Help, het lukt niet meer om mijn dvd te kopieren op mijn laptop. Ik heb de dvd geript met ripit4me, hierna naar dvdshrink decoding en zodra ie moet branden zegt ie het volgende:
Windows XP 5.1
IA32
WinAspi: File 'Wnaspi32.dll': Ver=4.60 (1021), size=45056 bytes, created 10-09-1999 12:06:00
ahead WinASPI: File 'C:\Program Files\Ahead\Nero\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 26-10-2004 18:35:34
Nero API version: 6.6.0.16
Using interface version: 6.3.1.4
Installed in: C:\Program Files\Ahead\Nero\
Application: ahead\Nero - Burning Rom
Internal Version: 6, 6, 0, 16b
Recorder: <MAT****A DVD-RAM UJ-840S>Version: 1.50 - HA 0 TA 1 - 6.6.0.16
Adapter driver: <atapi> HA 0
Drive buffer : 2048kB
Bus Type : default (0) -> ATAPI, detected: ATAPI
=== Scsi-Device-Map ===
DiskPeripheral : ST960821A atapi Port 0 ID 0 DMA: On
CdRomPeripheral : MAT****A DVD-RAM UJ-840S atapi Port 0 ID 1 DMA: On
=== CDRom-Device-Map ===
MAT****A DVD-RAM UJ-840S E: CDRom0
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 74448896 (0) Byte
ShowDrvBufStat : 0
BUFE : 0
Physical memory : 510MB (522288kB)
Free physical memory: 178MB (182388kB)
Memory in use : 65 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
8.3.2008
NeroAPI
19:29:22 #1 Phase 112 File APIProgress.cpp, Line 276
DVD-Video files reallocation started
19:29:22 #2 Phase 114 File APIProgress.cpp, Line 276
DVD-Video files reallocation completed (no file modified)
19:29:22 #3 Phase 111 File APIProgress.cpp, Line 276
DVD-Video files sorted
19:29:22 #4 Text 0 File Reader.cpp, Line 127
Reader running
19:29:22 #5 Text 0 File Writer.cpp, Line 122
Writer MAT****A DVD-RAM UJ-840S running
19:29:22 #6 Text 0 File AudioCompilationImpl.cpp, Line 842
DRM: StartDrmRecording(RealRec:1, ImageRec:0, Copies:1)
DRM: Beginning burn process.
19:29:22 #7 ISO9660GEN -11 File geniso.cpp, Line 3309
First writeable address = 0 (0x00000000)
19:29:22 #8 ISO9660GEN -11 File geniso.cpp, Line 3309
19:29:22 #9 Text 0 File Burncd.cpp, Line 3233
Turn on Disc-At-Once, using DVD media
19:29:22 #10 Text 0 File DlgWaitCD.cpp, Line 270
Last possible write address on media: 2295103 (510:01.28, 4482MB)
Last address to be written: 2286127 (508:01.52, 4465MB)
19:29:22 #11 Text 0 File DlgWaitCD.cpp, Line 282
Write in overburning mode: NO
19:29:22 #12 Text 0 File DlgWaitCD.cpp, Line 2483
Recorder: MAT****A DVD-RAM UJ-840S, Media type: DVD+R
Disc Manufacturer ID: CMC MAG, Media Type ID: E01, Product revision number: 0
Disc Application Code: 0, Extended Information Indicators: 3
19:29:22 #13 Text 0 File DlgWaitCD.cpp, Line 448
>>> Protocol of DlgWaitCD activities: <<<
19:29:22 #14 Text 0 File ThreadedTransferInterface.cpp, Line 838
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 ()
2 indices, index0 (150) not provided
original disc pos #0 + 2286128 (2286128) = #2286128/508:1.53
relocatable, disc pos for caching/writing not required/ required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2286128 blocks [MAT****A DVD-RAM UJ-840S]
19:29:22 #15 Text 0 File ThreadedTransferInterface.cpp, Line 1051
Prepare recorder [MAT****A DVD-RAM UJ-840S] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 4681990144, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_CtrlAdr_|_RecDep__________
0 | lead-in | 0 | 0x41 | 0x00
0 | 1 | 0 | 0x41 | 0x00
0 | 1 | 1 | 0x41 | 0x00
2286128 | lead-out | 1 | 0x41 | 0x00
19:29:22 #16 Phase 24 File APIProgress.cpp, Line 276
Caching of files started
19:29:22 #17 Text 0 File Burncd.cpp, Line 4120
Cache writing successful.
19:29:22 #18 Phase 25 File APIProgress.cpp, Line 276
Caching of files completed
19:29:22 #19 Phase 36 File APIProgress.cpp, Line 276
Burn process started at 8x (11.080 KB/s)
19:29:22 #20 Text 0 File ThreadedTransferInterface.cpp, Line 2654
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
19:29:22 #21 Text 0 File Cdrdrv.cpp, Line 8862
---- DVD Structure: Physical Format Information (00h) ----
Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD+R (10), Part Version: 1.0x (1)
Disc Size: 120 mm, Maximum Rate: <not specified> (F h)
Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
End Physical Sector Number of Data Area: 26053F h
End Sector Number in Layer 0: 0 h (LBN: FFFD0000 h, 4193920 MB)
Data in Burst Cutting Area (BCA) does not exist
Disc Application Code: 0 / 0 h
Extended Information indicators: 3 h
Disc Manufacturer ID: CMC.MAG.
Media type ID: E01
Number of Physical format information bytes in use in ADIP up to byte 63: 56
Media Specific [16..63]:
00 00 03 43 4D 43 20 4D - 41 47 00 45 30 31 00 38 ...CMC.MAG.E01.8
23 54 37 10 02 38 6A 02 - 88 67 15 15 0B 0B 08 08 #T7..8j..g......
01 19 1B 0C 0C 0C 0D 01 - 00 00 00 00 00 00 00 00 ................
19:29:22 #22 Text 0 File DVDPlusRW.cpp, Line 665
Start write address at LBA 0
DVD high compatibility mode: Yes
19:30:01 #23 SCSI -400 File Cdrdrv.cpp, Line 1434
SCSI Exec, HA 0, TA 1, LUN 0, buffer 0x060E0000
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x04 (KEY_HARDWARE_ERROR)
Sense Code: 0x03
Sense Qual: 0x00
CDB Data: 0x2A 0x00 0x00 0x00 0x05 0xE0 0x00 0x00 0x20 0x00 0x00 0x00
Sense Data: 0xF1 0x00 0x04 0x00 0x00 0x02 0xF0 0x0A
0x00 0x29 0x00 0x00 0x03 0x00
19:30:01 #24 CDR -400 File Writer.cpp, Line 311
Unspecified target error
19:30:01 #25 Text 0 File ThreadedTransfer.cpp, Line 228
all writers idle, stopping conversion
19:30:01 #26 Text 0 File ThreadedTransfer.cpp, Line 222
conversion idle, stopping reader
19:30:09 #27 SCSI -1046 File Cdrdrv.cpp, Line 1180
Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
Sense Code: 0x30
Sense Qual: 0x05
CDB Data: 0x5B 0x01 0x05 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x05 0x00 0x00 0x00 0x00 0x0A
0x00 0x82 0x00 0x00 0x30 0x05
19:30:09 #28 Phase 127 File APIProgress.cpp, Line 276
Generating DVD high compatibility borders
19:30:09 #29 Phase 129 File APIProgress.cpp, Line 276
Generating DVD borders completed successfully
19:30:09 #30 Phase 38 File APIProgress.cpp, Line 276
Burn process failed at 8x (11.080 KB/s)
19:30:09 #31 Text 0 File AudioCompilationImpl.cpp, Line 867
DRM: DRM burn session terminated.
19:30:09 #32 Text 0 File AudioCompilationImpl.cpp, Line 896
DRM: Closing entire DRM handling. Bye.
Existing drivers:
File 'Drivers\ASPI32.SYS': Ver=4.60 (1021), size=25244 bytes, created 10-09-1999 12:06:00
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
Ik heb het al meerder malen geprobeerd met een dvd+r 4,7 gb 16x vd HEMA en DVD+r 4.7GB 1-8x van tdk. Het wil niet meer terwijl het een paar weken geleden nog heel goed ging.
Wie oh wie kan mij helpen?
Windows XP 5.1
IA32
AutoRun : 1
Excluded drive IDs:
ShowDrvBufStat : 0
BUFE : 0
Use Inquiry : 1
8.3.2008
NeroAPI
Reader running
DAO infos:
MCN: ""
Tracks 1 to 1:
DAO layout:
Media type ID: E01
Sense Code: 0x03
Sense Qual: 0x00
Sense Code: 0x30
Sense Qual: 0x05
Existing drivers:
Registry Keys:
