activeringscode
savant11
7 jan 2008
oke, nu heb ik dit voor register.php:
PHP:
<?php
include("connection.php"); // maakt contact met de databse
session_start();// zodat alle sessie variabelen beschikbaar zijn
if(isset($_POST['submit']))
$voornaam = addslashes(trim($_POST['voornaam']));
$tussenvoegsel = addslashes(trim($_POST['tussenvoegsel']));
$achternaam = addslashes(trim($_POST['achternaam']));
$geboortedatum =  addslashes(trim($_POST['geboortedatum']));
$postcode =  addslashes(trim($_POST['postcode']));
$land =  addslashes(trim($_POST['land']));
$username = addslashes(trim($_POST['username']));
$email = addslashes(trim($_POST['email']));
$pass = addslashes(trim($_POST['password']));
$conf = addslashes(trim($_POST['confirm']));
$ip = $_SERVER['REMOTE_ADDR'];
$date = date("d, m y");
if ( $_POST['password'] == $_POST['confirm'] )
{}else{
echo '<script>alert("Your passwords were not the same, please enter the same password in each field.");</script>';
echo '<script>history.back(1);</script>';
exit;
$password = md5($pass);
if ((((( empty($voornaam) ) || ( empty($achternaam) ) || ( empty($username) ) || ( empty($email) ) || ( empty($password) )))))
echo '<script>alert("One or more fields was left empty, please try again.");</script>';
exit;
if((!strstr($email , "@")) || (!strstr($email , ".")))
echo '<script>alert("You entered an invalid email address. Please try again.");</script>';
exit;
$q = mysql_query("SELECT * FROM gebruikers WHERE username = '$username'") or die(mysql_error());
if(mysql_num_rows($q) > 0)
echo '<script>alert("The username you entered is already in use, please try again.");</script>';
exit;
$name = $voornaam . ' ' . $achternaam;
//$actkey = mt_rand(1, 500).'f78dj899dd';
//$act = sha1($actkey);
//******************BEGIN*************************************************************
//  Hier wordt de unieke sleutel gecreeerd voor de link
function randomstring($len)
   srand(date("s"));
   while($i<$len)
       $str.=chr((rand()%26)+97);
       $i++;
   $str=$str.substr(uniqid (""),0,22);
   return $str;
// Now generate the 6-digit code
$actkey = randomstring(6);    // 6 for a 6-digit code
$actkey = substr("$actkey", 0, 6);    // added to fix bug.
function generateHash ( $length )
        $chars    = 'abcdefghijklmnopqrstuvwxyz23456789';
        $numChars = strlen ( $chars );
        $string = '';
        for ( $i = 0; $i < $length; $i++ )
            $string .= substr ( $chars, rand ( 1, $numChars ) - 1, 1 );
        return sha1($string);
//***************EINDE*************************************************************************
//***************************************************BEGIN*********************************************************************************************
//Stuurt de gebruiker een mail met daarin de gegevens en een link om zich te activeren!!
$query = mysql_query("INSERT INTO gebruikers (username, password, voornaam,achternaam,tussenvoegsel,geboortedatum,
postcode,land,geslacht, email,ip,actkey,active)
VALUES ('$username','$password','$voornaam','$achternaam','$tussenvoegsel','$geboortedatum'
,'$postcode','$land','$geslacht','$email','$ip','$actkey','$active')") or die(mysql_error());
$send = mail($email , "Registration Confirmation" , "Thank you for registering by Coinnovation!.\n\n
Your username and password is below, along with details on how to activate your account.\n\nUser:
".$username."\nPass: ".$pass."\n\nClick the link below to activate your account:
\nhttp://localhost/www/hsleiden/project2_2007/php/login2/activate.php?id=".$actkey."     \n\n
Please do not reply, this is an automated mailer.\n\nThanks", "FROM: [email]nengelen@orange.nl[/email]");
$code = generateHash(10);
    // De code genereren.
        $insertact = "INSERT INTO activation (id_user, sha1) VALUES (".$id.", '".$code."')";
// De net-geregistreerde user met z'n code in de tabel 'activation' zetten.
$actresult = mysql_query($insertact);
$titel = "Activatiecode";
$boodschap =
"Beste blabla,
Uw activatielink.
http://localhost/www/hsleiden/project2_2007/php/login2/activate.php?id=$id&activation=$code&type=login_activation
$ok = mail($mail, $titel, $boodschap, "FROM:  <nengelen@orange.nl>");
//****************************************************EINDE********************************************************************************************
if(($query)&&($send))
echo ' <html>
<head>
<title>Success</title>
<link href="style.css" rel="stylesheet" type="text/css">
</head>
<body>
<div id="success">
<p>Thank you for registering, you will recieve an email
soon with your login details and your activation link so that you can activate your account.</p>
<p><a href="login.php">Click here</a> to login once you have activated.</p>
</div>
</body>
</html>
} else {
echo '
<html>
<head>
<title>Error</title>
</head>
<body>
<div id="error">
<p>We are sorry, there appears to be a problem with our script at the moment.</p>
<p>Your data was not lost. Username: '.$username.' | Password: '.$pass.' | Email: '.$email.' | Full name: '.$name.'</p>
<p>Please try again later.</p>
</div>
</body>
</html>
} else {
mysql_close();
<!-- *************************************REGISTRATIE FORMULIER*****************************************************************************-->
<html>
<head>
<title>Register</title>
</head>
<body>
<div id="wrapper">
<div id="head">Registratie pagina</div>
<br>
<div id="main">
<p>Je kan je hier geristreren! </p>
<form action="<?= $_SERVER['PHP_SELF'] ?>" method="post">
<table width="100%" border="0" cellpadding="0" cellspacing="0">
<tr>
<td width="50%">Voornaam </td>
<td width="50%"><input name="voornaam" type="text" id="voornaam"></td>
</tr>
<tr>
<td width="50%">Tussenvoegsel </td>
<td width="50%"><input name="tussenvoegsel" type="text" id="tussenvoegsel"></td>
</tr>
<tr>
<td>Achternaam</td>
<td><input name="achternaam" type="text" id="achternaam"></td>
</tr>
<tr>
<td width="50%">Geboortedatum </td>
<td width="50%"><input name="geboortedatum" type="text" id="geboortedaum"></td>
</tr>
<tr>
<td width="50%">Land </td>
<td width="50%"><input name="land" type="text" id="land"></td>
</tr>
<tr>
<td width="50%">Postcode </td>
<td width="50%"><input name="postcode" type="text" id="postcode"></td>
</tr>
<tr>
<td width="50%">Geslacht </td>
<td width="50%"><input name="geslacht" type="radio" id="man"  value="man" checked="checked"></td>
<tr><td></td><td><input name="geslacht" type="radio" id="vrouw" value="vrouw" checked="checked"></td></tr>
</tr>
<tr>
<td>Email Address </td>
<td><input name="email" type="text" id="email"></td>
</tr>
<tr>
<td>gebruikers naam</td>
<td><input name="username" type="text" id="username"></td>
</tr>
<tr>
<td>Password</td>
<td><input name="password" type="password" id="password"></td>
</tr>
<tr>
<td>Password(herhaal)  </td>
<td><input name="confirm" type="password" id="confirm"></td>
</tr>
<tr>
<td>Register</td>
<td><input name="submit" type="submit" class="textBox" value="Submit"></td>
</tr>
</table>
</form>
deze website. </div>
</div>
</body>
</html>
[./PHP]
 en dit voor activate.php:
[.PHP]
<?php
session_start();
// Eerst een basiscontrole uitvoeren op de URL
if(!isset($_GET['sleutel']) || !isset($_GET['username'])) {
    echo 'De URL is ongeldig.';
} else {
    // Om een account te activeren moeten we gewoon de activatie-
    // gegevens uit de tabel gooien:
    mysql_query("DELETE FROM gebruikers WHERE
                            gebruiker_id = ".intval($_GET['gebruiker'])." AND
                            sleutel       = '".mysql_real_escape_string($_GET['sleutel'])."'");
    //  mysql_affected_rows()
    // of in dit geval dus verwijderd. Zo weten we ook gelijk of de gegevens wel juist waren!
    if(mysql_affected_rows() == 0) {
        echo 'De account bestaat niet of was reeds geactiveerd.';
    } else {
        // Er is een rij aangetast, dus is het gelukt :)
        echo 'De activatie is gelukt. Je kan nu <a href="login.php">Inloggen</a>';
$id = $_GET['id'];
$code = $_GET['activation'];
$type = $_GET['type'];
if($type = 'login_activation'){
    $query = "SELECT * FROM activation WHERE sha1 = '".$code."' AND id_user = '".$id."'";
        $result = mysql_query($query);
            $numrows = mysql_num_rows($result);
    if($numrows == 1){
        $update = "UPDATE gebruikers SET activation = 1 WHERE id_user = '".$id."'";
            $resultupdate = mysql_query($update);
        $delete = "DELETE FROM activation WHERE id_user = '".$id."'";
            $resultdelete = mysql_query($delete);
        echo $l_activationMessage;
    }else{
        echo $l_deactivationMessage;
}else{
maar dan krijg ik by register.php deze foutmelding:
"Warning: mail() [function.mail]: SMTP server response: 503 in C:\xampp\htdocs\www\hsleiden\project2_2007\php\login2\register.php on line 143" en dat is by deze regel: $ok = mail($mail, $titel, $boodschap, "FROM: <nengelen@orange.nl>");
Klopt precies:
Je zult die melding niet krijgen als je hebt geupload,
want dan kun je wel een bevestigingsmail versturen,
mits je de instellingen bij je host goed hebt staan.
:cool:
Klopt precies:
:cool:[/maar ik heb het lokaal staan en krijg ook een bevesitigingslink, zie activate van een vroeger tijdstip , het gaat erom dat ik de mail wel kryg, maar als ik op de link in de mail klik, de error kryg: URL bestaat niet!!]
Sorry, ik lig er compleet af. Ik heb geen idee meer waar je het over hebt.
Waarschijnlijk twee keer dezelfde vraag gesteld volgens klager maar ik heb er niet naar gekeken. Dat weet jijzelf het beste!
Het zou om deze vraag gaan:
http://www.helpmij.nl/forum/showthread.php?t=334248
De moderator zoekt het uit en als jij inderdaad twee keer dezelfde vraag het gesteld dan hoort dat niet!
Succes met je vraag!
Sorry, ik lig er compleet af. Ik heb geen idee meer waar je het over hebt.[/ja, sorry hoor: maar ik kryg nu dus de foutmelding: "Warning: mail() [function.mail]: SMTP server response: 503 in C:\xampp\htdocs\www\hsleiden\project2_2007\php\login2\register.php on line 143
" en dat is de regel : "$ok = mail($mail, $titel, $boodschap, "FROM: <nengelen@orange.nl>"); " Ik ben hier al zolang mee bezig en het is een project voor school , dus kunt u alsjeblieft zeggen wat ik fout doe dan..]
Als je localhost werkt gewoon in de php.ini de smtp van je provider in vullen en je kunt local ook mailen...
Overigens is het machtig irritant dat je steeds een quote gebruikt en vervolgens daarin gaat typen. Gelieve pas te gaan typen na [/quote] in plaats van die weg te halen.
Error etc Info:
http://pcsupport.about.com/od/findbyerrormessage/a/503error.htm
http://email.about.com/cs/standards/a/smtp_error_code_2.htm
http://email.about.com/cs/standards/a/smtp.htm
Als je vanaf je eigen comp via de php file een mail wil versturen zal dit niet lukken.
Vanaf een internetsite met php en smtp ondersteuning wel.
:cool:[/maak kyk dan eens naar het topic met dezelfde titel: " activeringscode" van 18:58, dan zie je dat dat niet het probleem is, want ik kryg gewoon de mail met de activeringslink, maar als ik dus op de link klik dan kryg ik de melding: Kan URL niet vinden, maar kreeg van iemand anders dus een tip met een aangepast script ,dat heb ik dus verander maar kryg nu dus de melding "Warning: mail() [function.mail]: SMTP server response: 503 in C:\xampp\htdocs\www\hsleiden\project2_2007\php\login2\register.php on line 143
" en regel 143 is: "$ok = mail($mail, $titel, $boodschap, "FROM: <nengelen@orange.nl>"); " daar zit em dus de fout!!]
in plaats van die weg te halen.[/QUOTE]
Maar dat zeg ik toch ook, ik kan gewoon mailen en ik kryg dus ook mails, dat is niet het probleem! heb ook het commando in de dospromt gegeven: "telnet localhost 25" en er wordt keurig een verbinding gemaakt: "220 localhost". En ik neem juist wel dingen van jullie aan, maar het probleem ligt gewoon ergens anders. Zoals ik al eerder heb vermeld.
Dit heb ik ook in de php. ini file staan:
[mail function]
; For Win32 only.
SMTP = localhost
smtp_port = 25
Je SMTP in je php.ini moet naar die van je provider wijzen... Niet naar localhost tenzij je zelf een SMTP server draait (alhoewel ik betwijfel of dat werkt tegenwoordig)
En zoals ik al vermoedde heb je dus mijn link niet gebruikt... Daarin staat meerdere pagina's over jouw probleem. Van ons wil je het antwoord niet horen, van een ander misschien wel..
Hoi, welke link?? deze: Handleiding: [Win XP] Toetsenbord instellingen?? Sorry, maar nu snap ik u niet.
Wat doe jij raar?? ja, je stuurt me dan een verbeterd script, nou dat accepteer ik dan ook en wijzig dus myn script met die van jou!!
Maar je zegt er niet by dat het niet lokaal werkt! Als je nou gelyk had aangegeven dat die fout ermee te maken had met dat ik het lokaal draaide, dan hoefde het niet zo ver te gaan.
En deze fout bedoel ik dan: $ok = mail($mail, $titel, $boodschap, "FROM: <nengelen@orange.nl>");
Denk je dat ik jullie in de maling neem ofzo?? Maar als jullie niet duidelyk tegen my doen, dan weet ik het toch ook niet.
En met de dubbelposten, ja da wist ik niet. sorry!
