System Information
Time of this report: 7/6/2008, 19:51:15
Machine name: MARTIN
Operating System: Windows XP Home Edition (5.1, Build 2600) Service Pack 2 (2600.xpsp_sp2_gdr.070227-2254)
Language: Dutch (Regional Setting: Dutch)
System Manufacturer: MEDIONPC
System Model: MS-7204
BIOS: Phoenix - AwardBIOS v6.00PG
Processor: Intel(R) Pentium(R) D CPU 3.00GHz (2 CPUs)
Memory: 1022MB RAM
Page File: 585MB used, 1873MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 9.0c (4.09.0000.0904)
DX Setup Parameters: Not found
DxDiag Version: 5.03.2600.2180 32bit Unicode
DxDiag Notes
DirectX Files Tab: No problems found.
Display Tab 1: The file vga.dll is not digitally signed, which means that it has not been tested by Microsoft's Windows Hardware Quality Labs (WHQL). You may be able to get a WHQL logo'd driver from the hardware manufacturer. The system is using the generic video driver. Please install video driver provided by the hardware manufacturer. Direct3D functionality not available. You should verify that the driver is a final version from the hardware manufacturer.
Sound Tab 1: No problems found.
Music Tab: No problems found.
Input Tab: No problems found.
Network Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (n/a)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (n/a)
DirectMusic: 0/5 (n/a)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name:
Manufacturer:
Chip type:
DAC type:
Device Key: Enum\
Display Memory: n/a
Current Mode: 1024 x 768 (32 bit) (1Hz)
Monitor:
Monitor Max Res:
Driver Name: vga.dll
Driver Version: 5.01.2600.0000 (Dutch)
DDI Version: unknown
Driver Attributes: Final Retail
Driver Date/Size: 8/4/2004 14:00:00, 9344 bytes
WHQL Logo'd: No
WHQL Date Stamp: None
VDD: n.v.t.
Mini VDD: vga.sys
Mini VDD Date: 8/4/2004 13:59:59, 20992 bytes
Device Identifier: {D7B70EE0-4340-11CF-B063-282AAEC2C835}
Vendor ID: 0x0000
Device ID: 0x0000
SubSys ID: 0x00000000
Revision ID: 0x0000
Revision ID: 0x0000
Video Accel:
Deinterlace Caps: n/a
Registry: OK
DDraw Status: Not Available
D3D Status: Not Available
AGP Status: Not Available
DDraw Test Result: Not run
D3D7 Test Result: Not run
D3D8 Test Result: Not run
D3D9 Test Result: Not run
Sound Devices
Description: Realtek HD Audio output
Default Sound Playback: Yes
Default Voice Playback: No
Hardware ID: HDAUDIO\FUNC_01&VEN_10EC&DEV_0882&SUBSYS_10EC0882&REV_1001
Manufacturer ID: 1
Product ID: 2
Type: WDM
Driver Name: RtkHDAud.sys
Driver Version: 5.10.0000.5211 (English)
WHQL Logo'd: n/a
Date and Size: 1/13/2006 18:13:17, 4137984 bytes
Other Files:
Driver Provider: Realtek Semiconductor Corp.
HW Accel Level: Full
Cap Flags: 0x0
Min/Max Sample Rate: 0, 0
Static/Strm HW Mix Bufs: 0, 0
Static/Strm HW 3D Bufs: 0, 0
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: No, No
I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Registry: OK
Sound Test Result: Not run
Sound Capture Devices
Description: Realtek HD Audio input
Default Sound Capture: Yes
Default Voice Capture: Yes
Cap Flags: 0x41
Format Flags: 0xFFF
Description: Realtek HD Digital input
Default Sound Capture: No
Default Voice Capture: No
Cap Flags: 0x41
Format Flags: 0xFFF
Description: 713x BDA Analog Audio Capture
Driver Name: 3xHybrid.sys
Driver Version: 1.03.0003.0001 (English)
Date and Size: 12/6/2005 12:15:59, 826752 bytes
Cap Flags: 0x41
Format Flags: 0xCC0
Cap Flags: 0x41
Format Flags: 0xCC0
DirectMusic
DLS Path: C:\WINDOWS\SYSTEM32\drivers\GM.DLS
DLS Version: 1.00.0016.0002
Acceleration: n/a
Ports: Microsoft Synthesizer, Software (Not Kernel Mode), Output, DLS, Internal, Default Port
Microsoft MIDI-mapper (emulatie), Hardware (Not Kernel Mode), Output, No DLS, Internal
Microsoft GS Wavetable-software (emulatie), Hardware (Not Kernel Mode), Output, No DLS, Internal
Registry: OK
DirectInput Devices
Device Name: Muis
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Toetsenbord
Attached: 1
Controller ID: n/a
FF Driver: n/a
Device Name: USB Wireless HID Receiver
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x04F2, 0x0420
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Poll w/ Interrupt: No
Registry: OK
USB Devices
+ USB-hoofdhub
| Vendor/Product ID: 0x8086, 0x27CA
| Matching Device ID: usb\root_hub
| Service: usbhub
| Driver: usbhub.sys, 8/3/2004 23:08:43, 57600 bytes
| Driver: usbd.sys, 8/4/2004 13:59:59, 4736 bytes
Gameport Devices
PS/2 Devices
+ HID-toetsenbordapparaat
| Matching Device ID: hid_device_system_keyboard
| Service: kbdhid
| Driver: kbdhid.sys, 8/4/2004 00:57:19, 14848 bytes
| Driver: kbdclass.sys, 8/4/2004 13:59:59, 25216 bytes
+ Toestenbordstuurprogramma voor Terminal Server
| Matching Device ID: root\rdp_kbd
| Upper Filters: kbdclass
| Service: TermDD
| Driver: termdd.sys, 8/4/2004 01:03:47, 40840 bytes
+ HID-compliant muis
| Matching Device ID: hid_device_system_mouse
| Service: mouhid
| Driver: mouclass.sys, 8/4/2004 13:59:59, 23552 bytes
| Driver: mouhid.sys, 9/6/2001 19:04:39, 12288 bytes
+ Stuurprogramma voor muis van Terminal Server
| Matching Device ID: root\rdp_mou
| Upper Filters: mouclass
| Service: TermDD
DirectPlay Service Providers
DirectPlay8 Modem Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
DirectPlay8 Serial Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
DirectPlay8 IPX Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
DirectPlay8 TCP/IP Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
Internet TCP/IP Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.2180)
IPX Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.2180)
Modem Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.2180)
Serial Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.2180)
DirectPlay Voice Wizard Tests: Full Duplex: Not run, Half Duplex: Not run, Mic: Not run
DirectPlay Test Result: Not run
Registry: OK
DirectPlay Adapters
DirectPlay8 Modem Service Provider: Creatix V.92 Data Fax Modem
DirectPlay8 Serial Service Provider: COM1
DirectPlay8 Serial Service Provider: COM2
DirectPlay8 Serial Service Provider: COM3
DirectPlay Voice Codecs
Voxware VR12 1.4kbit/s
Voxware SC06 6.4kbit/s
Voxware SC03 3.2kbit/s
MS-PCM 64 kbit/s
MS-ADPCM 32.8 kbit/s
Microsoft GSM 6.10 13 kbit/s
TrueSpeech(TM) 8.6 kbit/s
DirectPlay Lobbyable Apps
Disk & DVD/CD-ROM Drives
Drive: C:
Free Space: 21.0 GB
Total Space: 119.2 GB
File System: NTFS
Model: ST3250824AS
Drive: D:
Free Space: 100.7 GB
Total Space: 113.1 GB
File System: NTFS
Model: ST3250824AS
Drive: E:
Free Space: 1.0 GB
Total Space: 6.1 GB
File System: FAT32
Model: ST3250824AS
Drive: F:
Model: SONY DVD RW DW-G121A
Driver: c:\windows\system32\drivers\cdrom.sys, 5.01.2600.2180 (Dutch), 8/4/2004 13:59:59, 49536 bytes
Drive: G:
Model: SONY DVD-ROM DDU1615
Drive: K:
Model: HJ3304L JJT415U SCSI CdRom Device
Drive: L:
Drive: M:
Drive: N:
System Devices
Name: Intel(R) 82801G (ICH7 Family) Ultra ATA Storage Controllers - 27DF
Device ID: PCI\VEN_8086&DEV_27DF&SUBSYS_72041462&REV_01\3&2411E6FE&0&F9
Driver: C:\WINDOWS\system32\DRIVERS\pciide.sys, 5.01.2600.0000 (Dutch), 9/6/2001 20:14:19, 3328 bytes
Driver: C:\WINDOWS\system32\DRIVERS\pciidex.sys, 5.01.2600.2180 (Dutch), 8/3/2004 22:59:41, 25088 bytes
Driver: C:\WINDOWS\system32\DRIVERS\atapi.sys, 5.01.2600.2180 (English), 8/3/2004 22:59:43, 95360 bytes
Name: Intel(R) 82801G (ICH7 Family) SMBus Controller - 27DA
Device ID: PCI\VEN_8086&DEV_27DA&SUBSYS_72041462&REV_01\3&2411E6FE&0&FB
Driver: n/a
Name: Microsoft UAA Bus Driver for High Definition Audio
Device ID: PCI\VEN_8086&DEV_27D8&SUBSYS_72041462&REV_01\3&2411E6FE&0&D8
Driver: C:\WINDOWS\system32\DRIVERS\hdaudbus.sys, 5.10.0001.5013 (English), 1/7/2005 17:07:17, 138752 bytes
Name: Intel(R) 82801G (ICH7 Family) USB2 Enhanced Host Controller - 27CC
Device ID: PCI\VEN_8086&DEV_27CC&SUBSYS_72041462&REV_01\3&2411E6FE&0&EF
Driver: C:\WINDOWS\system32\drivers\usbehci.sys, 5.01.2600.2180 (English), 8/3/2004 23:08:37, 26624 bytes
Driver: C:\WINDOWS\system32\drivers\usbport.sys, 5.01.2600.2180 (English), 8/3/2004 23:08:43, 142976 bytes
Driver: C:\WINDOWS\system32\usbui.dll, 5.01.2600.2180 (Dutch), 8/4/2004 01:03:24, 76288 bytes
Driver: C:\WINDOWS\system32\drivers\usbhub.sys, 5.01.2600.2180 (English), 8/3/2004 23:08:43, 57600 bytes
Driver: C:\WINDOWS\system32\hccoin.dll, 5.01.2600.2180 (English), 8/4/2004 14:00:00, 7168 bytes
Name: Intel(R) 82801G (ICH7 Family) USB Universal Host Controller - 27CB
Device ID: PCI\VEN_8086&DEV_27CB&SUBSYS_72041462&REV_01\3&2411E6FE&0&EB
Driver: C:\WINDOWS\system32\drivers\usbuhci.sys, 5.01.2600.2180 (English), 8/3/2004 23:08:37, 20480 bytes
Name: Intel(R) 82801G (ICH7 Family) USB Universal Host Controller - 27CA
Device ID: PCI\VEN_8086&DEV_27CA&SUBSYS_72041462&REV_01\3&2411E6FE&0&EA
Name: Intel(R) 82801G (ICH7 Family) USB Universal Host Controller - 27C9
Device ID: PCI\VEN_8086&DEV_27C9&SUBSYS_72041462&REV_01\3&2411E6FE&0&E9
Name: Intel(R) 82801G (ICH7 Family) USB Universal Host Controller - 27C8
Device ID: PCI\VEN_8086&DEV_27C8&SUBSYS_72041462&REV_01\3&2411E6FE&0&E8
Name: Intel(R) 82801GB/GR/GH (ICH7 Family) Serial ATA Storage Controller - 27C0
Device ID: PCI\VEN_8086&DEV_27C0&SUBSYS_72041462&REV_01\3&2411E6FE&0&FA
Name: Intel(R) 82801GB/GR (ICH7 Family) LPC Interface Controller - 27B8
Device ID: PCI\VEN_8086&DEV_27B8&SUBSYS_00000000&REV_01\3&2411E6FE&0&F8
Driver: C:\WINDOWS\system32\DRIVERS\isapnp.sys, 5.01.2600.0000 (Dutch), 9/6/2001 18:20:17, 36352 bytes
Name: Intel(R) 945G/P PCI Express Root Port - 2771
Device ID: PCI\VEN_8086&DEV_2771&SUBSYS_00000000&REV_81\3&2411E6FE&0&08
Driver: C:\WINDOWS\system32\DRIVERS\pci.sys, 5.01.2600.2180 (Dutch), 8/4/2004 00:53:29, 68224 bytes
Name: Intel(R) 945G/P Processor to I/O Controller - 2770
Device ID: PCI\VEN_8086&DEV_2770&SUBSYS_00000000&REV_81\3&2411E6FE&0&00
Driver: n/a
Name: Intel(R) 82801 PCI Bridge - 244E
Device ID: PCI\VEN_8086&DEV_244E&SUBSYS_00000000&REV_E1\3&2411E6FE&0&F0
Name: Creatix V.92 Data Fax Modem
Device ID: PCI\VEN_11C1&DEV_0620&SUBSYS_062011C1&REV_00\4&1AF1648C&0&28F0
Driver: n/a
Name: Medion SAA7131, Hybrid Capture Device 2
Device ID: PCI\VEN_1131&DEV_7133&SUBSYS_000816BE&REV_D1\4&1AF1648C&0&20F0
Driver: C:\WINDOWS\system32\drivers\drmk.sys, 5.01.2600.2180 (English), 8/4/2004 00:07:59, 60288 bytes
Driver: C:\WINDOWS\system32\drivers\portcls.sys, 5.01.2600.1364 (English), 3/16/2004 10:58:19, 136960 bytes
Driver: C:\WINDOWS\system32\drivers\stream.sys, 5.03.2600.2180 (Dutch), 8/4/2004 00:08:03, 48640 bytes
Driver: C:\WINDOWS\system32\wdmaud.drv, 5.01.2600.2180 (English), 8/4/2004 01:03:40, 23552 bytes
Driver: C:\WINDOWS\system32\ksuser.dll, 5.03.2600.2180 (Dutch), 8/4/2004 02:03:14, 4096 bytes
Driver: C:\WINDOWS\system32\kstvtune.ax, 5.03.2600.2180 (Dutch), 8/4/2004 02:03:38, 61952 bytes
Driver: C:\WINDOWS\system32\ksxbar.ax, 5.03.2600.2180 (English), 8/4/2004 02:03:38, 43008 bytes
Driver: C:\WINDOWS\system32\kswdmcap.ax, 5.03.2600.2180 (Dutch), 8/4/2004 02:03:38, 91136 bytes
Driver: C:\WINDOWS\system32\vidcap.ax, 5.01.2600.2180 (English), 8/4/2004 02:03:38, 28672 bytes
Driver: C:\WINDOWS\system32\vfwwdm32.dll, 5.01.2600.2180 (Dutch), 8/4/2004 02:03:24, 54272 bytes
Driver: C:\WINDOWS\system32\iyuv_32.dll, 5.01.2600.2180 (Dutch), 8/4/2004 02:03:14, 47616 bytes
Driver: C:\WINDOWS\system32\msh263.drv, 5.01.2600.2180 (Dutch), 8/4/2004 02:03:40, 299008 bytes
Driver: C:\WINDOWS\system32\msyuv.dll, 5.03.2600.2180 (English), 8/4/2004 02:03:18, 17408 bytes
Driver: C:\WINDOWS\system32\BdaPlgIn.ax, 5.03.2600.2180 (Dutch), 8/4/2004 02:03:38, 18432 bytes
Driver: C:\WINDOWS\system32\MSDvbNP.ax, 6.05.2600.2180 (English), 8/4/2004 02:03:38, 56832 bytes
Driver: C:\WINDOWS\system32\PsisRndr.ax, 6.05.2600.2180 (English), 8/4/2004 02:03:38, 33280 bytes
Driver: C:\WINDOWS\system32\PsisDecd.dll, 6.05.2600.2180 (English), 8/4/2004 02:03:20, 363520 bytes
Driver: C:\WINDOWS\system32\drivers\BdaSup.sys, 5.03.2600.2180 (English), 8/4/2004 00:10:13, 11776 bytes
Driver: C:\WINDOWS\system32\tsbyuv.dll, 5.01.2600.0000 (English), 9/6/2001 22:27:04, 8192 bytes
Driver: C:\WINDOWS\system32\drivers\3xHybrid.sys, 1.03.0003.0001 (English), 12/6/2005 12:15:59, 826752 bytes
Driver: C:\WINDOWS\system32\34CoInstaller.dll, 2/27/2003 10:07:00, 3072 bytes
Name: Medion SAA7131, Hybrid Capture Device 1
Device ID: PCI\VEN_1131&DEV_7133&SUBSYS_000716BE&REV_D1\4&1AF1648C&0&08F0
Name: VIA OHCI Compliant IEEE 1394 Host Controller
Device ID: PCI\VEN_1106&DEV_3044&SUBSYS_204D1462&REV_80\4&1AF1648C&0&18F0
Driver: C:\WINDOWS\system32\DRIVERS\ohci1394.sys, 5.01.2600.2180 (English), 8/4/2004 00:10:09, 61056 bytes
Driver: C:\WINDOWS\system32\DRIVERS\1394bus.sys, 5.01.2600.2180 (English), 8/4/2004 00:10:07, 53248 bytes
Driver: C:\WINDOWS\system32\DRIVERS\nic1394.sys, 5.01.2600.2180 (English), 8/4/2004 13:59:59, 61824 bytes
Driver: C:\WINDOWS\system32\DRIVERS\arp1394.sys, 5.01.2600.2180 (English), 8/4/2004 13:59:59, 60800 bytes
Driver: C:\WINDOWS\system32\DRIVERS\enum1394.sys, 5.01.2600.0000 (English), 8/17/2001 22:46:39, 6400 bytes
Name: Realtek RTL8139 Family PCI Fast Ethernet NIC
Device ID: PCI\VEN_10EC&DEV_8139&SUBSYS_204C1462&REV_10\4&1AF1648C&0&10F0
Driver: C:\WINDOWS\system32\DRIVERS\RTL8139.sys, 5.398.0613.2003 (English), 8/4/2004 00:31:33, 20992 bytes
Name: NVIDIA GeForce 6700 XL
Device ID: PCI\VEN_10DE&DEV_0147&SUBSYS_03501462&REV_A2\4&11C8B129&0&0008
Driver: C:\WINDOWS\system32\DRIVERS\nv4_mini.sys, 6.14.0010.9371 (English), 10/22/2006 12:22:00, 3994624 bytes
Driver: C:\WINDOWS\system32\nv4_disp.dll, 6.14.0010.9371 (English), 10/22/2006 12:22:00, 4527488 bytes
Driver: C:\WINDOWS\system32\nvsvc32.exe, 6.14.0010.9371 (English), 10/22/2006 12:22:00, 159810 bytes
Driver: C:\WINDOWS\system32\nvhwvid.dll, 6.14.0010.9371 (), 10/22/2006 12:22:00, 581632 bytes
Driver: C:\WINDOWS\system32\nvapi.dll, 6.14.0010.9371 (), 10/22/2006 12:22:00, 212992 bytes
Driver: C:\WINDOWS\system32\nvoglnt.dll, 6.14.0010.9371 (English), 10/22/2006 12:22:00, 5644288 bytes
Driver: C:\WINDOWS\system32\nvcpl.dll, 6.14.0010.9371 (English), 10/22/2006 12:22:00, 7700480 bytes
Driver: C:\WINDOWS\system32\nvmctray.dll, 6.14.0010.9371 (English), 10/22/2006 12:22:00, 86016 bytes
Driver: C:\WINDOWS\system32\nvwddi.dll, 6.14.0010.9371 (English), 10/22/2006 12:22:00, 81920 bytes
Driver: C:\WINDOWS\system32\nvnt4cpl.dll, 6.14.0010.11060 (English), 10/22/2006 12:22:00, 286720 bytes
Driver: C:\WINDOWS\system32\nvmccs.dll, 6.14.0010.9371 (English), 10/22/2006 12:22:00, 229376 bytes
Driver: C:\WINDOWS\system32\nvdisps.dll, 6.14.0010.9371 (English), 10/22/2006 12:22:00, 5619712 bytes
Driver: C:\WINDOWS\system32\nvgames.dll, 6.14.0010.9371 (English), 10/22/2006 12:22:00, 3047424 bytes
Driver: C:\WINDOWS\system32\nvmccss.dll, 6.14.0010.9371 (English), 10/22/2006 12:22:00, 188416 bytes
Driver: C:\WINDOWS\system32\nvmobls.dll, 6.14.0010.9371 (English), 10/22/2006 12:22:00, 888832 bytes
Driver: C:\WINDOWS\system32\nvvitvs.dll, 6.14.0010.9371 (English), 10/22/2006 12:22:00, 2924544 bytes
Driver: C:\WINDOWS\system32\nvwss.dll, 6.14.0010.9371 (English), 10/22/2006 12:22:00, 1236992 bytes
Driver: C:\WINDOWS\help\nvcpl.hlp, 10/22/2006 12:22:00, 177897 bytes
Driver: C:\WINDOWS\help\nvwcplen.hlp, 10/22/2006 12:22:00, 55444 bytes
Driver: C:\WINDOWS\system32\nvcod.dll, 1.00.0000.0035 (English), 10/22/2006 12:22:00, 35840 bytes
Driver: C:\WINDOWS\system32\nvcodins.dll, 1.00.0000.0035 (English), 10/22/2006 12:22:00, 35840 bytes
DirectX Components
ddraw.dll: 5.03.2600.2180 Dutch Final Retail 8/4/2004 14:00:00 266240 bytes
ddrawex.dll: 5.03.2600.2180 English Final Retail 8/4/2004 14:00:00 27136 bytes
dxapi.sys: 5.01.2600.0000 English Final Retail 8/4/2004 13:59:59 10496 bytes
d3d8.dll: 5.03.2600.2180 Dutch Final Retail 8/4/2004 14:00:00 1179648 bytes
d3d8thk.dll: 5.03.2600.2180 English Final Retail 8/4/2004 14:00:00 8192 bytes
d3d9.dll: 5.03.2600.2180 English Final Retail 8/4/2004 14:00:00 1689088 bytes
d3dim.dll: 5.01.2600.0000 English Final Retail 8/4/2004 14:00:00 436224 bytes
d3dim700.dll: 5.03.2600.2180 English Final Retail 8/4/2004 14:00:00 825344 bytes
d3dramp.dll: 5.01.2600.0000 English Final Retail 8/4/2004 14:00:00 590336 bytes
d3drm.dll: 5.01.2600.0000 English Final Retail 8/4/2004 14:00:00 350208 bytes
d3dxof.dll: 5.01.2600.0000 English Final Retail 8/4/2004 14:00:00 47616 bytes
d3dpmesh.dll: 5.01.2600.0000 English Final Retail 8/4/2004 14:00:00 34816 bytes
dplay.dll: 5.00.2134.0001 Dutch Final Retail 8/4/2004 14:00:00 33040 bytes
dplayx.dll: 5.03.2600.2180 English Final Retail 8/4/2004 14:00:00 229888 bytes
dpmodemx.dll: 5.03.2600.2180 Dutch Final Retail 8/4/2004 14:00:00 24064 bytes
dpwsock.dll: 5.00.2134.0001 English Final Retail 8/4/2004 14:00:00 42768 bytes
dpwsockx.dll: 5.03.2600.2180 Dutch Final Retail 8/4/2004 14:00:00 57856 bytes
dplaysvr.exe: 5.03.2600.2180 English Final Retail 8/4/2004 14:00:00 30208 bytes
dpnsvr.exe: 5.03.2600.2180 Dutch Final Retail 8/4/2004 14:00:00 18432 bytes
dpnet.dll: 5.03.2600.2180 English Final Retail 8/4/2004 14:00:00 375296 bytes
dpnlobby.dll: 5.03.2600.2180 English Final Retail 8/4/2004 14:00:00 3584 bytes
dpnaddr.dll: 5.03.2600.2180 English Final Retail 8/4/2004 14:00:00 3584 bytes
dpvoice.dll: 5.03.2600.2180 Dutch Final Retail 8/4/2004 14:00:00 212480 bytes
dpvsetup.exe: 5.03.2600.2180 English Final Retail 8/4/2004 14:00:00 83456 bytes
dpvvox.dll: 5.03.2600.2180 Dutch Final Retail 8/4/2004 14:00:00 116736 bytes
dpvacm.dll: 5.03.2600.2180 Dutch Final Retail 8/4/2004 14:00:00 21504 bytes
dpnhpast.dll: 5.03.2600.2180 English Final Retail 8/4/2004 14:00:00 35328 bytes
dpnhupnp.dll: 5.03.2600.2180 English Final Retail 8/4/2004 14:00:00 60928 bytes
dpserial.dll: 5.00.2134.0001 Dutch Final Retail 8/4/2004 14:00:00 53520 bytes
dinput.dll: 5.03.2600.2180 Dutch Final Retail 8/4/2004 14:00:00 164352 bytes
dinput8.dll: 5.03.2600.2180 Dutch Final Retail 8/4/2004 14:00:00 186880 bytes
dimap.dll: 5.01.2600.0000 English Final Retail 8/4/2004 14:00:00 44032 bytes
diactfrm.dll: 5.01.2600.0000 Dutch Final Retail 8/4/2004 14:00:00 395264 bytes
joy.cpl: 5.03.2600.2180 Dutch Final Retail 8/4/2004 14:00:00 69632 bytes
gcdef.dll: 5.01.2600.0000 Dutch Final Retail 8/4/2004 14:00:00 77312 bytes
pid.dll: 5.03.2600.2180 English Final Retail 8/4/2004 14:00:00 35328 bytes
dsound.dll: 5.03.2600.2180 Dutch Final Retail 8/4/2004 14:00:00 367616 bytes
dsound3d.dll: 5.03.2600.2180 English Final Retail 8/4/2004 14:00:00 1294336 bytes
dswave.dll: 5.03.2600.2180 English Final Retail 8/4/2004 14:00:00 19456 bytes
dsdmo.dll: 5.03.2600.2180 English Final Retail 8/4/2004 14:00:00 181760 bytes
dsdmoprp.dll: 5.03.2600.2180 Dutch Final Retail 8/4/2004 14:00:00 72192 bytes
dmusic.dll: 5.03.2600.2180 Dutch Final Retail 8/4/2004 14:00:00 104448 bytes
dmband.dll: 5.03.2600.2180 English Final Retail 8/4/2004 14:00:00 28672 bytes
dmcompos.dll: 5.03.2600.2180 English Final Retail 8/4/2004 14:00:00 61440 bytes
dmime.dll: 5.03.2600.2180 English Final Retail 8/4/2004 14:00:00 181248 bytes
dmloader.dll: 5.03.2600.2180 English Final Retail 8/4/2004 14:00:00 35840 bytes
dmstyle.dll: 5.03.2600.2180 English Final Retail 8/4/2004 14:00:00 105984 bytes
dmsynth.dll: 5.03.2600.2180 English Final Retail 8/4/2004 14:00:00 103424 bytes
dmscript.dll: 5.03.2600.2180 English Final Retail 8/4/2004 14:00:00 82432 bytes
system.dll: 1.01.4322.2407 English Final Retail 7/11/2007 01:05:50 1232896 bytes
Microsoft.DirectX.Direct3D.dll: 9.05.0132.0000 English Final Retail 11/16/2007 20:40:17 473600 bytes
Microsoft.DirectX.Direct3DX.dll: 5.04.0000.3900 English Final Retail 11/16/2007 20:40:12 2676224 bytes
Microsoft.DirectX.Direct3DX.dll: 9.04.0091.0000 English Final Retail 11/16/2007 20:40:14 2846720 bytes
Microsoft.DirectX.Direct3DX.dll: 9.05.0132.0000 English Final Retail 11/16/2007 20:40:14 563712 bytes
Microsoft.DirectX.Direct3DX.dll: 9.06.0168.0000 English Final Retail 11/16/2007 20:40:14 567296 bytes
Microsoft.DirectX.Direct3DX.dll: 9.07.0239.0000 English Final Retail 11/16/2007 20:40:14 576000 bytes
Microsoft.DirectX.Direct3DX.dll: 9.08.0299.0000 English Final Retail 11/16/2007 20:40:15 577024 bytes
Microsoft.DirectX.Direct3DX.dll: 9.09.0376.0000 English Final Retail 11/16/2007 20:40:15 577536 bytes
Microsoft.DirectX.Direct3DX.dll: 9.10.0455.0000 English Final Retail 11/16/2007 20:40:15 577536 bytes
Microsoft.DirectX.Direct3DX.dll: 9.11.0519.0000 English Final Retail 11/16/2007 20:40:16 578560 bytes
Microsoft.DirectX.Direct3DX.dll: 9.12.0589.0000 English Final Retail 11/16/2007 20:40:17 578560 bytes
Microsoft.DirectX.DirectDraw.dll: 5.04.0000.2904 English Final Retail 11/16/2007 20:40:17 145920 bytes
Microsoft.DirectX.DirectInput.dll: 5.04.0000.2904 English Final Retail 11/16/2007 20:40:17 159232 bytes
Microsoft.DirectX.DirectPlay.dll: 5.04.0000.2904 English Final Retail 11/16/2007 20:40:17 364544 bytes
Microsoft.DirectX.DirectSound.dll: 5.04.0000.2904 English Final Retail 11/16/2007 20:40:17 178176 bytes
Microsoft.DirectX.AudioVideoPlayback.dll: 5.04.0000.2904 English Final Retail 11/16/2007 20:40:17 53248 bytes
Microsoft.DirectX.Diagnostics.dll: 5.04.0000.2904 English Final Retail 11/16/2007 20:40:17 12800 bytes
Microsoft.DirectX.dll: 5.04.0000.2904 English Final Retail 11/16/2007 20:40:16 223232 bytes
dx7vb.dll: 5.03.2600.2180 Dutch Final Retail 8/4/2004 14:00:00 619008 bytes
dx8vb.dll: 5.03.2600.2180 Dutch Final Retail 8/4/2004 14:00:00 1227264 bytes
dxdiagn.dll: 5.03.2600.2180 Dutch Final Retail 8/4/2004 14:00:00 2113536 bytes
mfc40.dll: 4.01.0000.6140 English Final Retail 8/4/2004 14:00:00 924432 bytes
mfc42.dll: 6.02.4131.0000 English Final Retail 8/4/2004 14:00:00 1028096 bytes
wsock32.dll: 5.01.2600.2180 Dutch Final Retail 8/4/2004 14:00:00 24576 bytes
amstream.dll: 6.05.2600.2180 English Final Retail 8/4/2004 14:00:00 70656 bytes
devenum.dll: 6.05.2600.2180 Dutch Final Retail 8/4/2004 14:00:00 59904 bytes
dxmasf.dll: 6.04.0009.1133 Dutch Final Retail 8/24/2006 14:18:10 499254 bytes
mciqtz32.dll: 6.05.2600.2180 Dutch Final Retail 8/4/2004 14:00:00 35328 bytes
mpg2splt.ax: 6.05.2600.2180 English Final Retail 8/4/2004 14:00:00 148992 bytes
msdmo.dll: 6.05.2600.2180 English Final Retail 8/4/2004 14:00:00 14336 bytes
encapi.dll: 5.03.2600.2180 English Final Retail 8/4/2004 14:00:00 20480 bytes
qasf.dll: 11.00.5721.5145 English Final Retail 10/18/2006 21:47:18 211456 bytes
qcap.dll: 6.05.2600.2180 Dutch Final Retail 8/4/2004 14:00:00 192512 bytes
qdv.dll: 6.05.2600.2180 Dutch Final Retail 8/4/2004 14:00:00 279040 bytes
qdvd.dll: 6.05.2600.2180 Dutch Final Retail 8/4/2004 14:00:00 385536 bytes
qedit.dll: 6.05.2600.2180 Dutch Final Retail 8/4/2004 14:00:00 562688 bytes
qedwipes.dll: 6.05.2600.2180 English Final Retail 8/4/2004 14:00:00 733696 bytes
quartz.dll: 6.05.2600.3243 Dutch Final Retail 10/30/2007 00:45:24 1291776 bytes
strmdll.dll: 4.01.0000.3936 Dutch Final Retail 8/24/2006 14:19:52 246814 bytes
iac25_32.ax: 2.00.0005.0053 English Final Retail 8/4/2004 14:00:00 199680 bytes
ir41_32.ax: 4.51.0016.0003 English Final Retail 8/4/2004 14:00:00 848384 bytes
ir41_qc.dll: 4.30.0062.0002 English Final Retail 8/4/2004 14:00:00 120320 bytes
ir41_qcx.dll: 4.30.0064.0001 English Final Retail 8/4/2004 14:00:00 338432 bytes
ir50_32.dll: 5.2562.0015.0055 English Final Retail 8/4/2004 14:00:00 755200 bytes
ir50_qc.dll: 5.00.0063.0048 English Final Retail 8/4/2004 14:00:00 200192 bytes
ir50_qcx.dll: 5.00.0064.0048 English Final Retail 8/4/2004 14:00:00 183808 bytes
ivfsrc.ax: 5.10.0002.0051 English Final Retail 8/4/2004 14:00:00 154624 bytes
mswebdvd.dll: 6.05.2600.2180 Dutch Final Retail 8/4/2004 14:00:00 204800 bytes
ks.sys: 5.03.2600.2180 Dutch Final Retail 8/4/2004 00:15:21 140928 bytes
ksproxy.ax: 5.03.2600.2180 Dutch Final Retail 8/4/2004 02:03:38 130048 bytes
ksuser.dll: 5.03.2600.2180 Dutch Final Retail 8/4/2004 02:03:14 4096 bytes
stream.sys: 5.03.2600.2180 Dutch Final Retail 8/4/2004 00:08:03 48640 bytes
mspclock.sys: 5.03.2600.2180 Dutch Final Retail 8/3/2004 22:58:39 5376 bytes
mspqm.sys: 5.01.2600.2180 Dutch Final Retail 8/3/2004 22:58:41 4992 bytes
mskssrv.sys: 5.03.2600.2180 Dutch Final Retail 8/3/2004 22:58:41 7552 bytes
swenum.sys: 5.03.2600.2180 Dutch Final Retail 8/4/2004 13:59:59 4352 bytes
mstee.sys: 5.03.2600.2180 Dutch Final Retail 8/3/2004 22:58:39 5504 bytes
bdaplgin.ax: 5.03.2600.2180 Dutch Final Retail 8/4/2004 02:03:38 18432 bytes
bdasup.sys: 5.03.2600.2180 English Final Retail 8/4/2004 00:10:13 11776 bytes
msdvbnp.ax: 6.05.2600.2180 English Final Retail 8/4/2004 02:03:38 56832 bytes
psisdecd.dll: 6.05.2600.2180 English Final Retail 8/4/2004 02:03:20 363520 bytes
psisrndr.ax: 6.05.2600.2180 English Final Retail 8/4/2004 02:03:38 33280 bytes
ipsink.ax: 5.03.2600.2180 Dutch Final Retail 8/4/2004 01:03:38 16384 bytes
mpeg2data.ax: 6.05.2600.2180 English Final Retail 8/4/2004 14:00:00 118272 bytes
ndisip.sys: 5.03.2600.2180 English Final Retail 8/3/2004 23:10:13 10880 bytes
mpe.sys: 5.03.2600.2180 English Final Retail 8/3/2004 23:10:13 15360 bytes
streamip.sys: 5.03.2600.2180 English Final Retail 8/3/2004 23:10:13 15360 bytes
msvidctl.dll: 6.05.2600.2180 Dutch Final Retail 8/4/2004 14:00:00 1432576 bytes
slip.sys: 5.03.2600.2180 English Final Retail 8/3/2004 23:10:17 11136 bytes
nabtsfec.sys: 5.03.2600.2180 English Final Retail 8/3/2004 23:10:29 85376 bytes
ccdecode.sys: 5.03.2600.2180 English Final Retail 8/3/2004 23:10:17 17024 bytes
vbisurf.ax: 5.03.2600.2180 English Final Retail 8/4/2004 14:00:00 30720 bytes
msyuv.dll: 5.03.2600.2180 English Final Retail 8/4/2004 02:03:18 17408 bytes
kstvtune.ax: 5.03.2600.2180 Dutch Final Retail 8/4/2004 02:03:38 61952 bytes
ksxbar.ax: 5.03.2600.2180 English Final Retail 8/4/2004 02:03:38 43008 bytes
kswdmcap.ax: 5.03.2600.2180 Dutch Final Retail 8/4/2004 02:03:38 91136 bytes
vfwwdm32.dll: 5.01.2600.2180 Dutch Final Retail 8/4/2004 02:03:24 54272 bytes
wstcodec.sys: 5.03.2600.2180 English Final Retail 8/3/2004 23:10:21 19328 bytes
wstdecod.dll: 5.03.2600.2180 Dutch Final Retail 8/4/2004 14:00:00 51200 bytes
DirectShow Filters
WDM Streaming VBI-codecs:
NABTS/FEC VBI Codec,0x00200000,2,1,,5.03.2600.2180
CC-decoder,0x00200000,2,1,,5.03.2600.2180
WST-codec,0x00200000,1,1,,5.03.2600.2180
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,,
WMAPro over S/PDIF DMO,0x00600800,1,1,,
WMA Voice Decoder DMO,0x00600800,1,1,,
WMVideo Advanced Decoder DMO,0x00800001,1,1,,
Mpeg4s Decoder DMO,0x00800001,1,1,,
WMV Screen decoder DMO,0x00800001,1,1,,
WMVideo Decoder DMO,0x00800001,1,1,,
Mpeg43 Decoder DMO,0x00800001,1,1,,
Mpeg4 Decoder DMO,0x00800001,1,1,,
DivX Decoder Filter,0x00800000,1,1,divxdec.ax,5.02.0001.1335
HH Video Step Renderer,0x00200000,1,0,,
Subtitle Mixer,0x0080000a,2,1,,
WMT MuxDeMux Filter,0x00200000,0,0,wmm2filt.dll,2.01.4026.0000
CyberLink MPEG Decoder,0x005fff00,2,3,MDMVD.ax,5.00.0000.0929
PP PCM Wrapper,0x00200000,1,1,ppPCMEnc.ax,1.01.0000.0321
PP MPEG-1 Splitter,0x00805000,1,2,ppM1Splter.ax,2.02.0000.1919
Sony MPEG4 Video Decoder,0x00400000,1,1,sm4spvd.ax,1.21.0004.1217
Muvee MPEG Decoder,0x00600006,2,3,MuveeMVD.ax,5.00.0000.0929
PP DV Dump Filter,0x00200000,1,0,ppDVDump.ax,2.00.0001.0002
PP CES (Source),0x00200000,0,2,CLEdtKrn.dll,1.00.0000.2226
Full Screen Renderer,0x00200000,1,0,quartz.dll,6.05.2600.3243
Cyberlink TS Information,0x00200000,1,0,pdtsinfo.ax,1.00.0000.1705
Nero Scene Detector 2,0x00200000,2,0,NeSceneDetector.ax,3.02.0000.0028
CyberLink Editing Service (Source),0x00200000,0,2,CLEdtKrn.dll,2.00.0000.1311
Muvee Audio Decoder,0x00601000,1,1,MuveeAud.ax,6.00.0000.0831
CyberLink File Map Source,0x00200000,0,1,PCMRFMSrc.ax,1.00.0000.0810
PP Video Regulator,0x00200000,1,1,ppResample.ax,2.05.0000.1818
DV Muxer,0x00400000,0,0,qdv.dll,6.05.2600.2180
CyberLink SBE Filter,0x00200000,0,0,PCMRsbe.ax,1.00.0000.2517
CyberLink AudAna Filter,0x00200000,1,0,MDAudAna.dll,1.01.0000.0518
Nero Digital Audio Decoder,0x00600000,1,1,NeAudio.ax,3.02.0000.0028
CyberLink Audio Encoder (PP2.5),0x00200000,2,0,PdAudEnc.ax,1.00.0000.1419
PP YUY2 Deinterlace,0x00200000,1,1,ppDItlYuY2.ax,2.05.0000.2703
DV Scenes,0x00200000,1,1,NVDV.dll,3.00.0002.0001
PP TL MPEG-2 Splitter,0x00804500,1,2,ppTLM2Splter.ax,2.02.0000.2104
CyberLink DDR,0x00200000,1,0,pdrender.ax,2.00.0002.0026
CyberLink TL MPEG-1 Splitter,0x00804500,1,2,PDTLM1Splter.ax,2.02.0000.2213
Color Space Converter,0x00400001,1,1,quartz.dll,6.05.2600.3243
CyberLink XDS Codec,0x00200000,1,0,PCMRxdscodec.ax,1.00.0000.0322
PP MPEG Video Decoder,0x005fff00,2,3,CLMVD.ax,5.00.0000.0929
WM ASF Reader,0x00400000,0,0,qasf.dll,11.00.5721.5145
Screen Capture filter,0x00200000,0,1,wmpsrcwp.dll,11.00.5721.5145
CyberLink YUY2 Sub-Sampling,0x00200000,1,1,pdsubyuy2.ax,2.05.0000.2923
AVI Splitter,0x00600000,1,1,quartz.dll,6.05.2600.3243
WMT AudioAnalyzer,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
CyberLink Audio Effect,0x00200000,1,1,PCMRAudFx.ax,6.00.0000.0805
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.05.2600.3243
CyberLink Pipe Switch,0x00200000,1,1,PCMRPipSwch.ax,1.00.0000.0725
CyberLink DV Buffer,0x00200000,2,0,pddvbuffer.ax,2.00.0000.0801
Indeo® video 5.10 Compression Filter,0x00200000,1,1,ir50_32.dll,5.2562.0015.0055
PP IDM,0x00200000,1,1,ppIDMF.ax,1.00.0000.2207
Cyberlink Scene Detect Filter,0x00200000,1,1,pdscndt.ax,1.00.0000.0813
CyberLink AudioCD Filter (PDVD6),0x00600000,0,1,CLAudioCD.ax,5.00.0000.2107
CyberLink AVI Audio Time Regulator,0x00200000,1,1,pdavi_audtr.ax,1.00.0000.0724
PP DDR,0x00200000,1,0,ppRender.ax,2.00.0002.0026
Windows Media Audio Decoder,0x00800001,1,1,msadds32.ax,8.00.0000.4487
RealVideo Decoder,0x00400000,1,1,,
PP Video Effect,0x00200000,1,1,ppVidFx.ax,1.00.0000.1008
Cyberlink TS Information,0x00200000,1,0,ppTSInfo.ax,1.00.0000.1705
CyberLink Video Regulator,0x00200000,1,1,clrgl.ax,2.00.0000.2431
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.05.2600.2180
CyberLink Audio Decoder,0x00602000,1,1,CLAud.ax,6.00.0000.1407
PP DV Video Decoder,0x00200000,2,3,ppDVVSD.ax,6.00.0000.2130
Cyberlink TS Information,0x00200000,1,0,PCMRTSInfo.ax,1.00.0000.1407
WMT Format Conversion,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
CyberLink Audio Resampler,0x00200000,1,1,pdaursmpl.ax,1.00.0000.2625
StreamBufferSink,0x00200000,0,0,sbe.dll,6.05.2600.2180
PP Audio Resampler,0x00200000,1,1,ppAuRsmpl.ax,1.00.0000.2625
CyberLink DV Reader Filter,0x00200000,0,1,pddvmrd.ax,1.02.0009.0021
CyberLink MediaShow Filter (Source),0x00200000,0,2,MS_Source.dll,
Cyberlink Video Regulator,0x00200000,1,1,PCMDV_Resample.ax,3.05.0000.0401
WMT Black Frame Generator,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Nero Resize,0x00200000,1,1,NeResize.ax,3.02.0000.0028
MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.3243
CyberLink Audio Effect (PDVD6),0x00200000,1,1,claudfx.ax,6.00.0000.1223
Indeo® video 5.10 Decompression Filter,0x00640000,1,1,ir50_32.dll,5.2562.0015.0055
CyberLink MP3/WAV Wrapper,0x00600000,1,1,PDMP3Wrap.ax,3.06.0000.0321
WMT Screen Capture filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
CyberLink YUY2 DeInterlace,0x00200000,1,1,PCMDV_ditlyuy2.ax,2.01.0000.1715
PP Dump Dispatch Filter,0x00200000,1,0,PPDumpDispatch.ax,1.02.0001.2412
Microsoft Screen Video Decompressor,0x00800000,1,1,msscds32.ax,8.00.0000.4487
MPEG-1 Stream Splitter,0x00600000,1,2,quartz.dll,6.05.2600.3243
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.05.2600.3243
CyberLink SnapShotTIP Filter,0x00200000,1,1,pdsshot.ax,
Cyberlink Byte Counter Filter,0x00200000,1,1,pdbytecounter.ax,1.00.0000.1224
CyberLink Editing Service (Source),0x00200000,0,2,cledtkrn.dll,2.00.0000.1311
CyberLink MPEG Muxer,0x00200000,2,1,MDMpgMux.ax,5.00.0000.1727
PP File Reader (Async.),0x00200000,0,1,ppReader.ax,2.00.0000.0812
CyberLink MPEG Muxer,0x00200000,2,1,PDMpgMux.ax,4.00.0000.1313
Cyberlink File Reader (Async.),0x00200000,0,1,pdReader.ax,2.00.0000.0812
MPEG Layer-3 Decoder,0x00810000,1,1,l3codecx.ax,1.05.0000.0050
Nero Audio Stream Renderer,0x00200000,1,0,NeRender.ax,3.02.0000.0028
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.05.2600.2180
PP Snapshot Filter,0x00200000,1,0,ppSnapshot.ax,1.00.0000.0001
CyberLink Editing Service (Source),0x00200000,0,2,CLEdtKrn.dll,2.00.0000.1829
Muvee MPEG Muxer,0x00200000,2,1,MuveeMpgMux.ax,4.00.0000.1124
WAV Dest,0x00200000,0,0,wavdest.ax,
muvee HXImage Filter,0x00200000,1,1,HXImageFilter.ax,3.05.0001.0003
PP Dump Filter,0x00200000,1,0,ppDump.ax,3.00.0000.3322
PP MPEG Video Encoder,0x00200000,1,1,ppMpgVEnc.ax,5.00.0000.1104
CyberLink Audio Noise Reduction,0x00200000,1,1,CLAuNRWrapper.ax,1.00.0000.1310
ACELP.net Sipro Lab Audio Decoder,0x00800001,1,1,acelpdec.ax,1.04.0000.0000
Render Dib New,0x00200000,1,1,ezrgb24.ax,1.00.0000.0000
CyberLink OEMBUILD MPEG Audio Encoder,0x00200000,1,1,MuveeMAEnc.ax,2.05.0000.3526
CyberLink VidAna Filter,0x00200000,1,1,MDVidAna.dll,1.01.0000.0601
Nero Digital AVC Audio Encoder,0x00200000,1,2,NeNDAud.ax,3.02.0000.0028
Nero Digital AVC File Writer,0x00200000,1,0,NeNDMux.ax,3.02.0000.0028
Nero Digital AVC Null Renderer,0x00200000,1,0,NeNDMux.ax,3.02.0000.0028
Nero Digital AVC Muxer,0x00200000,2,1,NeNDMux.ax,3.02.0000.0028
Nero Digital AVC Video Enc,0x00200000,1,2,,
CyberLink SnapShot Filter,0x00200000,1,0,pdsnapshot.ax,1.00.0003.0026
PP Transform Tee,0x00200000,1,1,ppTee.ax,1.00.0000.1224
PP DV Buffer,0x00200000,2,0,ppDVBuffer.ax,1.05.0005.0022
CyberLink DV Buffer,0x00200000,0,1,ppDVDump.ax,2.00.0001.0002
CyberLink Audio Decoder (PCM45),0x00601000,1,1,CLAud.ax,6.00.0000.1718
Cyberlink SubTitle Importor (PCM45),0x00200000,1,1,CLSubTitle.ax,1.00.0000.1604
CyberLink Audio Effect (PCM45),0x00200000,1,1,claudfx.ax,6.00.0000.1223
CyberLink TimeStretch Filter (PCM45),0x00200000,1,1,clauts.ax,1.00.0000.2927
CyberLink Demultiplexer (PCM45),0x00400000,1,0,CLDemuxer.ax,1.00.0000.2728
CyberLink Line21 Decoder Filter (PCM45),0x00200000,0,2,CLLine21.ax,4.00.0000.4520
CyberLink DVD Navigator (PCM45),0x00600000,0,3,CLNavX.ax,6.00.0000.1726
CyberLink Video/SP Decoder (PCM45),0x00601000,2,3,CLVSD.ax,6.00.0000.1809
CyberLink AudioCD Filter (PCM45),0x00600000,0,1,CLAudioCD.AX,5.00.0000.2512
CyberLink Video Effect (PCM45),0x00200000,1,1,CLVidFx.ax,1.00.0000.1523
Nero QuickTime(tm) Video Decoder,0x00400000,1,1,NeQTDec.ax,3.02.0000.0028
CyberLink MPEG Video Encoder,0x00200000,1,1,pdmpgvenc.ax,5.00.0000.1305
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.05.2600.3243
CyberLink Double Pin Tee,0x00200000,1,2,PCMDV_doubletee.ax,1.00.0000.1224
CyberLink MP3 Wrapper-PCM,0x00600000,1,1,CLMP3Wrap.ax,1.00.0000.0000
CyberLink Audio CD Filter,0x00600000,0,1,claudiocd.ax,3.05.0000.0000
PCM Dump Dispatch Filter,0x00200000,1,0,PCMBDumpDispatch.ax,1.02.0001.2412
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.05.2600.3243
File Source (Netshow URL),0x00400000,0,1,wmpasf.dll,11.00.5721.5145
Nero Digital AVC Subpicture Enc,0x00200000,1,0,NeNDMux.ax,3.02.0000.0028
Nero Format Converter,0x00200000,1,1,NeroFormatConv.ax,3.02.0000.0028
CyberLink Video Effect,0x00200000,1,1,clvidfx.ax,1.00.0000.1008
WMT Import Filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
DV Splitter,0x00600000,1,2,qdv.dll,6.05.2600.2180
Bitmap Generate,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
CyberLink YUY2 DeInterlace,0x00200000,1,1,pdditlyuy2.ax,2.01.0000.1715
Windows Media Video Decoder,0x00800000,1,1,wmvds32.ax,8.00.0000.4487
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,6.05.2600.3243
PCM Dump Filter,0x00200000,1,0,PCMBDump.ax,3.00.0000.3322
Windows Media Video Decoder,0x00800000,1,1,wmv8ds32.ax,8.00.0000.4000
Subtitle Parser,0x00600000,1,1,,
PP File Reader (Async.),0x00200000,0,1,PCMBReader.ax,2.00.0000.0812
Nero Photo Source,0x00200000,0,1,NePhotoSource.ax,3.02.0000.0028
CyberLink File Map Sink,0x00200000,1,0,PCMRFMSnk.ax,1.00.0000.0810
CyberLink TimeStretch Filter (CES),0x00200000,1,1,clauts.ax,1.00.0000.2212
CyberLink Demux (PDVD6),0x00200000,1,0,CLDemuxer.ax,1.00.0000.2221
CyberLink MPEG Video Decoder,0x00200000,2,3,PCMDV_mmv.ax,4.00.0000.3013
PCM MPEG Video Encoder,0x00200000,1,1,PCMRMpgVEnc2.ax,5.00.0000.1206
WMT VIH2 Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
PP M2V Writer,0x00200000,1,0,PPM2VWriter.ax,1.03.0000.0705
CyberLink Audio Commercial Cut Analyzer,0x00200000,1,1,CLAudCM.ax,1.00.0000.1725
CLAudAna,0x00200000,1,0,pdaudana.dll,1.00.0000.1310
CyberLink Audio Commercial Cut Analyzer (PCM45),0x00200000,1,1,CLAudCM.ax,1.00.0000.2026
CyberLink Scene Detect Filter 2,0x00200000,1,1,PDScnDt2.dll,1.01.0000.1726
CyberLink TL MPEG-2 Splitter,0x00804500,1,2,MDTLM2Splter.ax,2.02.0000.2213
Nero Video Analyzer,0x00200000,2,0,NeVideoAnalyzer.ax,3.02.0000.0028
CyberLink DDR,0x00200000,1,0,PCMDV_render.ax,2.00.0002.0026
PP DV TCR,0x00200000,1,1,ppDVTCR.ax,1.07.0004.0010
PP Video Regulator,0x00200000,1,1,CLRGL.ax,2.00.0000.2213
Record Queue,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Cyberlink Video Regulator,0x00200000,1,1,PDResample.ax,2.05.0000.1818
PP TL MPEG-1 Splitter,0x00804500,1,2,ppTLM1Splter.ax,2.02.0000.2104
Nero ES Video Reader,0x00600000,0,1,NDParser.ax,3.02.0000.0028
Cyberlink Sub-Picture Filter,0x00200000,1,1,CLSubPic.ax,3.00.0000.0728
CyberLink Demultiplexer,0x00200000,1,0,pddemuxer.ax,1.00.0000.2905
CyberLink Line21 Decoder (PDVD6),0x00200000,0,2,CLLine21.ax,4.00.0000.4520
CyberLink Audio Resampler,0x00200000,1,1,MDAuRsmpl.ax,1.00.0000.2625
PP DV Reader Filter,0x00200000,0,1,ppDVMRd.ax,1.02.0009.0021
PP Audio Encoder,0x00200000,2,0,ppAudEnc.ax,2.00.0000.2927
DV Source Filter,0x00400000,0,1,NVDV.dll,3.00.0002.0001
CyberLink Load Image Filter,0x00200000,0,1,CLImage.ax,2.00.0000.0821
Nero Audio CD Filter,0x00200000,0,1,NeAudCD.ax,3.02.0000.0028
CyberLink Video Effect,0x00200000,1,1,CLVidFx.ax,1.00.0000.1008
Windows Media Multiplexer,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASX file Parser,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASX v.2 file Parser,0x00600000,1,0,wmpasf.dll,11.00.5721.5145
NSC file Parser,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
CLVAudAna,0x00200000,1,0,pdvaudana.dll,1.00.0000.1313
CyberLink MP3 Wrapper-PCM,0x00600000,1,1,PCMRmp3wrap.ax,1.00.0000.0000
PP MPEG Muxer,0x00200000,2,1,ppMpgMux.ax,5.00.0000.1228
PCM Dump Filter,0x00200000,1,0,PCMRdump.ax,3.00.0000.5303
CyberLink DV Filter,0x00200000,1,1,pddvtcr.ax,2.01.0000.1504
CyberLink M2V Writer,0x00200000,1,0,PCMBM2VWriter.ax,1.03.0000.0705
ACM Wrapper,0x00600000,1,1,quartz.dll,6.05.2600.3243
PCM MPEG-2 Splitter,0x00805000,1,2,PCMRM2Splter.ax,2.02.0000.2114
Windows Media source filter,0x00600000,0,2,wmpasf.dll,11.00.5721.5145
PP TimeStretch Filter (CES),0x00200000,1,1,clauts.ax,1.00.0000.2124
Video Renderer,0x00800001,1,0,quartz.dll,6.05.2600.3243
Frame Eater,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Nero DVD Navigator,0x00600000,0,4,NeDVD.ax,3.02.0000.0028
Sony MPEG4 AAC Decoder,0x00600000,1,1,saaclcd.ax,1.00.0004.9300
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.05.2600.2180
CyberLink DV Filter,0x00200000,1,1,PCMDV_dvtcr.ax,2.01.0009.0027
Cyberlink Dump Filter,0x00200000,1,0,PCMDV_Dump.ax,3.00.0000.3322
Line 21 Decoder,0x00600000,1,1,qdvd.dll,6.05.2600.2180
Video Port Manager,0x00600000,2,1,quartz.dll,6.05.2600.3243
CyberLink SnapShot Filter,0x00200000,1,0,PCMDV_snapshot.ax,1.00.0003.0026
WST Decoder,0x00600000,1,1,wstdecod.dll,5.03.2600.2180
CyberLink MPEG-2 Splitter,0x00805000,1,2,PCMBM2Splter.ax,2.02.0000.1919
Video Renderer,0x00400000,1,0,quartz.dll,6.05.2600.3243
CyberLink SBE Source Filter,0x00200000,0,0,PCMRsbesrc.ax,1.00.0000.2517
RealMedia Source,0x00600000,0,0,,
Nero Audio Sample Renderer,0x00200000,1,0,NeRender.ax,3.02.0000.0028
CyberLink Audio Spectrum Analyzer (PDVD6),0x00200000,1,1,CLAudSpa.ax,1.00.0000.0924
Nero Vcd Navigator,0x00600000,0,2,NeVcd.ax,3.02.0000.0028
PP TL MPEG-1 Splitter,0x00804500,1,2,ppTLM1Splter.ax,2.02.0000.2213
CyberLink Load Image Filter,0x00200000,0,1,PCMBImage.ax,2.01.0000.1223
DivX Decoder Filter,0xff800000,1,1,divxdec.ax,5.02.0001.1335
PP TL MPEG-2 Splitter,0x00804500,1,2,ppTLM2Splter.ax,2.02.0000.2213
CyberLink AVI Audio Time Regulator,0x00200000,1,1,PCMRAVI_AudTR.ax,1.00.0001.0213
PCM MPEG Video Encoder,0x00200000,1,1,PCMRMpgVEnc.ax,5.00.0000.1206
HH PlayR Video Renderer,0x00200000,1,0,,
DivXAntiFreeze,0x00800001,1,1,,
Nero Audio Processor,0x00200000,1,1,NeAudioConv.ax,3.02.0000.0028
CyberLink Audio Decoder,0x00200000,1,1,pdaud.ax,6.00.0000.1028
WM ASF Writer,0x00400000,0,0,qasf.dll,11.00.5721.5145
CyberLink MPEGV Analyzer,0x00200000,1,1,PCMRmpegvanalyzer.ax,1.00.0000.2517
WMT Sample Information Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
CyberLink MPEG Muxer,0x00200000,2,1,PDMpgMux.ax,5.00.0000.1912
Nero Mpeg2 Encoder,0x00200000,2,1,NeVCR.ax,3.02.0000.0028
PCM Video Regulator,0x00200000,1,1,PCMRResample.ax,4.00.0000.0126
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,5.03.2600.2180
CyberLink Demultiplexer,0x00400000,1,0,ppDemuxer.ax,1.00.0000.2905
CyberLink Audio Noise Reduction,0x00200000,1,1,PCMRAuNRWrapper.ax,1.00.0000.1318
Microsoft MPEG-4 Video Decompressor,0x00800000,1,1,mpg4ds32.ax,8.00.0000.4487
PCM Video Effect,0x00200000,1,1,PCMRVidFx.ax,1.00.0000.2102
Nero Video Stream Renderer,0x00200000,1,0,NeRender.ax,3.02.0000.0028
File writer,0x00200000,1,0,qcap.dll,6.05.2600.2180
PP YUY2 Sub-Sampling,0x00200000,1,1,ppSubYUY2.ax,2.05.0000.2628
CyberLink PCM Wrapper,0x00200000,1,1,PCMBPCMEnc.ax,1.01.0000.0321
PCM Audio Resampler,0x00200000,1,1,PCMBAuRsmpl.ax,1.00.0000.2415
CyberLink Video/SP Decoder,0x00600000,2,3,CLVSD.ax,6.00.0000.1402
PP MPEG Video Decoder,0x00200000,2,3,ppmmv.ax,6.00.0000.0805
CyberLink DV Dump Filter,0x00200000,1,0,PCMDV_dvdump.ax,2.01.0029.0004
CyberLink Teletext Decoder Filter,0x00200000,0,2,PCMRttxdec.ax,1.00.0000.2412
Nero PS Muxer,0x00200000,1,1,NePSMuxer.ax,3.02.0000.0028
CyberLink MPEG Muxer,0x00200000,2,1,PCMDV_MpgMux.ax,5.00.0000.0615
CyberLink Video Regulator,0x00200000,1,1,CLRGL.ax,2.00.0000.1508
CyberLink Audio Encoder,0x00200000,2,0,PCMDV_AudEnc.ax,2.00.0000.2031
PP WAV Dest,0x00200000,0,0,PPWavDest.ax,1.00.0000.0002
WMT Log Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Virtual Renderer,0x00200000,1,0,wmm2filt.dll,2.01.4026.0000
DirectVobSub,0x00200000,2,1,DVobSub.ax,2.00.0023.0000
CyberLink Transform Tee,0x00200000,1,1,pdtee.ax,3.00.0000.3130
CyberLink Demultiplexer,0x00200000,1,0,PCMRdemuxer.ax,1.00.0000.3807
RealAudio Decoder,0x00400000,1,1,,
PP Byte Counter,0x00200000,1,1,ppByteCounter.ax,1.00.0000.1224
PCM SnapShotTIP Filter,0x00200000,1,1,PCMRSShot.ax,1.00.0000.1905
CyberLink MPEG-1 Splitter,0x00805000,1,2,PCMBM1Splter.ax,2.02.0000.1919
DirectVobSub (auto-loading version),0x0080000b,2,1,DVobSub.ax,2.00.0023.0000
Cyberlink Dump Filter,0x00200000,1,0,PDDump.ax,3.00.0000.3322
CyberLink DV Dump Filter,0x00200000,1,0,pddvdump.ax,2.01.0034.0028
CyberLink Audio Encoder,0x00200000,2,0,PCMBAudEnc.ax,2.00.0000.2221
PP Audio Decoder,0x00200001,1,1,claud.ax,6.00.0000.1210
DVD Navigator,0x00200000,0,2,qdvd.dll,6.05.2600.2180
CyberLink MPEG Decoder,0x00600006,2,3,CLMVD.ax,5.00.0000.0929
CyberLink DVD Navigator (PDVD6),0x00600000,0,3,CLNavX.ax,6.00.0000.1414
Cyberlink Dump Dispatch Filter,0x00200000,1,0,pddumpdispatch.ax,1.02.0001.2412
IDM Filter,0x00200000,1,1,MDIDMF.ax,1.00.0000.2207
CyberLink TimeStretch Filter (PDVD6),0x00200000,1,1,clauts.ax,1.00.0000.2212
PP MPEG-2 Splitter,0x00805000,1,2,ppM2Splter.ax,2.02.0000.1919
PCM MPEG Muxer,0x00200000,2,1,PCMRMpgMux.ax,5.00.0000.2221
Cyberlink Scene Detect Filter,0x00200000,1,1,ppScnDt.ax,1.00.0000.0813
Overlay Mixer2,0x00400000,1,1,qdvd.dll,6.05.2600.2180
Subtitle Source,0x00200000,0,1,DVobSub.ax,2.00.0023.0000
Cyberlink SubTitle Importor (PDVD6),0x00200000,1,1,CLSubTitle.ax,1.00.0000.1307
CyberLink Video Regulator,0x00200000,1,1,CLRGL.ax,2.00.0000.2514
Nero Splitter,0x00600000,1,3,NeSplitter.ax,3.02.0000.0028
PP Audio Noise Reduction (CES),0x00200000,1,1,CLAuNRWrapper.ax,1.00.0000.1310
JWVidRender,0x00200000,1,0,,
CyberLink Video Effect,0x00200000,1,1,PDVidFx.ax,1.00.0000.0526
CyberLink MPEG Video Encoder,0x00200000,1,1,MpgVEnc.ax,5.00.0000.0726
CyberLink MPEG Video Encoder,0x00200000,1,1,PCMDV_MpgVEnc.ax,5.00.0000.0920
CyberLink Video/SP Decoder,0x005ffc18,2,3,PCMBVSD.ax,6.00.0000.1919
AC3Filter,0x40000000,1,1,ac3filter.ax,1.03.0001.0000
AVI Draw,0x00600064,9,1,quartz.dll,6.05.2600.3243
CyberLink TimeStretch Filter,0x00200000,1,1,PCMRAuts.ax,1.00.0000.2108
CyberLink VAudAna Filter,0x00200000,1,0,MDVAudAna.dll,1.01.0000.0506
.RAM file Parser,0x00600000,1,0,wmpasf.dll,11.00.5721.5145
Muvee MPEG-2 Splitter,0x00805000,1,2,MuveeM2Splter.ax,2.01.0000.2402
muvee Video Analyser,0x00200000,1,0,mvvanalyse.ax,3.05.0001.0003
muvee Music Analyser,0x00200000,1,0,mvmanalyse.ax,3.05.0001.0003
Bicubic Video Resizer,0x00800002,1,1,,
CyberLink Real File writer,0x00200000,2,0,pdrmfilewriter.ax,1.00.0000.0723
PP Gate Filter,0x00200000,1,1,ppGate.ax,1.00.0000.0001
Nero File Source / Splitter,0x00600000,0,3,NeFSource.ax,3.02.0000.0028
CyberLink Audio Encoder,0x00200000,2,0,PDAudEnc.ax,2.00.0000.2806
PP Audio Encoder,0x00200000,2,0,ppAudEnc.ax,2.00.0000.2221
CLVidAna,0x00200000,1,1,pdvidana.dll,1.00.0000.1312
WMT DirectX Transform Wrapper,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Muvee MPEG-1 Splitter,0x00805000,1,2,MuveeM1Splter.ax,2.01.0000.2402
G.711 Codec,0x00200000,1,1,g711codc.ax,5.01.2600.0000
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.05.2600.2180
Cyberlink Dump Filter,0x00200000,1,0,MDDump.ax,3.00.0000.3322
DV Video Decoder,0x00800000,1,1,qdv.dll,6.05.2600.2180
CyberLink DV Buffer,0x00200000,2,0,PCMDV_dvbuffer.ax,1.06.0003.0003
CyberLink MPEG Decoder,0x00600006,2,3,PDMVD.ax,5.00.0000.0929
Cyberlink TS Filter Filter,0x00200000,1,1,PCMRTSFF.ax,1.00.0000.1407
Indeo® audio software,0x00500000,1,1,iac25_32.ax,2.00.0005.0053
Cyberlink Gate Filter,0x00200000,1,1,pdgate.ax,1.00.0000.0001
Windows Media Update Filter,0x00400000,1,0,wmpasf.dll,11.00.5721.5145
HH-DV-Pin Tee,0x00200000,1,1,,
Cyberlink DV Scene Detect Filter,0x00200000,1,1,pddvscndt.ax,1.00.0000.0426
ASF DIB Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASF ACM Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASF ICM Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASF URL Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASF JPEG Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASF DJPEG Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
ASF embedded stuff Handler,0x00600000,1,1,wmpasf.dll,11.00.5721.5145
CyberLink WAV Dest,0x00200000,0,0,pdwavdest.ax,1.00.0000.0002
PCM Audio Resampler,0x00200000,1,1,PCMRAuRsmpl.ax,1.00.0000.2304
9x8Resize,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WIA Stream Snapshot Filter,0x00200000,1,1,wiasf.ax,1.00.0000.0000
Nero Video Processor,0x00200000,1,1,NeroVideoProc.ax,3.02.0000.0028
PCM Audio Encoder,0x00200000,2,0,PCMRaudenc.ax,2.00.0000.3516
CyberLink MPEG Video Encoder,0x00200000,1,1,MDMPGVEnc.ax,5.00.0000.1305
CyberLink Audio CD Filter,0x00600000,0,1,pdaudiocd.ax,3.05.0000.0000
Nero Video Decoder,0x00600000,2,2,NeVideo.ax,3.02.0000.0028
Allocator Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
IDM Filter,0x00200000,1,1,pdidmf.ax,1.00.0000.2207
PowerProducer Double Tee,0x00200000,1,2,ppDoubleTee.ax,1.00.0000.1224
SampleGrabber,0x00200000,1,1,qedit.dll,6.05.2600.2180
Null Renderer,0x00200000,1,0,qedit.dll,6.05.2600.2180
WMT Virtual Source,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
MPEG-2 Sections and Tables,0x005fffff,1,0,Mpeg2Data.ax,6.05.2600.2180
WMT Interlacer,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Nero Audio CD Navigator,0x00200000,0,1,NeAudCD.ax,3.02.0000.0028
StreamBufferSource,0x00200000,0,0,sbe.dll,6.05.2600.2180
Smart Tee,0x00200000,1,2,qcap.dll,6.05.2600.2180
CyberLink Load Image Filter,0x00200000,0,1,CLImage.ax,2.01.0000.1223
CyberLink TL MPEG-2 Splitter,0x00804500,1,2,PDTLM2Splter.ax,2.02.0000.2213
Overlay Mixer,0x00200000,0,0,qdvd.dll,6.05.2600.2180
Nero Scene Detector,0x00200000,1,0,NeSceneDetector.ax,3.02.0000.0028
MuVee MPEG Video Encoder,0x00200000,1,1,MuveeVEnc.ax,4.00.0000.1121
RealPlayer Audio Filter,0x00200000,1,1,rdsf3260.dll,6.00.0012.1208
CyberLink MPEG Video Encoder,0x00200000,1,1,PCMBMpgVEnc.ax,5.00.0000.1104
AVI Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.3243
Uncompressed Domain Shot Detection Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
PP Video Regulator,0x00200000,1,1,CLRGL.ax,2.00.0000.2514
CyberLink MPEG-1 Splitter,0x00805000,1,2,CLM1Splter.ax,2.02.0000.3710
Sony MP4 File Source,0x00800000,0,1,MP4FileSource.ax,1.00.0000.10050
PP SnapShotTIP Filter,0x00200000,1,1,ppSShot.ax,
AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.05.2600.3243
Cyberlink Dump Dispatch Filter,0x00200000,1,0,MDDumpDispatch.ax,1.02.0001.2412
Magix DS Capture,0x00200000,2,0,,
Morgan Stream Switcher,0x00800003,1,1,,
QuickTime Movie Parser,0x00600000,1,1,quartz.dll,6.05.2600.3243
Wave Parser,0x00400000,1,1,quartz.dll,6.05.2600.3243
MIDI Parser,0x00400000,1,1,quartz.dll,6.05.2600.3243
Multi-file Parser,0x00400000,1,1,quartz.dll,6.05.2600.3243
File stream renderer,0x00400000,1,1,quartz.dll,6.05.2600.3243
XML Playlist,0x00400000,1,0,wmpasf.dll,11.00.5721.5145
CyberLink DV Reader Filter,0x00200000,0,1,PCMDV_dvmrd.ax,1.02.0009.0021
Nero File Source,0x00200000,0,1,NeFileSrc.ax,3.02.0000.0028
Nero QuickTime(tm) Audio Decoder,0x00400000,1,1,NeQTDec.ax,3.02.0000.0028
CyberLink MPEG Video Decoder,0x00200000,2,3,pdmmv.ax,4.00.0000.3013
CyberLink Audio Encoder,0x00200000,2,0,MDAudEnc.ax,2.00.0000.1901
Nero File Source (Async.),0x00400000,0,1,NeFileSourceAsync.ax,3.02.0000.0028
CyberLink AVI Audio Time Regulator,0x00200000,1,1,AVI_AudTR.ax,1.00.0000.1515
Nero DVD Decoder,0x00600000,2,1,NeVideo.ax,3.02.0000.0028
PCM Video/SP Decoder,0x00600000,2,3,PCMRVSD.ax,6.00.0000.2109
CyberLink Video/SP Decoder (ShEX),0x005ffc18,2,3,CLImageVSD.ax,6.00.0000.1625
CyberLink TL MPEG-1 Splitter,0x00804500,1,2,MDTLM1Splter.ax,2.02.0000.2213
Nero Digital Parser,0x00600000,0,3,NDParser.ax,3.02.0000.0028
RealMedia Splitter,0x00600000,1,1,,
AVI Mux,0x00200000,1,0,qcap.dll,6.05.2600.2180
Subtitle Dest,0x00200000,1,1,,
CyberLink Double Pin Tee,0x00200000,1,2,pddoubletee.ax,1.00.0000.1224
CyberLink QuickTime Source Filter,0x00200000,0,2,clqtsrc.ax,1.00.0000.1417
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.05.2600.3243
File Source (Async.),0x00400000,0,1,quartz.dll,6.05.2600.3243
File Source (URL),0x00400000,0,1,quartz.dll,6.05.2600.3243
WMT DV Extract,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
PP Video Regulator,0x00200000,1,1,PCMBResample.ax,2.05.0000.1818
CyberLink LPCM Converter,0x00800000,1,1,LPCMCvrt.ax,1.00.0001.2411
Magix WAV Dest,0x00200000,0,0,,
CyberLink PTS Regulator,0x00200000,1,1,PCMPTSReg.ax,1.00.0000.1209
PCM Audio Decoder,0x00200000,1,1,PCMRAud.ax,6.00.0000.1027
Cyberlink Gate Filter,0x00200000,1,1,PCMDV_gate.ax,1.00.0000.0001
CyberLink Audio Decoder,0x00200000,1,1,MDAUD.ax,6.00.0000.1620
Nero Frame Capture,0x00200000,1,1,NeCapture.ax,3.02.0000.0028
CyberLink YUY2 Sub-Sampling,0x00200000,1,1,PCMDV_subyuy2.ax,2.05.0000.2923
CyberLink M2V Writer,0x00200000,1,0,CLM2VWriter.ax,1.02.0001.1713
PP Audio Decoder,0x00200000,1,1,claud.ax,6.00.0000.0903
CyberLink PCM Wrapper,0x00200000,1,1,CLPCMEnc.ax,1.01.0000.0321
WMT Switch Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
PP MPEG Muxer,0x00200000,2,1,ppMpgMux.ax,5.00.0000.1214
PP Video Effect,0x00200000,1,1,ppVidFx.ax,1.00.0000.0803
WMT Volume,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
CyberLink MPEG-2 Splitter,0x00805000,1,2,CLM2Splter.ax,2.02.0000.3710
Nero Video Sample Renderer,0x00200000,1,0,NeRender.ax,3.02.0000.0028
CyberLink Video/SP Decoder,0x00200000,2,3,pdvsd.ax,6.00.0000.1830
CyberLink EPG Decoder,0x00200000,1,1,PCMREpgDec.ax,1.00.0000.2412
Stretch Video,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Muvee Dump Filter,0x00200000,1,0,MuveeDump.ax,3.00.0000.3322
Cyberlink Video Regulator,0x00200000,1,1,pdresample.ax,2.05.0000.1818
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.05.2600.2180
Nero DV Splitter,0x00200000,1,2,NeDVSplitter.ax,3.02.0000.0028
PP TimeStretch Filter (CES),0x00200000,1,1,clauts.ax,1.00.0000.2212
CyberLink QuickTime writer,0x00200000,2,0,pdqtfilewriter.ax,1.00.0000.0723
CyberLink Audio Noise Reduction,0x00200000,1,1,claunrwrapper.ax,1.00.0000.1310
BDA MPEG2 Transport Information Filter,0x00200000,1,0,PsisRndr.ax,6.05.2600.2180
QT Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.3243
MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.05.2600.3243
Cyberlink Dump Dispatch Filter,0x00200000,1,0,CLDumpDispatch.ax,1.02.0001.2412
Indeo® video 4.4 Decompression Filter,0x00640000,1,1,ir41_32.ax,4.51.0016.0003
Indeo® video 4.4 Compression Filter,0x00200000,1,1,ir41_32.ax,4.51.0016.0003
WDM streaming-tee/splitter-apparatuur:
Tee/Sink-to-Sink-conversieprogramma,0x00200000,1,1,,5.03.2600.2180
WDM streaming-gegevenstransformaties:
Microsoft Kernel akoestische echo-opheffing,0x00000000,0,0,,
Microsoft Kernel GS Wavetable-synthesizer,0x00200000,1,1,,5.03.2600.2180
Microsoft Kernel DLS-synthesizer,0x00200000,1,1,,5.03.2600.2180
Microsoft Kernel DRM-audiodecoder,0x00200000,1,1,,5.03.2600.2180
Video Compressors:
WMVideo8 Encoder DMO,0x00600800,1,1,,
MSScreen encoder DMO,0x00600800,1,1,,
WMVideo9 Encoder DMO,0x00600800,1,1,,
MSScreen 9 encoder DMO,0x00600800,1,1,,
DV Video Encoder,0x00200000,0,0,qdv.dll,6.05.2600.2180
Indeo® video 5.10 Compression Filter,0x00100000,1,1,ir50_32.dll,5.2562.0015.0055
MJPEG Compressor,0x00200000,0,0,quartz.dll,6.05.2600.3243
Nero Digital AVC Video Enc,0x00200000,1,2,NeNDVid.ax,3.02.0000.0028
Cinepak Codec by Radius,0x00200000,1,1,qcap.dll,6.05.2600.2180
DivX® 5.2.1 Codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel 4:2:0 Video V2.50,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel Indeo(R) Video R3.2,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel Indeo® Video 4.5,0x00200000,1,1,qcap.dll,6.05.2600.2180
Indeo® video 5.10,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel IYUV-codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft H.261 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft H.263 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft RLE,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft Video 1,0x00200000,1,1,qcap.dll,6.05.2600.2180
VP60® Simple Profile ,0x00200000,1,1,qcap.dll,6.05.2600.2180
VP61® Advanced Profile,0x00200000,1,1,qcap.dll,6.05.2600.2180
Audio Compressors:
WMA Voice Encoder DMO,0x00600800,1,1,,
WM Speech Encoder DMO,0x00600800,1,1,,
WMAudio Encoder DMO,0x00600800,1,1,,
IAC2,0x00200000,1,1,quartz.dll,6.05.2600.3243
Lernout & Hauspie CELP 4.8kbit/s,0x00200000,1,1,quartz.dll,6.05.2600.3243
Lernout & Hauspie SBC 8kbit/s,0x00200000,1,1,quartz.dll,6.05.2600.3243
Lernout & Hauspie SBC 12kbit/s,0x00200000,1,1,quartz.dll,6.05.2600.3243
Lernout & Hauspie SBC 16kbit/s,0x00200000,1,1,quartz.dll,6.05.2600.3243
IMA ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.3243
Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.3243
ACELP.net,0x00200000,1,1,quartz.dll,6.05.2600.3243
DSP Group TrueSpeech(TM),0x00200000,1,1,quartz.dll,6.05.2600.3243
Windows Media Audio V1,0x00200000,1,1,quartz.dll,6.05.2600.3243
Windows Media Audio V2,0x00200000,1,1,quartz.dll,6.05.2600.3243
GSM 6.10,0x00200000,1,1,quartz.dll,6.05.2600.3243
Messenger Audio Codec,0x00200000,1,1,quartz.dll,6.05.2600.3243
Microsoft G.723.1,0x00200000,1,1,quartz.dll,6.05.2600.3243
CCITT A-Law,0x00200000,1,1,quartz.dll,6.05.2600.3243
CCITT u-Law,0x00200000,1,1,quartz.dll,6.05.2600.3243
AC3,0x00200000,1,1,quartz.dll,6.05.2600.3243
DTS,0x00200000,1,1,quartz.dll,6.05.2600.3243
MPEG Layer-3,0x00200000,1,1,quartz.dll,6.05.2600.3243
Audio Capture Sources:
Realtek HD Audio input,0x00200000,0,0,qcap.dll,6.05.2600.2180
713x BDA Analog Audio Capture,0x00200000,0,0,qcap.dll,6.05.2600.2180
713x BDA Analog Audio Capture (,0x00200000,0,0,qcap.dll,6.05.2600.2180
Realtek HD Digital input,0x00200000,0,0,qcap.dll,6.05.2600.2180
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,quartz.dll,6.05.2600.3243
Microsoft GS Wavetable-software,0x00200000,1,0,quartz.dll,6.05.2600.3243
WDM streaming-opnameapparaten:
Realtek HD Digital input,0x00200000,1,1,,5.03.2600.2180
,0x00000000,0,0,,
713x BDA Analog Capture,0x00200000,6,1,,5.03.2600.2180
713x BDA Analog Audio Capture,0x00200000,2,0,,5.03.2600.2180
WDM streaming-opbouwprincipeapparatuur:
Realtek HD Audio output,0x00200000,2,1,,5.03.2600.2180
BDA-bronfilters:
713x BDA DVBT Tuner,0x00200000,0,0,,5.03.2600.2180
713x BDA DVBS Tuner,0x00200000,0,0,,5.03.2600.2180
BDA Rendering Filters:
BDA IP Sink,0x00200000,1,1,,5.03.2600.2180
BDA Network Providers:
Microsoft ATSC Network Provider,0x00200000,0,1,MsDvbNp.ax,6.05.2600.2180
Microsoft DVBC Network Provider,0x00200000,0,1,MsDvbNp.ax,6.05.2600.2180
Microsoft DVBS Network Provider,0x00200000,0,1,MsDvbNp.ax,6.05.2600.2180
Microsoft DVBT Network Provider,0x00200000,0,1,MsDvbNp.ax,6.05.2600.2180
Video Capture Sources:
BDA Transport Information Renderers:
BDA MPEG2 Transport Information Filter,0x00600000,1,0,PsisRndr.ax,6.05.2600.2180
MPEG-2 Sections and Tables,0x00600000,1,0,Mpeg2Data.ax,6.05.2600.2180
TV/tuner-apparatuur voor WDM-streaming:
713x BDA Analog TV Tuner,0x00200000,2,0,,5.03.2600.2180
Crossbar-apparatuur voor WDM-streaming:
713x BDA Analog Xbar,0x00200000,8,0,,5.03.2600.2180
TV/audio-apparatuur voor WDM-streaming:
713x BDA Analog TV Audio,0x00200000,2,0,,5.03.2600.2180
BDA CP/CA Filters:
Decrypt/Tag,0x00600000,1,0,encdec.dll,6.05.2600.2180
Encrypt/Tag,0x00200000,0,0,encdec.dll,6.05.2600.2180
XDS Codec,0x00200000,0,0,encdec.dll,6.05.2600.2180
WDM streaming-communicatietransformaties:
Audio Renderers:
CyberLink Audio Renderer (PCM45),0x00200000,1,0,CLADR.ax,6.00.0000.1727
CyberLink Audio Renderer (PDVD6),0x00200000,1,0,CLADR.ax,6.00.0000.1318
Default DirectSound Device,0x00800000,1,0,quartz.dll,6.05.2600.3243
Default WaveOut Device,0x00200000,1,0,quartz.dll,6.05.2600.3243
DirectSound: Realtek HD Audio output,0x00200000,1,0,quartz.dll,6.05.2600.3243
WDM-streaming systeemapparaten:
Realtek HD Audio input,0x00200000,5,1,,5.03.2600.2180
Realtek HD Audio output,0x00200000,13,1,,5.03.2600.2180
713x BDA Analog Audio Capture,0x00200000,1,1,,5.03.2600.2180
BDA Receiver Component:
713x BDA Digital Capture,0x00200000,2,0,,5.03.2600.2180
BDA Slip De-Framer,0x00600000,1,1,,5.03.2600.2180
BDA MPE-filter,0x00600000,1,1,,5.03.2600.2180
