#include "includes.h"
#include "tools.h"
#include "socket.h"
#include "buffer.h"
#include "list.h"
#define DLLEXPORT extern "C" __declspec(dllexport)
CList buffers;
CList sockets;
CList files;
int AddSocket(CSocket*);
int AddBuffer(CBuffer*);
int AddFile(HANDLE);
//Sockets
DLLEXPORT double tcpconnect(char*ip, double port, double mode)
CSocket* sock = new CSocket();
if(sock->tcpconnect(ip, (int)port, (int)mode))
return AddSocket(sock);
delete sock;
return -1;
DLLEXPORT double tcplisten(double port, double max, double mode)
if(sock->tcplisten((int)port, (int) max,(int)mode))
delete sock;
return -1;
DLLEXPORT double tcpaccept(double sockid, double mode)
CSocket*sock = (CSocket*)sockets.item((int)sockid);
if(sock == NULL)return -1;
CSocket*sock2 = sock->tcpaccept((int)mode);
if(sock2 != NULL)return AddSocket(sock2);
return -1;
DLLEXPORT char* tcpip(double sockid)
if(sock == NULL)return NULL;
return sock->tcpip();
DLLEXPORT double setnagle(double sockid, double value)
if(sock == NULL)return 0;
if(value)
sock->setnagle(true);
else sock->setnagle(false);
return 1;
DLLEXPORT double tcpconnected(double sockid)
if(sock->tcpconnected())return 1;
else return 0;
DLLEXPORT double udpconnect(double port, double mode)
if(sock->udpconnect((int)port, (int)mode))
delete sock;
return -1;
DLLEXPORT double sendmessage(double sockid, char*ip, double port, double buffid)
CBuffer*buff = (CBuffer*)buffers.item((int)buffid);
if(buff == NULL)return -2;
int size = sock->sendmessage(ip, (int)port, buff);
if(size < 0)return -sock->lasterror();
return size;
DLLEXPORT double receivemessage(double sockid, double len, double buffid)
int size = sock->receivemessage((int)len, buff);
if(size < 0)
int error = sock->lasterror();
if(error == 10054)return 0;
return -error;
return size;
DLLEXPORT double peekmessage(double sockid, double len, double buffid)
int size = sock->peekmessage((int)len, buff);
if(size < 0)
return -error;
return size;
DLLEXPORT double setformat(double sockid, double mode, char*sep)
return sock->SetFormat((int)mode, sep);
DLLEXPORT char* lastinIP()
return CSocket::lastinIP();
DLLEXPORT double lastinPort()
return CSocket::lastinPort();
DLLEXPORT double setsync(double sockid, double mode)
sock->setsync((int)mode);
return 1;
DLLEXPORT double closesock(double sockid)
delete sock;
sockets.set((int)sockid, NULL);
return 1;
DLLEXPORT double socklasterror(double sockid)
DLLEXPORT char* myhost()
return CSocket::myhost();
DLLEXPORT double compareip(char*ip, char*mask)
return CTools::comparematch(ip, mask);
DLLEXPORT double sockexit()
CSocket::SockExit();
return 1;
DLLEXPORT double sockstart()
CSocket::SockStart();
return 1;
DLLEXPORT char* hostip(char*host)
return CSocket::GetIp(host);
DLLEXPORT double getsocketid(double sockid)
return sock->sockid;
//Buffers
DLLEXPORT double writebyte(double val, double buffid)
if(buff == NULL)return 0;
return buff->writebyte((unsigned char)val);
DLLEXPORT double writeshort(double val, double buffid)
return buff->writeshort((short)val);
DLLEXPORT double writeushort(double val, double buffid)
return buff->writeushort((unsigned short)val);
DLLEXPORT double writeint(double val, double buffid)
return buff->writeint((int)val);
DLLEXPORT double writeuint(double val, double buffid)
return buff->writeuint((unsigned int)val);
DLLEXPORT double writefloat(double val, double buffid)
return buff->writefloat((float)val);
DLLEXPORT double writedouble(double val, double buffid)
return buff->writedouble(val);
DLLEXPORT double writechars(char*str, double buffid)
return buff->writechars(str);
DLLEXPORT double writestring(char*str, double buffid)
return buff->writestring(str);
DLLEXPORT double readbyte(double buffid)
return buff->readbyte();
DLLEXPORT double readshort(double buffid)
return buff->readshort();
DLLEXPORT double readushort(double buffid)
return buff->readushort();
DLLEXPORT double readint(double buffid)
return buff->readint();
DLLEXPORT double readuint(double buffid)
return buff->readuint();
DLLEXPORT double readfloat(double buffid)
return buff->readfloat();
DLLEXPORT double readdouble(double buffid)
return buff->readdouble();
DLLEXPORT char* readchars(double len, double buffid)
if(buff == NULL)return NULL;
return buff->readchars((int)len);
DLLEXPORT char* readstring(double buffid)
return buff->readstring();
DLLEXPORT char* readsep(char*sep, double buffid)
return buff->readsep(sep);
DLLEXPORT double getpos(double pos, double buffid)
if(pos == 0)return buff->writepos;
else return buff->readpos;
DLLEXPORT double clearbuffer(double buffid)
buff->clear();
return 1;
DLLEXPORT double buffsize(double buffid)
return buff->count;
DLLEXPORT double setpos(double pos, double buffid)
buff->readpos = (int)pos;
buff->writepos = (int)pos;
return pos;
DLLEXPORT double bytesleft(double buffid)
return buff->bytesleft();
DLLEXPORT double createbuffer()
CBuffer* buff = new CBuffer();
return AddBuffer(buff);
DLLEXPORT double freebuffer(double buffid)
if(buffid == 0)return 0; //no deleting default buffer
delete buff;
buffers.set((int)buffid, NULL);
return 1;
DLLEXPORT double copybuffer(double destinationid, double sourceid)
CBuffer*destination = (CBuffer*)buffers.item((int)destinationid);
if(destination == NULL)return 0;
CBuffer*source = (CBuffer*)buffers.item((int)sourceid);
if(source == NULL)return 0;
destination->addBuffer(source);
return 1;
DLLEXPORT double copybuffer2(double destinationid, double start, double len, double sourceid)
destination->addBuffer(source->data+(int)start, (int)len);
return 1;
//tools
DLLEXPORT char* getmacaddress()
return CTools::getmacaddress();
DLLEXPORT char* md5string(char*str)
return CTools::md5string(str);
DLLEXPORT char* md5buffer(double buffid)
return CTools::md5buffer(buff);
DLLEXPORT double bufferencrypt(char*pass, double buffid)
CTools::encryptedbuffer(buff, pass);
return 1;
DLLEXPORT double adler32(double buffid)
return CTools::adler32(buff);
DLLEXPORT double bufferexists(double buffid)
return 1;
DLLEXPORT double netconnected()
return CTools::netconnected();
DLLEXPORT double fileopen(char*name, double mode)
HANDLE file = CTools::BinOpen(name, (int)mode);
if(file != NULL)
return AddFile(file);
return -1;
DLLEXPORT double fileclose(double fileid)
HANDLE file = (HANDLE)files.item((int)fileid);
if(file == NULL)return -1;
files.set((int)fileid, NULL);
return CTools::BinClose(file);
DLLEXPORT double filewrite(double fileid, double buffid)
if(buff == NULL)return -1;
return CTools::BinWrite(file, buff);
DLLEXPORT double fileread(double fileid, double bytes, double buffid)
return CTools::BinRead(file, (int)bytes, buff);
DLLEXPORT double filepos(double fileid)
return CTools::BinGetPos(file);
DLLEXPORT double filesetpos(double fileid, double pos)
return CTools::BinSetPos(file, (int)pos);
DLLEXPORT double filesize(double fileid)
return CTools::BinFileSize(file);
DLLEXPORT double iptouint(char*ip)
return CTools::ip2uint(ip);
DLLEXPORT char* uinttoip(double ip)
return CTools::uint2ip((unsigned int)ip);
int AddBuffer(CBuffer*b)
for(int i = 0; i < buffers.count; i ++)
if(buffers[i] == NULL)
buffers.set(i, b);
return i;
buffers.Add(b);
return buffers.count-1;
int AddSocket(CSocket*b)
for(int i = 0; i < sockets.count; i ++)
if(sockets[i] == NULL)
sockets.set(i, b);
return i;
sockets.Add(b);
return sockets.count-1;
int AddFile(HANDLE b)
for(int i = 0; i < files.count; i ++)
if(files[i] == NULL)
files.set(i, b);
return i;
files.Add(b);
return files.count-1;
DLLEXPORT double dllInit()
buffers.Add(new CBuffer());
sockets.Add(new CSocket()); //dummy socket
return 1;
BOOL APIENTRY DllMain( HMODULE hModule,
DWORD ul_reason_for_call,
LPVOID lpReserved
switch (ul_reason_for_call)
case DLL_PROCESS_DETACH:
for(int i = 0; i < buffers.count; i++)
if(buffers[i] != NULL)
delete (CBuffer*)buffers.item(i);
for(int i = 0; i < sockets.count; i++)
if(sockets[i] != NULL)
delete (CSocket*)sockets.item(i);
if(files[i] != NULL)
CTools::BinClose((HANDLE)files.item(i));
break;
return TRUE;
