Dit kwam uit mijn dxdiag test:
System Information
Time of this report: 4/18/2008, 12:10:01
Machine name: JURJAN
Operating System: Windows XP Home Edition (5.1, Build 2600) Service Pack 2 (2600.xpsp_sp2_gdr.070227-2254)
Language: Dutch (Regional Setting: English)
System Manufacturer: To Be Filled By O.E.M.
System Model: To Be Filled By O.E.M.
BIOS: BIOS Date: 04/22/03 22:17:52 Ver: 08.00.09
Processor: Intel(R) Celeron(R) CPU 2.20GHz
Memory: 1022MB RAM
Page File: 498MB used, 1194MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 9.0c (4.09.0000.0904)
DX Setup Parameters: Not found
DxDiag Version: 5.03.2600.2180 32bit Unicode
Sound Devices
Description: C-Media Wave Device
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: PCI\VEN_13F6&DEV_0111&SUBSYS_A6501681&REV_10
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: cmaudio.sys
Driver Version: 5.12.0001.0643 (English)
Driver Attributes: Final Debug
WHQL Logo'd: Yes
Date and Size: 11/18/2002 15:51:40, 377358 bytes
Other Files:
Driver Provider: C-Media
HW Accel Level: Full
Cap Flags: 0xF5F
Min/Max Sample Rate: 100, 100000
Static/Strm HW Mix Bufs: 17, 16
Static/Strm HW 3D Bufs: 17, 16
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: Yes, Yes
I3DL2(tm) Listen/Src: Yes, Yes
Sensaura(tm) ZoomFX(tm): Yes
Registry: OK
Sound Test Result: Failure at step 19 (User verification of software): HRESULT = 0x00000000 (error code)---------------------
Sound Capture Devices
Default Sound Capture: Yes
Default Voice Capture: Yes
Cap Flags: 0x41
Format Flags: 0xCC0
DirectMusic
DLS Path: C:\WINDOWS\SYSTEM32\drivers\GM.DLS
DLS Version: 1.00.0016.0002
Acceleration: n/a
Ports: Microsoft Synthesizer, Software (Not Kernel Mode), Output, DLS, Internal, Default Port
MPU-401, Hardware (Kernel Mode), Input, No DLS, External
MPU-401, Hardware (Kernel Mode), Output, No DLS, External
C-Media Wave Device, Software (Kernel Mode), Output, DLS, Internal
Microsoft MIDI-mapper (emulatie), Hardware (Not Kernel Mode), Output, No DLS, Internal
Microsoft GS Wavetable-software (emulatie), Hardware (Not Kernel Mode), Output, No DLS, Internal
MPU-401 (emulatie), Hardware (Not Kernel Mode), Output, No DLS, External
MPU-401 (emulatie), Hardware (Not Kernel Mode), Input, No DLS, External
Registry: OK
Test Result: Not run
Ik heb niet alles er bij gezet, maar de standard specs en die van mijn audiokaart
