hoe gedownload spel branden??
wentzlove
2 jul 2008
Hallo
ik heb via bittorrent de game GTA vice city gedownload
alleen heb ik nog niet zo veel ervaring met branden van spellen (helemaal niet)
er zitten wel instructies bij ,
First read the System Requirements.txt and make sure your machine will support this game
if so
Find
"GTA_Vice_City.iso"
and
"Vice_City_Play.iso"
in the same folder as this text document
and also find "gta-vc.exe" inside the "Crack" Folder also located in the same folder as this text document
Either Burn each one to cd at 16X with nero or imgageburn or your favorite cd burning program
Or Use Demon tools Or Nero Image Drive To Mount The Images
use the
"GTA_Vice_City.iso" to start the install process (for best results install completely with all the radiostations)
Follow the installers instuctions
If installing the radio stations you will be asked to change discs at this time swap out the "GTA_Vice_City.iso" disc
with the "Vice_City_Play.iso" disc
or if using a mounted image unmount "GTA_Vice_City.iso" and mount "Vice_City_Play.iso"
and continue to follow the installers promts
After the install process is complete DO NOT TRY TO START THE GAME UNTIL YOU FINISH THIS LAST STEP
Copy and paste the "gta-vc.exe" From the Crack Folder To Your Install Directory Probably something like
"C:\Program Files\Rockstar Games\Grand Theft Auto Vice City" and click yes when asked if you want to overwrite the old one
Now To Play The Game You Must Have The "Vice_City_Play.iso" Disc in your drive or mounted in a virtual drive every time
you play
Now just use the desktop shortcut to start the game (with the Play disc in the drive or mounted)
If you didnt install the radio stations you may get an error that a file is missing if this is the case find the missing file by name in the
"Vice_City_Play.iso" disc or image and copy it to your install directory
Please seed
Freak-area51.mine.nu
maar nadat ik de 3 bestanden op 1 schijfje had gedaan gebeurde er niks,
weet iemand wat ik moet doen ? moet ik aparte bestanden op 2 schrijfjes branden?
http://isorecorder.alexfeinman.com/isorecorder.htm
Kijk eens op deze link voor uitleg.
Je hebt in ieder geval 2 cd's nodig om de 2 iso files te branden
(de site begrijp ik niet helemaal :rolleyes:)
ik heb 2 iso bestanden, en 1 ander bestand
moet ik dan 1 iso + dat andere bestand op 1 cd en op de andere cd 1 iso + weer dat andere bestand doen?
want wat ik net had gedaan was die 2 iso's + dat andere bestand op 1 schijfje gezet.
Als je er tegenopziet om te branden kan je de iso's ook in een virtuele drive steken...
Als je nero hebt kan je ze met nero imagedrive mounten...
Indien je geen nero hebt download je best het gratis daemon tools...
Gewoon proberen, denk dat beide programma's zichzelf uitwijzen, indien je er niet uitraakt zeg je het maar...
download deamon tools en mount die cd`s en je kunt spelen.. heb ik ook gedaan met nfs most wanted.. werkt perfect..
ik heb nero , maar op welke moet ik dan klikken ? en wat daarna te doen?
Welke versie van nero heb je?
Heb je vista of xp btw?
download deamon tools of alcohol 120%
met die programma`s kun iso bestanden mounten en uitpakken..
Goedzo (want in vista werkt het (nog) niet met nero, had je sowieso voor deamon tools moeten kiezen.
Hoe dan ook: je kiest voor start, alle programma's, nero, nero 6, nero imagedrive
In dat venster kies je voor nero imagedrive inschakelen
het kan zijn dat je dan je pc moet herstarten
vervolgens vink je het aantal virtuele stations aan dat je wilt, 1 is voldoende denk ik, je kan de iso's ook na elkaar mounten...
Dan werkt ie even aan het aanmaken van dat station en komt er een tab bij: eerste station, daar klik je op en je klikt op de '...'-button.
Dan blader je naar het isobestand en kiest voor openen.
alles is gelukt ( ik heb nu 2 schijfjes)
maar wat moet ik hier doen?
als ik dat doe dat hoef ik het niet te overschrijven, en als ik nu op gta vice city PLAY druk, doet die het nog steeds niet
volgens mij mag je hier ook geen cracks posten togh?:rolleyes:
ander stuur ik wel via mail..als je die geeft:P
Heb ik iets fout gedaan dan :rolleyes:?? :shocked:
er staat wel een crack folder , en daarin staat gta vc ( maar ik heb verder ook geen idee wat een crack is )
