<?php
if(!file_exists("config.php")){
header("Location: installer.php");
exit();
session_start(); ?>
<html>
<head>
<style>
body{
padding: 0;
margin: 0;
font-family: Arial, Helvetica, sans-serif;
font-size: 12px;
fieldset.message, fieldset.warning, fieldset.notice, fieldset.error, fieldset.personal{
display: block;
margin: 3px;
padding: 5px;
-moz-border-radius: 10px;
fieldset.warning{
border: 1px solid #800000;
background: #CC0000;
color: #ffffff;
fieldset.notice{
border: 1px solid #c8c8c8;
background: #e6e6e6;
fieldset.personal{
border: 1px solid #bfc790;
background: #eff3d4;
fieldset.error{
legend.messageheading{
color:#999999;
display: block;
div.messagebody{
color: #000000;
display: block;
span.name{
color:#CC0000;
#chatwindow{
height: 80%;
width:100%;
overflow: scroll;
form{
margin: 0; padding: 0;
tt{
color: #990000;
tt .optional{
color: #009900;
table{
width: 100%;
table, tr, td, th{
font-size: 12px;
tr{
border-bottom: 1px solid grey;
</style>
var timeout = 5;//hoeveel seconden tussen de updates
//einde intellingen.
var xmlhttp=false;
/*@cc_on @*/
/*@if (@_jscript_version >= 5)
// JScript gives us Conditional compilation, we can cope with old IE versions.
// and security blocked creation of the objects.
try {
xmlhttp = new ActiveXObject("Msxml2.XMLHTTP");
} catch (e) {
try {
xmlhttp = new ActiveXObject("Microsoft.XMLHTTP");
} catch (E) {
xmlhttp = false;
@end @*/
if (!xmlhttp && typeof XMLHttpRequest!='undefined') {
xmlhttp = new XMLHttpRequest();
var dead = false;
<?php
if(isset($_SESSION['name'])){
echo "var nickname = \"".$_SESSION['name']."\";\n";
else{
echo "var nickname = \"annoniem\";\n";
echo "var basepath = \"http://".$_SERVER['HTTP_HOST'].dirname($_SERVER['PHP_SELF'])."/\";\n";
var timer = 0;
var busy = false;
function setname()
busy = true;
document.getElementById("submitbutton").disabled = true;
var d = new Date();
var newname = prompt("Wat is je nickname", nickname);
if(newname != null){
xmlhttp.open("GET",basepath+"server.php?message=/NAME "+newname+"&random="+d.getFullYear()+(d.getMonth()+1)+d.getDate()+d.getHours()+d.getMinutes()+d.getSeconds(),true);
xmlhttp.onreadystatechange=function() {
if (xmlhttp.readyState==4) {
if(xmlhttp.responseText.indexOf("OK") != -1){
document.getElementById('chatwindow').innerHTML += "<fieldset class=\"notice\">"+nickname+" has changed his name to "+newname+"</fieldset>\n";
document.getElementById('chatwindow').scrollTop = 10000000;
nickname = newname;
update("undefined");
//else{
// alert("Failed to set nickname:\n"+xmlhttp.responseText);
// dead = true;
busy = false;
xmlhttp.send(null);
else
document.getElementById("submitbutton").disabled = false;
busy = false;
return true;
busy = false;
function setaway()
var d = new Date();
xmlhttp.open("GET",basepath+"server.php?message=/AWAY&random="+d.getFullYear()+(d.getMonth()+1)+d.getDate()+d.getHours()+d.getMinutes()+d.getSeconds(),true);
document.getElementById('chatwindow').innerHTML += "<fieldset class=\"notice\">Lastid is has successfully reset to zero</fieldset>\n";
dead = true;
else{
alert("Failed to reset your id:\n"+xmlhttp.responseText);
dead = true;
xmlhttp.send(null);
function update(bericht)
if(bericht.toUpperCase() == "/DISCONNECT"){
setaway;
dead = true;
if(bericht != "" && busy != true && dead != true){
busy = true;
timer = timeout;
var d = new Date()
if(bericht == "undefined"){
var url = "server.php?random="+d.getFullYear()+(d.getMonth()+1)+d.getDate()+d.getHours()+d.getMinutes()+d.getSeconds();
else{
var url = "server.php?message="+bericht+"&random="+d.getFullYear()+(d.getMonth()+1)+d.getDate()+d.getHours()+d.getMinutes()+d.getSeconds();
xmlhttp.open("GET",basepath+url,true);//method, target, async (set always true!)
if(xmlhttp.responseText != "" && xmlhttp.responseText != " "){
if(xmlhttp.responseText.indexOf("SETNAME") != -1)
setname();
else{
var rows = xmlhttp.responseText.split("\n");
for(i = 0; i <= rows.length-1; i++)
var data = rows[i].split("||");
if(data[0] == "OK"){ var type = data[1];}
else{ var type = data[0];}
switch(type.toUpperCase()){
case "DIE":
if(data[0] == "OK"){data[0]=data[1];data[1]=data[2];}
document.getElementById('chatwindow').innerHTML += "<fieldset class=\"error\"><div class=\"messagebody\">"+data[1]+"</div></fieldset>\n";
dead=true;
break;
case "MESSAGE":
if(data[0] == "OK"){data[0]=data[1];data[1]=data[2];data[2]=data[3],data[3]=data[4],data[4]=data[5];}
document.getElementById('chatwindow').innerHTML += "<fieldset class=\"message\"><legend class=\"messageheading\"><span class=\"id\">"+data[1]+"</span><span class=\"name\">"+data[2]+"</span> said on "+data[3]+":</legend><div class=\"messagebody\">"+data[4]+"</div></fieldset>\n";
break;
case "NOTICE":
document.getElementById('chatwindow').innerHTML += "<fieldset class=\"notice\"><div class=\"messagebody\">"+data[4]+"</div></fieldset>\n";
break;
case "PERSONAL":
document.getElementById('chatwindow').innerHTML += "<fieldset class=\"personal\"><div class=\"messagebody\">"+data[1]+"</div></fieldset>\n";
break;
case "WARNING":
document.getElementById('chatwindow').innerHTML += "<fieldset class=\"warning\"><div class=\"messagebody\">"+data[1]+"</div></fieldset>\n";
break;
default:
document.getElementById('chatwindow').innerHTML += "<fieldset class=\"error\">"+xmlhttp.responseText+"</fieldset>\n";
break;
xmlhttp.send(null);
busy = false;
else{ if(dead){
if(bericht.toUpperCase() == "/CONNECT"){
dead = false;
counter();
document.getElementById('chatwindow').innerHTML = "<fieldset class=\"Notice\">Client has been reset.</fieldset>\n";
function counter()
if(!dead){
if(timer <= 0)
timing = setTimeout("counter()", 1000);
else{
timer = timer-2;
else{
clearTimeout(timing)
document.getElementById('chatwindow').innerHTML += "<fieldset class=\"error\">Client terminated. Please reload this page to restart the chat.</fieldset>\n";
</script>
</head>
<body onunload="setaway()">
<div id="chatwindow"></div>
<form name="formulier" onSubmit="javascript: update(document.getElementById('chattext').value);document.getElementById('chattext').value = '';return false;">
<input type="text" id="chattext" name="chattext" maxlength="256" style="width: 450px; "/>
<input type="submit" id="submitbutton" value="Say!" style="width:150px; "/>
<input type="button" onClick="setname()" value="andere naam"/>
</form>
<script>
counter();
</script>
<br/>
</body>
</html>
-------------------------server.php (zoals de naam al zegt)----------------------------
<?php
ob_start();
session_start();
error_reporting(E_ALL);
/*SQLtable
CREATE TABLE IF NOT EXISTS `PREFIXmessages` (
`id` int(8) NOT NULL auto_increment,
`message` mediumtext NOT NULL,
`author` text NOT NULL,
`ip` varchar(15) NOT NULL default '',
`timestamp` int(10) NOT NULL default '0',
`type` enum('message','notice','warning','error') NOT NULL default 'message',
UNIQUE KEY `id` (`id`)
) TYPE=MyISAM AUTO_INCREMENT=42 ;
//instellingen
require("config.php");
//optionele hooks
function messagepreparser($message){
//deze functie wordt uitgevoerd voordat het bericht in de database wordt geplaatst
function outputparser($input){
//als je de gehele uitvoer nog eventjes wilt doorscannen op dingen die niet kunnen,
//zoals scheldwoorden. Deze functie heeft in tegenstelling tot de vorige 2 ook invloed
//op het naamveld het de timestamp
$output = str_replace("****", "f*ck", $input);
return $output;
//belangrijke array defineren
$commands = array();
//even wat standaard commando's defineren
$commands['name'] = array();
$commands['name']['usage'] = '/name [nickname]';
$commands['name']['description'] = 'Change your nickname.';
$commands['name']['help'] = '<tt>/name</tt> changes your nickname and will inform all others.<br/>Warning: You may not use spaces in your nickname.';
$commands['name']['function'] = '
unset($parameters[0]);
$newname = implode(" ", $parameters);
if(!isset($_SESSION[\'name\'])){
addmessage($newname." has joined the chat", "Server", "notice");
else{
addmessage($_SESSION[\'name\']." has changed his name to ".$newname,"Server","notice");
$_SESSION[\'name\'] = $newname;
print("OK||");
return true;
$commands['away'] = array();
$commands['away']['usage'] = '/away';
$commands['away']['description'] = 'Disconnects you from the chat.';
$commands['away']['help'] = '<tt>/away</tt> will send a message to all users that you have left the chatroom. Then it will reset all your personal variables and eventually your client will get the message to stop.<br/>This function is automaticly called when you leave the client.<br/>You can reconnect with the chat by reloading your browserwindow or type <tt>/connect</tt> in your messagebar.';
$commands['away']['function'] = '
unset($_SESSION[\'lastupdate\']);
if(isset($_SESSION[\'isadmin\'])){unset($_SESSION[\'isadmin\']);}
if(addmessage($_SESSION[\'name\']." has left the chat", "Server", "notice") && !isset($_SESSION[\'lastupdate\']) && define("STOP", true) && print("OK||DIE||You have logged out.")){
return true;
$commands['help'] = array();
$commands['help']['usage'] = '/help <span class="optional">[command]</span>';
$commands['help']['description'] = 'displays the message that you are now reading.';
$commands['help']['help'] = 'With <tt>/help</tt> you can display a listing of all available commands or by typing for example <tt>/help name</tt> you will see the help for <tt>/name</tt> if available.';
//standaardfuncties
function connected(){
global $dbverbinding;
/********hook********/
if(defined('ADD_connected')){
eval(ADD_connected);
if(!defined("CONNECTED")){
if($dbverbinding=mysql_connect(MYSQL_SERVER,MYSQL_USER,MYSQL_PASSWORD)){
if(mysql_select_db(MYSQL_DATABASE,$dbverbinding)){
if(define("CONNECTED", true)){return true;}
else{
print("DIE||Kon de constante <i>CONNEDTED</i> niet dsefineren\n");
return false;
else{
print("DIE||Fout nr ".mysql_errno($dbverbinding)." bij het selecteren van de database: ".mysql_error($dbverbinding)."\n");
return false;
else{
print("DIE||Fout bij het verinding maken met de database op ".MYSQL_SERVER." als ".MYSQL_USER."\n");
return false;
else{
return true;
function addmessage($message = "", $name = "Annoniem", $type="message"){
if(defined('ADD_addmessage')){
eval(ADD_addmessage);
if($message{0} == "/"){
if(command($message)){
return true;
else{
if(trim($message) != ""){
if(connected()){
if($name == "Annoniem" && isset($_SESSION['name'])){
$name = $_SESSION['name'];
if(function_exists("messagepreparser")){
$message = messagepreparser($message);
else{
$message = strip_tags($message,'<b> <u> <i>');
if(mysql_query("INSERT INTO ".MYSQL_PREFIX."messages (message,author,ip,timestamp,type) VALUES ('".$message."','".htmlentities($name)."','".$_SERVER['REMOTE_ADDR']."',".mktime().",'".$type."')")){
return true;
else{
print("DIE||Error nr ".mysql_errno($dbverbinding)." while executing SQLquery: ".mysql_error($dbverbinding)."\n");
return false;
else{
print("DIE||Function addmessage() doesn't get a connection to the database");
return false;
else{
return false;
function echomessages(){
$awnser = array();
if(defined('ADD_echomessages')){
eval(ADD_echomessages);
if(connected()){
if(!isset($_SESSION['lastupdate'])){
$query = "SELECT * FROM ".MYSQL_PREFIX."messages WHERE timestamp > ".(mktime()-60*60*24)." ORDER BY id DESC LIMIT ".FIRSTTIME_MAX_MESSAGES;
else{
$query = "SELECT * FROM ".MYSQL_PREFIX."messages WHERE timestamp > ".$_SESSION['lastupdate']." ORDER BY id DESC LIMIT ".MAX_MESSAGES;
if($results = mysql_query($query)){
while($row = mysql_fetch_array($results)){
if(defined('ADD_echomessages_loop')){
eval(ADD_echomessages_loop);
$message = nl2br($row['message']);
$awnser[] = $row['type']."||".$row['id']."||".$row['author']."||".date(TIMESTAMP, $row['timestamp'])."||".$message;
$_SESSION['lastupdate'] = mktime();
if($row['id'] >= MAX_SIZE_DB){
cleandb();
if(function_exists("outputparser")){
outputparser($awnser);
else{
echo implode("\n", array_reverse($awnser));
return true;
else{
print('DIE||Fout nr '.mysql_errno($dbverbinding).' bij het uitvoeren van de SQLquery: '.mysql_error($dbverbinding)."\n");
return false;
else{
print('DIE||Functie addmessage() krijgt geen verbinding met database.\n');
return false;
function command($in){
global $commands;
$parameters = explode(" ", substr($in, 1));
$parameters[0] = strtolower($parameters[0]);
if(defined('ADD_command')){
eval(ADD_command);
if($parameters[0] == "help"){//speciale functie
if(isset($parameters[1])){//doelgerichte help
if(!isset($commands[$parameters[1]])){
if(print("PERSONAL||<tt>/".$parameters[1]."</tt> is not a function.<br/>Type <tt>/help</tt> for all available commands.")){
return true;
elseif(!isset($commands[$parameters[1]]['help'])){
if(print("PERSONAL||<tt>/".$parameters[1]."</tt> does not has a help.")){
return true;
else{
if((!isset($commands[$parameters[1]]['secure']) || (isset($commands[$parameters[1]]['secure']) && $commands[$parameters[1]]['secure'] == false) || (isset($commands[$parameters[1]]['secure']) && $commands[$parameters[1]]['secure'] == true && isset($_SESSION['isadmin']))) && print("PERSONAL||".$commands[$parameters[1]]['help'])){
return true;
else{
return true;
else{//list alle functies
$output = "";
foreach($commands as $key => $value){
if(isset($commands[$key]['usage']) && isset($commands[$key]['description']) && (!isset($commands[$key]['secure']) || (isset($commands[$key]['secure']) && (!$commands[$key]['secure'] || ($commands[$key]['secure'] && isset($_SESSION['isadmin'])))))){
$output .= "<li><tt>".$commands[$key]['usage']."</tt><br/>".$commands[$key]['description']."</li>";
if(!empty($output)){
print("PERSONAL||".nl2br("<ul class=\"help\">".$output."</ul>"));
else{
print("PERSONAL||No functions available.");
return true;
elseif(isset($commands[$parameters[0]])){
if(isset($commands[$parameters[0]]['function'])){
if(isset($commands[$parameters[0]]['secure']) && $commands[$parameters[0]]['secure'] == true){
if(!isset($_SESSION['isadmin'])){
if(print("PERSONAL||<tt>/".$parameters[0]."</tt> is not a function.<br/>Type <tt>/help</tt> for all available commands.")){
return true;
exit();
$awnser = eval($commands[$parameters[0]]['function']);
if($awnser != false){
if(isset($echo)){
print($echo);
return true;
else{
return false;
elseif(print("PERSONAL||<tt>/".$parameters[0]."</tt> does not has a function.<br/>Type <tt>/help ".$parameters[0]."</tt> for more details")){
return true;
elseif(print("PERSONAL||<tt>/".$parameters[0]."</tt> is not a function.<br/>Type <tt>/help</tt> for all available commands.")){
return true;
function cleandb(){
if(defined('ADD_cleandb')){
eval(ADD_cleandb);
if(connected()){
if($results = mysql_query("TRUNCATE ".MYSQL_PREFIX."messages")){
addmessage("Database has been cleaned", "Server", "notice");
return true;
else{return false;}
}else{return false;}
//plugins inladen.
if(PLUGINS_ENABLED && is_dir(PLUGINS_DIR)){
if ($handle = opendir(PLUGINS_DIR."/")){
while (false !== ($file = readdir($handle))) {
$bestand = PLUGINS_DIR."/".$file ;
$ext = pathinfo($bestand);
if($ext['extension'] == "php"){
include(PLUGINS_DIR."/".$file);
closedir($handle);
//aanvraagafhandeling
if(!isset($_SESSION['name']) && !isset($_GET['message'])){
echo "SETNAME";
elseif(isset($_GET['message'])){
if(!addmessage(str_replace("||", "|",$_GET['message']))){
print("WARNING||Kon bericht niet toevoegen\n");
elseif(!defined("STOP")){
if(!echomessages()){die("DIE||Kon berichten niet weergeven\n");}
else{
ob_end_flush();
-------------------------------------config.php (client)-----------------------------------
<?php
//het is ook mogelijk de installer te gebruiken. SLa dan dit bestand over en download het volgende, en zet het in dezelfde directorie als server.php en index.php
//http://jellinde.jl.funpic.org/phpchat_v2/plugins/_download_installer.php
define("MAX_MESSAGES", 10);
define("FIRSTTIME_MAX_MESSAGES", 1);
define("MYSQL_SERVER", "localhost");
define("MYSQL_USER", "root");
define("MYSQL_PASSWORD", "");
define("MYSQL_DATABASE", "chat");
define("MYSQL_PREFIX", "chat_");
define("MAX_SIZE_DB", 500);
define("TIMESTAMP", "Y-m-d H:i:s");//formaat van timestamp. Zie http://nl3.php.net/manual/nl/function.date.php
define("MAX_WORD_LENGTH", 30);
define("PLUGINS_ENABLED", true);
define("PLUGINS_DIR", "./plugins");
define("PASSWORD", "wachtwoord");
ken je google?
hier een paar zoek woorden
chatbox
php-chatbox
php
chatten
een chatbox die ik kan begrijpen
MySQL chatbox
MySQL
