Mijn eerste applicatie maken
Kuifje_007
25 mrt 2004
Ik wil Java leren maken. Ik heb al boek Gertjan Laan doorgenomen. Nu probeer ik applicatie te maken maar als ik start, gebeurt er namelijk niets. Ik krijg ook geen foutmelding.
package mijnapplicatie;
import java.awt.*;
import java.awt.event.*;
import javax.swing.*;
 * <p>Title: </p>
 * <p>Description: </p>
 * <p>Copyright: Copyright (c) 2008</p>
 * <p>Company: </p>
 * @author not attributable
 * @version 1.0
public class inlogscherm extends JFrame {
  JPanel contentPane;
  BorderLayout borderLayout1 = new BorderLayout();
  Label label1 = new Label();
  TextField textField1 = new TextField();
  TextField txtInlogNaam = new TextField();
  Label lbInlognaam = new Label();
  Label lbWachtwoord = new Label();
  TextField txtWachtwoord = new TextField();
  //Construct the frame
  public inlogscherm() {
    enableEvents(AWTEvent.WINDOW_EVENT_MASK);
    try {
      jbInit();
    catch(Exception e) {
      e.printStackTrace();
  //Component initialization
  private void jbInit() throws Exception  {
    contentPane = (JPanel) this.getContentPane();
    getContentPane().setLayout(null);
    label1.setText("label1");
    //setLayout(null);
    this.setSize(new Dimension(400, 300));
    this.setTitle("Inlogscherm");
    txtInlogNaam.setText("");
    txtInlogNaam.setBounds(new Rectangle(60, 90, 250, 40));
    lbInlognaam.setText("Inlognaam");
    lbInlognaam.setBounds(new Rectangle(60, 60, 150, 36));
    lbWachtwoord.setText("Wachtwoord");
    lbWachtwoord.setBounds(new Rectangle(60, 160, 142, 28));
    txtWachtwoord.setBounds(new Rectangle(60, 190, 250, 40));
    contentPane.add(label1, BorderLayout.NORTH);
    contentPane.add(textField1, BorderLayout.CENTER);
    contentPane.add(txtInlogNaam, null);
    contentPane.add(lbInlognaam, null);
    contentPane.add(lbWachtwoord, null);
    contentPane.add(txtWachtwoord, null);
  //Overridden so we can exit when window is closed
  protected void processWindowEvent(WindowEvent e) {
    super.processWindowEvent(e);
    if (e.getID() == WindowEvent.WINDOW_CLOSING) {
      System.exit(0);
  public static void main( String[] args ) {
    new inlogscherm();
Kan iemand mij helpen? :o
import java.awt.*;
 * <p>Title: </p>
 * <p>Company: </p>
 * @version 1.0
  JPanel contentPane;
    try {
      jbInit();
    //setLayout(null);
      System.exit(0);
    new inlogscherm();
je bent de functie show( ); vergeten, zeer belangrijk zonder deze zie je niks...Zet hem bij de init of de constructor
En als je verschillende virtual windows moet maken, bijv. inlogscherm, klantenscherm, etc., moet je dan verschillende classes maken voor elk Windows of hoe zit het eigenlijk? :o
Het is wel aan te raden om dat te doen, dan kan je in elke klasse specifieke knoppen / vakken etc aangeven welke ze zouden moeten weergeven.
En als je een form niet meer nodig bent, dan kan je op deze de .Visible(false) aanroepen waardoor hij niet meer zichtbaar is.
