArray[j];
cellText = '<' + titleFace +'>' +
cellText + '</' + titleFace + '></a>';
newTitle = '<a ' +
linkEventString +
cellText +
'</a>';
if (j == sortIndex)
newTitle += ' <font color=' + updownColor + '>';
if (descending)
newTitle += desChr;
else
newTitle += ascChr;
newTitle += '</font>';
titleRowCellArray[j].innerHTML = newTitle;
// Re-drawing the table
rowCount = 0;
if (! colSpanArray[i])
rowContent = rowArray[rowCount].
split(recDelimiter);
nChildNodes =
table.rows[i].cells[j].firstChild.
childNodes.length;
innerMostNode =
table.rows[i].cells[j].firstChild;
innerMostNode =
nChildNodes =
innerMostNode.
childNodes.
length;
innerMostNode.data = rowContent[j];
rowCount++;
// Switching btw descending/ascending sort
if (descending)
descending = false;
else
descending = true;
// Function to be used for Array sorting
function compare(a, b)
// Getting the element array for inputs (a,b)
var aRowContent = a.split(recDelimiter);
var bRowContent = b.split(recDelimiter);
// Needed in case the data conversion is necessary
var aToBeCompared, bToBeCompared;
if (! isNaN(aRowContent[sortIndex]))
aToBeCompared = parseInt(aRowContent[sortIndex], 10);
else
aToBeCompared = aRowContent[sortIndex];
if (! isNaN(bRowContent[sortIndex]))
bToBeCompared = parseInt(bRowContent[sortIndex], 10);
else
bToBeCompared = bRowContent[sortIndex];
if (aToBeCompared < bToBeCompared)
if (!descending)
return -1;
else
return 1;
if (aToBeCompared > bToBeCompared)
if (!descending)
return 1;
else
return -1;
return 0;
// Function to set the cursor
function setCursor(obj)
// Show hint text at the browser status bar
window.status = "Sort by " + obj.firstChild.innerHTML;
// Change the mouse cursor to hand or pointer
if (isIE)
obj.firstChild.style.cursor = "hand";
else
obj.firstChild.style.cursor = "pointer";
// Function to set the title color
function setColor(obj,mode)
if (mode == "selected")
// Remember the original color
if (obj.style.color != selectedColor)
defaultColor = obj.style.color;
obj.style.color = selectedColor;
else
// Restoring original color and re-setting the status bar
obj.style.color = defaultColor;
window.status = '';
// Function to check browser type/version
function checkBrowser()
if (navigator.appName == "Microsoft Internet Explorer"
&& navigator.appVersion.indexOf("5.") >= 0)
isIE = true;
return true;
// For some reason, appVersion returns 5 for Netscape 6.2 ...
else if (navigator.appName == "Netscape"
isIE = false;
return true;
else
return false;
